Old 01-12-2016, 10:40 AM   #51
reaper71
reaper71's Avatar
Re: Reed 78 FJ40 Rebuild
Pic #1. The first coat of filler.
Pic #2. Drivers side applied.
Pic #3. The passenger side after it was blocked and spot primed again.
Pic #4. The cowl after it was blocked and primed again.
Mark...
reaper71 is offline   Reply With Quote
Old 01-12-2016, 03:43 PM   #52
RockinKees
RockinKees's Avatar
That's looking real good!
Is it going to be a showcar?
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-13-2016, 10:15 AM   #53
reaper71
reaper71's Avatar
Nope..
The owner is going to be taking it to Florida and leaving it at his Vacation home. He wanted something real nice to drive when he goes and stays for extended time.
He's owned it for a long time and finally wanted to make it nice again it will live most of it's life with the top removed at the beach..
Mark...
Old 01-13-2016, 10:23 AM   #54
reaper71
reaper71's Avatar
Pic #1. Drivers side after spot primer.
Pic #2. Guide coat on and ready for blocking.
Pic #3. Body all blocked and ready for final primer.
Mark...
Old 01-13-2016, 09:19 PM   #55
Advanced Design
Advanced Design's Avatar
Thanks for the explanation on the coating Mark. Wow, lotta blocking and priming! Hours and hours...
Advanced Design is offline   Reply With Quote
Old 01-14-2016, 10:13 AM   #56
reaper71
reaper71's Avatar
Actually it only took a total of 4 days.
with it having so much flat surfaces it moved along pretty fast. plus since the panels were pretty damn straight helped out!
It spent more time drying than actual sanding!!
Mark...
Old 01-14-2016, 10:26 AM   #57
reaper71
reaper71's Avatar
Pic #1. This was taken after the final primer was shot.
Pic #2. Back in final. (If anyone is wondering Why so many holes on the door openings?) One set is for the short doors (top off) and 2nd set for tall doors (top on)
Pic #3. In this shot I'm building a cart from 1x1 tube that the tub is bolted to. This thing is a pain in the neck to move and transfer to a trailer so I made this. It will also aid in spraying the tub with the coating.
unbolt and lift,spray underside,bolt back down spray inside and out and ship!
Pic #4. Another shot of cart and also side view of final primer.
Mark...
Old 01-14-2016, 02:04 PM   #58
Low Elco
Great lookin' work! Gonna look sweet at the beach.
Low Elco is offline   Reply With Quote
Old 01-14-2016, 02:20 PM   #59
RockinKees
RockinKees's Avatar
Originally Posted by reaper71 View Post
Nope..
Mark...
Well, it's going to be a very nice beachcruiser then
Masterpiece Mark!
Cheers!! Kees.
Kool Guyz CC
Old 01-15-2016, 10:28 AM   #60
reaper71
reaper71's Avatar
Thank's guy's for the compliments!
Mark...
Old 01-15-2016, 05:55 PM   #61
BlueJeep
BlueJeep's Avatar
Looking good! I see the plastic hanging in the background, care to share how you've set up your "booth"?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 01-16-2016, 10:27 AM   #62
reaper71
reaper71's Avatar
Sure!!
Went to the local Walmart and picked up several rolls of 7mil plastic 10' by 25' and then me and Dad used the air stapler and fastened it to the ceiling and let hang. It's a bit crude by does a great job keeping outside debris from getting into the spray area. After the plastic was up I sealed off any open spots with masking tape. Then I used the shop vac and vacuumed the lights,rails etc. to get them clean followed by moping the floors.
On another build of mine (Blakes GMC) It shows us putting up the plastic.
Hope this helps.
Mark...
Old 01-18-2016, 10:37 AM   #63
reaper71
reaper71's Avatar
On to the next project on the list...
Pic #1. These are the short rear doors that need some TLC. I had a small amount of patch work and several dents to deal with.
Pic #2. Front of doors, the tire carrier was removed (will have a bumper mounted swing mount) and more dents.
Pic #3. The large rear door (when top is on)
Pic #4. The backside of door after Epoxy,High build and blocking.
Pic #5. Front side. As you can see they were pretty beat up..
Mark...
Old 01-20-2016, 10:51 AM   #64
reaper71
reaper71's Avatar
Pic #1. 1st round of filler.
Pic #2. After blocking was done.
Pic #3. Front side all done ready for more primer.
Mark...
Old 01-23-2016, 10:55 AM   #65
reaper71
reaper71's Avatar
Pic #1. After blocking.
Pic #2. The final primer was shot.
Pic #3. Final primer and ready to pick up.
These will be the last pics for awhile till the customer gets the chassis back over to me so I can do final mock up and paint. Then start on assembly.
Mark...
Old 01-23-2016, 02:12 PM   #66
Advanced Design
Looks good!
Old 01-23-2016, 05:16 PM   #67
RockinKees
RockinKees's Avatar
Looks nice!
Looking forward to assembly
Cheers!! Kees.
Kool Guyz CC
Old 01-25-2016, 10:47 AM   #68
reaper71
reaper71's Avatar
Thank's me too..
Old 02-03-2016, 11:14 AM   #69
reaper71
reaper71's Avatar
So, I finally got the chassis back in the shop so I could get in final paint.
Pic #1. This is where I left off in Eastwood rust encapsulator.
Pic #2. Getting the frame prepped (wiped down with wax & grease remover)
Pic #3. After it was shot in Satin Black Enamel.
Pic #4. Another view, also showing the new shackles after unmasking.
Pic #5. And finally the rear calipers and steering box in the background.
Time to start assembly on most of the chassis.
Mark...
Old 02-03-2016, 04:13 PM   #70
RockinKees
RockinKees's Avatar
Let the build begin!
Cheers!! Kees.
Kool Guyz CC
Old 02-03-2016, 06:07 PM   #71
reaper71
reaper71's Avatar
And here we go!!
Pic #1.After getting the rear disk brakes on I then installed the braided lines. ( a bit longer than I would prefer but they work)
Pic #2. This was after the Shocks, braided lines,steering box,tie rod ends and stabilizer were installed.
Pic #3. A quick look at the rear setup.
Pic #4. The full roller ready for drivetrain.
Waiting on the transmission and transfer case to show up.
The customer is taking the body etc to Texas to have it coated on Monday so I will keep you posted on the progress.
This was all finished up this afternoon so we are real time..
Mark...
Old 02-03-2016, 07:04 PM   #72
Advanced Design
Always nice to see them coming together.
Old 02-04-2016, 10:42 AM   #73
reaper71
reaper71's Avatar
Yes I agree Doug!
Just wish it was mine that was finishing up!!
Mark...
Old 02-22-2016, 10:51 AM   #74
reaper71
reaper71's Avatar
So as we left off the chassis was all set for the drive train to be installed....
Pic #1. The engine ready to have the flywheel and clutch installed.
For those of you that has ever or will deal with a Company (Advance Adapters )
be advised to do alot of home work prior to using their products!! Nice pieces great quality (Hand's down the WORST instructions EVER produced!!) they do not explain things in detail...(give you a 500 word back story on the 5 speed trans being used) but not how or what needs to be modified.
Pic #2. Example 1. The output shaft pictured here is supposed to go into the (spud shaft in the new transfer case) New transfer case is 4 1/2" in depth
The O.E. shaft is 8" (they DO NOT tell you to remove the O.E back section to reveal the shaft pictured here. (had to call tech support #1)
Pic #3. Example #2. This is the spud shaft it measures 2 1/2" across I.D The O.E. measures 2" O.D. (Do Not tell you to cut anything) Call tech #2 to find this out
Pic #4. Here it is showing the O.E set up that needs to be cut at 4 1/2" the long sleeve reveals the larger splined shaft underneath (again does not explain this in the instructions) Black collar is the new 5th gear lock to be installed and does not explain this either call tech #3 to find this out.
Pic #5. This was after it was cut and new lock collar installed ready to be bolted to the trans.
What should have taken 1 hr or so took around 6 hrs do to lack of explanation.
OK Off my soap box...This may sound simple to others who have done this before but this was my first 5 speed mated to a transfer case setup.
Mark...
Old 02-22-2016, 10:57 AM   #75
reaper71
reaper71's Avatar
Pic #1. motor/trans and new transfer case all set in place for mock up.
Pic #2. Another view showing the new units and brackets.
Mark...
