Old 07-25-2015, 01:25 PM   #51
tre5
tre5's Avatar
Re: Building a '49 for myself
Here's some more photos of the rear link setup
Pan hard bar mounts
4 link tubes and Ridetech coil overs mocked up
Rear view of the Ridetech coil overs
A couple of the pan hard bar installed
Follow me on facebook and Instagram. Tre 5 Customs
My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809
Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105
Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949
tre5 is offline   Reply With Quote
Old 07-25-2015, 01:27 PM   #52
tre5
tre5's Avatar
Ran the Russell stainless steel braided lines along the axle as well.
And installed the McGaughys 13" rear disc brake setup and the 20" X 10" Intros wrapped in 275/40R20 Toyo Proxes STII tires out back.
Old 07-25-2015, 01:37 PM   #53
tre5
tre5's Avatar
Moving up front... Installed a set of Ridetech controls arms that are meant for G body cars. The pivot points on the frame are the same as the S10, but Ridetech has done a ton of R&D on the G body cars, so we decided to go with their "Truturn" setup which makes changes in camber curve, caster gain, and minimizes bump steer. The control arms are connected to a set of McGaughys 2" drop spindles and their 13" front brake kit. I don't have good photos of this step because we were shooting a tech article for Street Trucks on the installation.
Here's a photo of the steering shaft that's part of the AD-Engineering.com kit. Works out perfectly with the stainless eBay headers.
Here's what I am going for with my ride height. I'm still waiting of the coil overs to show up, so this is just held up by the jack.
Old 07-25-2015, 01:40 PM   #54
tre5
tre5's Avatar
Wheels up front are 20" X 8.5" and wrapped in 255/40R20 Toyos. I have 2" spacers on each side to push the wheel out, and adapt the pattern from the 5x4.75" from the S10 to the 5x5" of the rear 12 bolt axle.
Old 07-25-2015, 03:02 PM   #55
84blaze
I really like what you're doing man. Super excited to get a bit further on my project. I think I'll be building my own mounts as the ADE kit doesn't hang the body low enough for what I want to do.
I wonder how your turning radius will be with the 40 series up front... I know with a 245/35R20 and no spacer they rub pretty bad at full knock. The 2" spacer should make all the difference.
84blaze is offline   Reply With Quote
Old 07-25-2015, 03:24 PM   #56
Advanced Design
Advanced Design's Avatar
Nice work tre5...very nice!
Advanced Design is offline   Reply With Quote
Old 07-25-2015, 03:25 PM   #57
tre5
tre5's Avatar
Old 07-25-2015, 03:26 PM   #58
tre5
tre5's Avatar
I can turn, lock to lock, at the height in the photos. It doesn't rub anywhere. I was pleasantly surprised!
Old 07-25-2015, 04:53 PM   #59
84blaze
Thats awesome dude. Looking forward to more progress!!
Old 07-25-2015, 05:43 PM   #60
DeanTX
DeanTX's Avatar
Tre5, how many inches from the ground to front of running board? I'm trying to get an idea of how low I can go without needing a trans hump. Great skills BTW.
DeanTX is offline   Reply With Quote
Old 07-25-2015, 05:48 PM   #61
tre5
tre5's Avatar
I put the frame about 4.5" from the ground. I haven't measured the running boards. Plus I don't have the coil overs in up front yet, so it's still just a guess as to where it'll actually sit.
Old 07-25-2015, 11:17 PM   #62
84blaze
Can you post a photo of the running board in comparison to the frame rail?
Thanks!
Old 07-31-2015, 08:36 PM   #63
tre5
tre5's Avatar
Thanks!
The running board is 2.75" above the frame.
Old 07-31-2015, 08:37 PM   #64
tre5
tre5's Avatar
Got the bed on and we are in the process of tubing the bed sides. I have all kinds of room between the frame and the wheel/ tire.
Old 07-31-2015, 08:41 PM   #65
tre5
tre5's Avatar
Some engine compartment photos with the radiator mounted up. I used a 19X22 unit from Summit.
Old 07-31-2015, 08:49 PM   #66
tre5
tre5's Avatar
Also started on the exhaust. Ran ebay stainless headers with 2.5" outlets, to a 2.5" Y-pipe, then steps up to 3". 3" Continues through a Black Widow Pro Venum 250 series muffler. Then it snakes its way over the 4 link, over the axle, around the coilovers, above the panhard bar, under the frame, and finally out the bottom of the bumper.
Old 07-31-2015, 09:51 PM   #67
DeanTX
DeanTX's Avatar
Looking good! On the rear coilovers, what is the spring rate?
Old 07-31-2015, 10:10 PM   #68
tre5
tre5's Avatar
250lbs
Old 07-31-2015, 11:26 PM   #69
joedoh
joedoh's Avatar
looks crazy clean! nice work
and at first I thought you were pointing at the chrome jackstand. which is pretty cool in its own right.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 08-01-2015, 10:19 PM   #70
youngrodder
youngrodder's Avatar
Very nice work Tre5...Following along.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-06-2015, 08:37 PM   #71
tre5
tre5's Avatar
I got the Ridetech coil overs mounted up in the front. I took the advice of Ridetech and cut out the coil retaining nubs in the spring pocket before I installed them. I'm pretty happy with the ride height, but I hope the rear comes down about an inch once I get some gas in the tank and get the two batteries in.
Old 08-06-2015, 08:41 PM   #72
tre5
tre5's Avatar
I feel like all I've done all week is align panels. I got the bed mounted with the new tubs for the 10" rear wheels, then the rear fenders, then the running boards and filler panels lined up with the bed and fenders, then the rear bumper and splash apron, then all the front end... inner fenders, outer fenders, lower apron, radiator support, upper apron, fender supports, grill, hood hinges, hood springs, front bumper and splash apron... WHAT A PAIN IN THE ASS!!! It's really starting to look like a truck though. Off to the body shop tomorrow, finally.
Old 08-06-2015, 10:53 PM   #73
youngrodder
Looks great... you are crankin on this one.. What color you going with?
Marc
Old 08-06-2015, 10:56 PM   #74
tre5
tre5's Avatar
Marc
WA800J is the code. It's the pearl white found on newer GMs.
Old 08-07-2015, 10:11 AM   #75
solidaxel
solidaxel's Avatar
250lbs
Which Shock, adjustable?
Won't 250# be a bit light?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
