Old 07-31-2015, 10:14 PM   #51
57chevyman
57chevyman's Avatar
Re: Flawed Success Turn Signal Puzzle
you're sure the tail light is grounded good? i had to run a separate ground wire. do your taillights already have a ground wire bc they are LED?
i know the incandescent lights are supposed to ground thru the bracket, but that wouldnt work on my truck.. and i was getting a similar problem.. both sides flashing.... as soon as i gave the lights a stronger ground, they worked perfect
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 07-31-2015, 10:25 PM   #52
Tire Guy
Tire Guy's Avatar
I'll give it a shot. There is not a separate ground wire on the lights.
Tire Guy is offline   Reply With Quote
Old 07-31-2015, 10:59 PM   #53
1project2many
Bad grounds at the front lights can cause both sides to blink. If the turn signals don't blink in the front when the headlights are on I'd suspect bad grounds.
1project2many is offline   Reply With Quote
