08-05-2019, 11:48 AM | #51 | |
Re: My 54 s10 build
Looks like some great progress. Are you not adding running boards?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
08-05-2019, 01:42 PM | #52 |
Re: My 54 s10 build
Gigamanx, I plan on running boards but I’ll have to trim them (height wise) to get them to fit under the cab. My test measurements show I’ll have to cut the part that spans the area between the flat part of the board to the rocker panel on the cab. It should be subtle and the folks who are hardcore into these trucks may only be the ones to notice.
my 54 s10 build |
08-05-2019, 09:25 PM | #53 |
Re: My 54 s10 build
For the bed I took some box tube cut to the width of the inside of the bed. Then welded legs to the bottom of the tube to bolt it into the original bed mount holes. I need to make the ones for the front and back once I decide on what I want to do for a floor. I connected the tube with angle iron the length of the bed to make a frame and slid the bed sheet metal over it. With the notch being tall, I’ll make the floor eventually flat across. The bed won’t be very deep but that’ll be ok.
my 54 s10 build |
08-10-2019, 02:51 PM | #54 |
Re: My 54 s10 build
looking very flat!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-18-2019, 08:01 AM | #55 |
Post Whore
Re: My 54 s10 build
awesome bullnose
05-28-2020, 10:36 AM | #56 |
Re: My 54 s10 build
Great build !!!
Is that a Thorbecke Bros 4 link kit ? |
05-28-2020, 07:28 PM | #57 |
Re: My 54 s10 build
Thanks man. Yep it’s thorbecke’s s10 bolt in kit that deletes the original gas tank. The bridge notch kit is from him as well. It’s a really nice setup. I couldn’t be happier with how it came out. They don’t call him the “s10 Jesus” for nothing. Haha.
my 54 s10 build |
05-28-2020, 07:37 PM | #58 |
Re: My 54 s10 build
As always life kinda gets in the way and haven’t been able to post much but I have got some things done. Running boards are on and now it really has a hovercraft look. I simply took some rectangular box tube and built basically a nerf bar, then bolted the crusty running boards to them.
my 54 s10 build |
06-11-2020, 10:13 PM | #59 |
Re: My 54 s10 build
I wanted something simple for the bed floor. Something not too expensive and something that could be used without worry. I decided, for now, to use some 2x6s in white pine stained with some Thompson’s weather sealer. They were laid out and braced on the bottom as one removable unit. The bed floor isn’t very deep but I like having the flat floor instead of having the notch sticking out of the middle. I put a large piano hinge on the front so you can lift it up to service the rear suspension/air system from the top. It’s super simple and I like the way it came out.
my 54 s10 build |
06-12-2020, 02:06 AM | #60 |
Re: My 54 s10 build
bed floor came out nice, I like the hinges
06-12-2020, 08:44 AM | #61 |
Re: My 54 s10 build
Not bad for a bed. You can always upgrade later and attach to the same piano hinges. Looks a lot better than my plywood 4x8 bed haha...
06-12-2020, 11:02 AM | #62 |
Re: My 54 s10 build
Thanks guys. The hinge idea was always in the plan. I'm getting too old to be crawling all around on the floor constantly to fix things. I tried to do as much as I could to make things serviceable from the top.
my 54 s10 build |
06-18-2020, 10:48 AM | #63 |
Re: My 54 s10 build
06-18-2020, 08:03 PM | #64 |
Re: My 54 s10 build
Thanks man. Looking back I kinda slacked on taking a few pics with it out of the truck. It’s pretty simple really. The hinge is from McMaster Carr and I believe it’s a 3 inch piano hinge. Meaning 1 1/5 inch on either side. The 2x2 on the leading edge is bolted to the front of the bed with 4 bolts and the hinge screws to that. You can take the entire floor out just by unbolting the front edge.
my 54 s10 build |
