#51 | |
Re: project "C10 Fever" (68 factory black 396 swb)
#52 |
![]() Join Date: Dec 2006
I think it sits perfect!
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#53 |
![]() Join Date: Dec 2012
looking gooooood!!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!!
#54 |
![]() Join Date: Jan 2007
pulled the beast out today for some much needed shop cleaning. i'm not positive but i think i may be a bit too low in the front. it looks like if i turn going through any kind of dip the tires might rub the inner fender. the front drop is supposed to be around 4". it's a 2.5" spindle, and factory springs cut to the same length as a pair of front springs i was told was straight from the ECE 4/6 kit, which should have been 1.5" (i think). it's possible they are cut more than i thought, or they are a bit worn out. they looked really nice, but you never know. i was going for a 4/5, but i think i have more like a 5.5 front 5 rear...
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#55 |
Awesome truck and some nice work done there man! I'll tag along for this. C'mon big block!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776
#56 |
thanks brother. i've checked out your build too, i think we've got the exact wheel/tire setup. yeah i'm getting really impatient about the 396 sitting on the stand. i've got a "nasty" cam picked out, can't wait for that phase.
#57 |
Looking good!!!!!
![]() ![]() I hope Louie is looking at this!
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#58 |
looking great!
#59 |
Build looks great! I'm in till the end.
CHEVY/GMC VIN DECODERS |
#60 |
thanks guys! i've been busy with other things for the last few months, but should make some more progress soon.
#61 |
I'd drive it some to see the front end works. I'm not a fan of much lowering, yours looks just about right! If it has a small block in it now, that front end WILL be lower with the big six (396...
)Where did you get those hubcaps? |
#62 | |
i got the caps in a trade.
#63 |
![]() Join Date: Dec 2015
Those caps don't look good on there, you should sell them to me
#64 | |
#65 | |
I think the front is perfect if it doesn't rub, back is still an inch too high. Although if it came up an inch in the front is might look perfect as well.
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
#66 | |
![]() they are 68 only and are not reproduced. they are VERY hard to find in stainless. i appreciate the input, and i tend to agree with you. i'm extremely fickle about these things so who knows where it will end up.
#67 |
so i wrapped up my other project (vitamin c) so i'm getting back onto the 68.
finished installing the brake lines. welded on some brackets and bolted on new tabs since the 71-72 parts connect on the front of the crossmember. installed the sway bar and shocks. now i have to figure out this stance... the front was too low (see post 54). so i pulled the cut oem springs out and installed new bbc stock height front springs for a starting point (next step is installing the 396). i am liking the 5" drop in the rear, now i need to figure out how much front spring to cut. i'm thinking after i install the 396 and cut 1/2 to 3/4 of a coil i'll have a very slight rake, which would be perfect. until i change my mind again... ![]()
#68 |
stole a photo from chewychevy67's build thread and tweaked it to represent what my truck would have looked like from the factory. i will definitely be going with black paint with a white grille and white tailgate letters and full trim. still undecided on the white roof, but it sure looks classy! i'm not doing any mods to this truck that can't easily be reversed so some day when i'm old and grumpy i can do a factory resto...
#69 |
I like that. I do like the white roof. It is sharp. I'll save that picture to my computer as well!!
#70 |
alright so i finally have the stance i've been looking for. i had to cut a coil off the new bbc springs. the bottom coil i removed was 1", and the drop was just under 2", just as i had hoped (17"/9" control arm ratio). once i get the 396 in i think it will drop another 1/4" to 1/2" which will be perfect.
#71 |
Great Progress.
Rincon |
#72 |
Nice stance. What is your total drop front/rear?
#73 |
5" springs out back. 2.5" spindle plus one cut coil that dropped the front end 2". but it's a sbc sitting on bbc springs. so i'd say it's the equivalent of a 4/5 drop.
#74 |
Do you still have your old 275 60/15 you want to sell?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#75 |
sold them a while ago
| Bookmarks |
