#51 |
![]() ![]() Join Date: Apr 2012
Re: Another piece of the puzzle showed up.
Winston , do you have the part number from that clutch ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#52 |
![]() Join Date: Aug 2013
Sure do nos baby, the box label did have the words clutch on it when I saw it for sale, but didn't have it when it arrived...
#53 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#54 |
#55 |
By the part number your clutch is Buick , not Chevrolet . Again it may work but is not "correct". Theres a bunch of different clutches out there like this all designed for different combinations. Looks like you do have the correct blade because that particular clutch has the larger hub which also means a larger bolt pattern to the blade. Heres the exact application for your clutch.
Fits 64 special Skylark V8 HD cooling ,police,Delcotron or A/C. 65-67 Special ,Skylark, Le Sabre V8 with a/c,ATC & HD Cooling EXCEPT GS 69-70 special ,skylark 350 with a/c 69-70 lesabre with A/c.
#56 |
Heres a couple more of those including the superceded part number .
http://www.ebay.com/itm/NOS-1964-197...3D121687654492 http://www.ebay.com/itm/NOS-1969-197...26405c&vxp=mtr
#57 |
Too funny, I bought the second one... I knew it wasn't correct. The one I had before got trashed at the platers so I had to get something that was nice and nos. Oh and cheap
#58 |
Nice job on finding one that would fit the truck blade ! Heres pictures of the physical difference between Winstons and the correct Chevy clutch. The used one on the right is a Buick clutch.
#59 |
its just a little guy, thanks now i gotta search for a correct one. they aint cheap, but i'll find one CHEAP!!!
#60 |
![]() Join Date: Aug 2008
is the fan number 3883159 one off from the clutch number?
#61 |
Yes . I found the blade number in a 1967 Chevrolet parts book . They List the blade the same way or application as the clutch . That number was superseded by two different 6 digit numbers in 1972 but those numbers end up being 7 blade fans. I ran into a clutch Yelmer that has a longer stem or is spaced out further than the ones pictured nos . Book states there's a "second design " ? Which I think these short shaft ones are ? Have you noticed a date on these blades ? The orange one I posted has a 68 stamped in it . Winston's it looks to have a 6 ?
#62 |
Hello Jon one is on the truck , can see it. i will look at my others i have one nos and 2 used is the date stamped or inked on ?
#63 |
The orange one has a stamp "68" or is it 89 ? Winston's I could see a 6 stamp. I have one more I can look at. Will look tomorrow .
#64 |
The correct truck one is huge!
#65 | |
#66 |
thanks for the parts, how did you know i needed a battery hold down!!! the P.O made this one, kinda cool. not correct...
#67 | |
Posted via Mobile Device |
