#51 |
Re: My 54 3100 pickup build
Main rail sections.
"There are two types of people in this world: those who like Chevy pickups, and those who don't." |
#52 |
10 piece dimple die set, got so many plans for these babys
#53 |
One end of the rear notch box plate
#54 |
Yep, other end of the notch
#55 |
Mundane fab, drill pilot hole, drill medium hole, punch pilot hole, punch main hole, squash in the dimple die press. Rince and repeat 32 times
#56 |
Close up
#57 |
![]() Join Date: May 2015
Good job on the patchwork..but something don't look right....your steering wheel is on the wrong side...ha ha..
#58 |
Came out pretty good. I should be getting paid for this sh1t
#59 |
Another angle
#60 |
Forgot to add, the rear notch has some fissure plates added prior to boxing
#61 |
I purchased a TCI IFS right hand drive front end, with RHD power rack, coil spring with shock, 2" drop spindles, sway bar, etc, quality was good, but not without issues, the rack had no clearance to fit the uni joint
And the spring towers were only tacked in place, Anyway cant sweat the small stuff. Here it is welded in place.
#62 |
Close up of most of the bits fitted.
#63 |
The 1986 GM rotor and single piston caliper are probably ok for your run of the mill drum brake car upgrade, but my little truck needs more to stop the modified LS1, especially with the large mass of the American Racing 20" Daytona rims. After some research, it seems that I could buy some billet hubs from CPP or modify something else. Gen 1 Camaro Drum brake hubs run the same bearing as the Gen 3 rotors that came in the TCI kit.
(Disc brake hubs have a different offset,) I took a used pair of 68 drum brake hubs, machined the rough cast surface down, pressed on an outer sleeve to fit the bore in my wheels, fitted some ARP 1/2"-20 wheel studs. Painted them suckers gloss black. Purchased a new set of Ford Grenada timken bearings. The seal was tricky as the stub on the spindle was larger than the GM. But I found one that will work.
#64 |
Here they are ready to fit
#65 |
Our top of the range Holden Special Vehicles SS Commodore, HSV has 365mm (14.4") front rotors, and 350mm (13.8") rear rotors. These Were my choice for a budget brake upgrade, easy to replace locally, and the HSV can be ordered with a Redline Brake package that includes the same front Brembo Calliper as the USA 2010 Camaro. Which means the HSV master cyclinder booster will combine and match up well.
#66 |
Fills out them big wheels real well, all up cost is close to a grand.
#67 |
Someone is about to ask how I got the Camaro Brembo calliper to fit the mustang II spindle, where a GM single piston stopper was mounted previously.
I noticed many brake upgrade brackets were made from 3/8 plate, which for my build was not enough, After many visits to lukeskaff.com who has a great site with tons of helpful info. I decided 16mm plate was required, made a couple of thin alloy test plates untill I got the correct radial height, and cut out my 16mm plate, drilled some holes in the right place, made 12mm spacers to set the calliper depth right. And as the top calliper hole needed to be where the threaded bolt attaching to the spindle was, I cut a notch out. Inseted a grade 8 bolt with its head cut off. And welded it to the bracket. Allowing me to drill the top hole alongside the welded stud. Made that sound more complicated than it needed to be.
#68 |
Here it is in all its glory,
![]() And as the Mustang II came with grade 5 hardware, thats safe right? No way jose, so some grade 12 socket heads were in order.
#69 |
The rear wheels should sit close to this height when mounted, this week I moved on to setting up the rear end, I am using a Summit Circle track 9" housing, 55" wide flange to flange. Add 2.1/2" each side for the axle flanges, thats 60" overall, hub to hub.
I am using 55 chevy pickup 3" drop leaf spring set in the rear. Have removed the top leaf, and had the second leaf remade shorter eye to eye. So as to mount them on the outside of the chassis rails. Smarty pants amoung you know there is not enough space, correct, give yourself some candy. Earlier while playing with the chassis rails, I pinched them parallel just behind the last floorboard mounting bracket. And pulled them back out where the rear bend was. The chassis tapers from the front, all the way to the floor board bracket, then it's parallel to the rear bumper.
#70 |
In order to mount the leaf springs as close as possible towards the floor board bracket, I had to make my own. Heres the drawing.
#71 |
Looks like these will do the trick
#72 |
This will be my last pic for a couple weeks, while I make some more progress. Back soon.
#73 | |
Posted via Mobile Device |
#74 |
Village Idiot....
Extremely impressed and jealous of your fabricating skills.....beyond nice!
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
#75 | |
Makes me look like I know what Im doing :-) Posted via Mobile Device |
| Bookmarks |
| Tags |
| 1/2 ton, 1954 chevy, 3100 |
