Old 08-12-2015, 09:28 AM   #51
toddoky
Re: Hooker 73-87 GM truck LS swap system
Originally Posted by toddoky View Post
The radiator in the red truck is made by CRS...make sure you're sitting down if you go looking for pricing information.
I incorrectly stated the name of the source of the radiator earlier...the correct name is C&R Radiators.
toddoky is offline   Reply With Quote
Old 08-13-2015, 10:02 PM   #52
Misled
Misled's Avatar
I bought the 20-137 kit. I keep hearing of an install kit I will need. Can you advise what that is (and part number) please?
Misled is offline   Reply With Quote
Old 08-14-2015, 07:08 AM   #53
toddoky
Depending on the engine you are installing the kit with, you may need to use an available spacer kit to match the fore/aft offset of the Holley components with the water pump and balancer on your engine. What LS engine are you installing?
Old 08-14-2015, 10:27 AM   #54
toddoky
These are the part numbers of the Holley installation kits; pick the one you need based on the water pump/balancer offset you have on your engine...
Corvette/CTSV - 21-1, F-Body/GTO- 21-2 or truck- 21-3
Old 08-14-2015, 10:59 AM   #55
Matt Cramer
Ok, something I'm curious about on '67-'72 trucks. Bit of a weird question, and I can understand if you don't have the answer.
I made a set of homemade mounts that have similar bolt positions to these: https://holley.com/products/ls_power...parts/12622HKR
Then I put the stock engine stands in the six cylinder position so the engine mounted in the same location. I used a set of used 2010 Camaro exhaust manifolds, and had to do a lot of sawing and welding on the stock engine stands to make them clear everything.
Would the Hooker manifolds have cleared this?
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 08-14-2015, 11:19 AM   #56
toddoky
I've not done any test fitting of any type of parts on 67-72 trucks, so I unfortunately don't have an answer for you either way.
Old 08-14-2015, 11:32 AM   #57
Misled
Misled's Avatar
It is the GTO, so thank you...I will get that on order as well
Old 08-15-2015, 03:37 PM   #58
roundhouse
The engine brackets are compatible with the later factory truck compressor that does not have the rear sensor on it, but the edge of the front lip of the clamshell mounting brace on the truck will need to be trimmed slightly to clear the compressor.
so you are saying that we dont have to relocate the AC compressor when for a LS 5.3 in a 73-87 ?
how does it not hit the frame?
or do we have to move the transmission?
we have a 76 K-10 4wd with a stock 70's 350 and a NV-3500 5 speed from a 2007 Silverado.
roundhouse is offline   Reply With Quote
Old 08-16-2015, 07:29 AM   #59
toddoky
Hey Roundhouse. The later type A/C compressor can be used in the stock location by notching the front lower lip on the right side frame bracket that the clamshell mount attaches to. This applies only to 2WD trucks as I've not spent any time with a 4WD truck to be able to know what the differences are in that area. 4WD fitment validation has not been discussed here by management, so I don't know if or when that may happen. I'm suspecting that the only components in this system that would also fit a 4WD are the engine brackets and the headers; the trans crossmember and the exhaust systems will be a no-go.
Old 08-17-2015, 11:31 PM   #60
Misled
Misled's Avatar
toddoky,
Yet another question for ya......
The PART# 12646HKR crossmember. Mine is on order, is it painted or powdercoated from the factory?
Thanks again,
Barry
Old 08-17-2015, 11:52 PM   #61
toddoky
toddoky,
Thanks again,
Barry
Semi-gloss black powdercoat finish.
Old 08-18-2015, 03:35 PM   #62
Misled
Misled's Avatar
Perfect...saves me a step!!
Old 08-18-2015, 04:13 PM   #63
roundhouse
we are keeping the 2007 NV3500 5 speed thats currently in the truck,
the trans should stay in the same place?
dont think we;d need the crossmember, its for swapping in a 4L60, right?
Old 08-19-2015, 10:10 AM   #64
toddoky
Hey roundhouse. The Hooker crossmember can be used to install a TH2004R,TH400, 4L60-4L70, 4L80, T56 or T56 Magnum transmission in a 2WD truck. None of the parts in this system have been designed for or tested for fitment on a 4WD truck, so any information I give you is likely to be erroneous or useless in regards to your 4WD K-10. I would be happy to see you use Hooker components in your swap, but they just weren't designed for your application; you may have success with the engine mounting brackets, but that's about it.
Old 08-21-2015, 04:14 PM   #65
Houston Ben
Houston Ben's Avatar
Sooo...no worky for 6L80?
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 08-21-2015, 05:08 PM   #66
toddoky
There is no direct accomodation for that trans, but because the location of its mount lies between a TH400 and a 4L60, it would be easy enough to fabricate an adapter bracket to pick up its mount off of the Hooker crossmember.
Old 08-22-2015, 12:50 PM   #67
Malo83
Cruzzzn' Vet
Malo83's Avatar
Glad to see you over here, been following on LS1tech
http://ls1tech.com/forums/conversion...m-preview.html
Malo83 is offline   Reply With Quote
Old 08-22-2015, 01:27 PM   #68
toddoky
I'm glad to be here as well. I'm a long-time and repeat squarebody owner myself, so I have more personal interest in the topics on this forum than what is present on any of the other sites I frequent in support of the Hooker LS swap kits.
Old 09-08-2015, 05:49 PM   #69
Misled
Misled's Avatar
Some Hooker pieces in place
Old 09-08-2015, 07:24 PM   #70
toddoky
Looks great, glad to see more Hooker components in use.
Old 09-08-2015, 08:48 PM   #71
indymachinist
does look good. clean and simple.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-10-2015, 07:58 PM   #72
Advanced Design
Advanced Design's Avatar
This LS swap competition looks very interesting with a focus on the 73 - 87 C10.
Winner gets to keep the provided LS engine and Holley parts.
https://www.holley.com/events/lsfest/engineswap/
Advanced Design is offline   Reply With Quote
Old 09-15-2015, 03:03 PM   #73
Pulse_GTO
Would love to know more about this.
Pulse_GTO is offline   Reply With Quote
Old 09-17-2015, 02:38 PM   #74
toddoky
The process is rather straight forward as long as you have fabricating abilities and equipment. You would start by installing your engine and trans in your truck using the Hooker engine mounting brackets and then jack up the rear of the transmission high enough to allow you to position the Hooker crossmember under the mount of the 6L80 trans. You would next adjust the height of the rear of the trans up or down until you achieve U-joint working angles that are optimized for your trucks' ride height/suspension configuration. Once that is achieved, you then need to design an adapter bracket that will connect the trans mount to the crossmember. If the crossmember crossbar is too high and leaves too little room for the design of such a piece, then you would just move the crossmember back about 4" and purchase/use the Hooker T56 crossmember cantilever bracket with the crossmember to provide a lower mounting surface height to build to.
Old 10-19-2015, 09:06 PM   #75
Misled
Misled's Avatar
toddoky, I'm having trouble figuring out which 2.5 exhaust fits my truck. It is a shortbed and I want the side exit exhaust.
Thanks,
Barry
