#51 |
Re: Gertie, the 72 c10 Highlander
#52 | |
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
#53 |
I got my new buckets mounted. Also got my new ACC carpet from Rockauto.... and a new ForeverSharp steering wheel! About ready to start getting the interior wrapped up so I can get my vintage air installed before the Oklahoma heat shows up!
#54 |
#55 |
![]() Join Date: Dec 2012
I really dig the color combination.
Mike
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#56 |
#57 |
Got my new wheels and tires on!
#58 |
Are those 255/70r15s?
Looks great!
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#59 |
#60 |
Love this build. Your getting after it and inspiring me to get moving on the jobs that need doing on my truck. Top job.
John 69 c20, 396, th400, dana60, ps, ac |
#61 |
#62 |
Well this has been a slow process, as promised. I unfortunately did not beat the heat, so my project was on hold for most of the summer. But summer is over and work has resumed. I have still been working on the interior and getting the vintage air installed. Like most know a can of worms can quickly be opened, but a little harder to shut!
Worked quite a bit on the floor, getting as much of the rust as i could out without actually cutting anything out. I also work on sealing up the cab the best I could. The goal for now is to keep the inside dry! Some before pics... |
#63 |
Figured now was a good time to get my cab mounts replaced. I went with poly for longevity. I also had to cut out the spot welds on the bolts. I bought a Dremel to get into the small depression more easily. (Such an awesome tool!
#64 |
I used a combination of metal sealer, rubberized coating, and undercoating to seal any place that water was getting in. I then undercoated the entire floor and put down Fatmat.
#65 |
More pics...
#66 |
![]() Join Date: Feb 2011
Nice job on the build...I'm taking notes for my '72
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#67 |
![]() Join Date: Apr 2005
Nice job
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#68 |
Keep up the good work, it's looking good!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#69 |
#70 |
A few more pics of the interior... got the evaporator unit mounted under the dash and the duct work run. Also temporarily mounted my control panel.
#71 |
Decided to go ahead and pull apart the front end so i could access everything more easily as well as clean up a bit. Here are some progress pics...
#72 |
Had to do some rust repair work to my core support. Welded in a patch piece, cleaned it up, then spayed with undercoating. I then clean the whole piece and sprayed it with black.
#73 |
Cleaned up my radiator. Fixed as may of the bent fins as I could and sprayed it with some high heat paint.
#74 |
Also finished getting the Vintage Air installed. All I lack is getting everything wired up...
#75 |
Its been awhile since my last post so I figure its time for an update. I worked on getting my front end put back together after I roughly straightened out my drive side fender. Wasn't looking for anything perfect just wanted to knock the dent out.
