Old 05-27-2015, 08:24 PM   #51
bowfaber
bowfaber's Avatar
Re: 4BT Cummins 4L85 Long to Short
bags
bowfaber is offline   Reply With Quote
Old 05-27-2015, 08:25 PM   #52
bowfaber
bowfaber's Avatar
bags con't
Old 05-27-2015, 08:26 PM   #53
bowfaber
bowfaber's Avatar
more bags
Old 05-27-2015, 08:26 PM   #54
bowfaber
bowfaber's Avatar
bag fab
Old 05-27-2015, 08:32 PM   #55
bowfaber
bowfaber's Avatar
Drive shaft came out of an 84 Chevy I believe.
Old 05-27-2015, 08:32 PM   #56
bowfaber
bowfaber's Avatar
drive shaft
Old 05-27-2015, 08:33 PM   #57
bowfaber
bowfaber's Avatar
shaft con't
Old 05-27-2015, 08:47 PM   #58
bowfaber
bowfaber's Avatar
fuel tank. Aluminum. Lengthened the sending unit to make it read a little more accurate.
Old 05-27-2015, 08:47 PM   #59
bowfaber
bowfaber's Avatar
fuel
Old 05-27-2015, 08:54 PM   #60
bowfaber
bowfaber's Avatar
fuel 2
Old 05-27-2015, 08:54 PM   #61
bowfaber
bowfaber's Avatar
fuel 3
Old 05-27-2015, 08:55 PM   #62
bowfaber
bowfaber's Avatar
fuel 4
Old 05-27-2015, 09:22 PM   #63
bowfaber
bowfaber's Avatar
Turbo flange. 1/2 inch bar stock. This turns the back of the turbo down, making it easier to install the exhaust, since I put the engine back so far.
Old 05-27-2015, 09:25 PM   #64
bowfaber
bowfaber's Avatar
turbo
Old 05-27-2015, 09:30 PM   #65
bowfaber
bowfaber's Avatar
I cut down some tubing to make it the proper size for the turbo flange. I used a 2x4 block of wood, kept cutting and checking the fitment- wood is cheaper than metal. Found the areas that need some material added, transferred the measurements to the metal tube and cut away. It fit just right on the first go around. Measure ten times, butcher some wood, cut the metal once...
Old 05-27-2015, 09:30 PM   #66
bowfaber
bowfaber's Avatar
flange
Old 05-27-2015, 09:32 PM   #67
bowfaber
bowfaber's Avatar
I turned the turbo a bit. Pinch the clamp with a locking pliers and use a leverage tool to rotate the turbo.
Old 05-27-2015, 09:34 PM   #68
bowfaber
bowfaber's Avatar
Next I had to do surgery to the tubing
Old 05-27-2015, 09:35 PM   #69
bowfaber
bowfaber's Avatar
I had a hard time tig welding the tube to the flange with mild steel rod (it would keep cracking the weld). I switched to silicon bronze rod and it glued it together just fine.
Old 05-27-2015, 09:40 PM   #70
bowfaber
bowfaber's Avatar
This was an intercooler that was laying around. I can't remember if was from the step van or not. More cutting and welding was required.
Old 05-27-2015, 09:41 PM   #71
bowfaber
bowfaber's Avatar
radiator and intercooler bracket. Starting the ram air scoop.
Old 05-27-2015, 09:42 PM   #72
bowfaber
bowfaber's Avatar
Did some cutting here and there to be able to service the air filter.
Old 05-27-2015, 09:43 PM   #73
bowfaber
bowfaber's Avatar
intercooler tubing
Old 05-27-2015, 09:45 PM   #74
bowfaber
bowfaber's Avatar
The 4BT Cummins never came with an AC option, so no brackets. Time to make some.
Old 05-27-2015, 09:46 PM   #75
bowfaber
bowfaber's Avatar
For the Air Conditioning system I went to Old Air Products. I will definitely use them in the future!
