![]() Join Date: Mar 2004
Body roll?
Need some input.
New 2.5 lift (all spring) with extended pitman arm (additional drop) New poly body mounts / transmission / transfer case mounts New tie rod ends / drag link ends New wheel bearings / new upper and lower ball joints. New close range steering box from RedHead. 15:1 ratio New intermediate shaft. New U-joint and rag joint. Hydroboost set up using the flow control valve from factory power steering pump. Alignment looks good and camber / caster looks good by just using a 3' level. I am having a horrible time keeping this thing pointed forward. A small bump in the road causes this thing to dip / dive / steer any way it wants which leads me to swaying all over and I go back and forth like a rally car driver on the steering wheel just in order to keep the thing in my lane. It is not safe. Even letting off the gas at a normal cruising speed causes it to do all this. It is NOT death wobble. Everything up front is brand new and tight. Even swapped the steering box out with a 18:1 from RedHead and still doing the same thing. Any ideas?
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
| Bookmarks |
