01-05-2016, 04:26 PM | #51 | |
Re: 5 day ls swap...can it be done
Things are looking good . |
01-05-2016, 04:38 PM | #52 |
Here is one of the testers i built to pulse the injectors.
https://youtu.be/tGueD00e4WU Built a better programmable one this fall.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
01-06-2016, 01:15 AM | #53 |
Good news, I got the engine to fire for a few seconds with some starting fluid. I took off the fuel rails and there was definitely some nasty gas in there. So I removed the injectors and they're soaking. Hopefully this will work!
01-06-2016, 11:04 AM | #54 |
Search youtube for homemade fuel injector cleaners. Pretty easy to make with either a large syringe from the pharmacy or a valve stem with the core removed.
01-06-2016, 01:27 PM | #55 |
I built a harness rig with a 12v wall transformer to cycle injectors. Just a push button and an EV1 plug. Had some nasty gummed up injectors on my old TPI swap.
01-06-2016, 02:38 PM | #56 | |
Luckily I have a injector plug, so it should be pretty easy |
01-07-2016, 12:49 AM | #57 |
Good news: I got the injectors cleaned and they seem to be working good.
Bad News: I tore 2 o-rings trying to install them back into the fuel rail at 9:55, so I didn't have time to run to the parts store to get new ones tonight. Hopefully tomorrow night will be the night it will run on its own! |
01-08-2016, 07:48 AM | #58 |
i use a small dab of grease on the orings when re installing them. have not tore one in 25+ years and injectors slide right in.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
01-08-2016, 10:01 AM | #59 | |
Good news: The engine fired up and runs https://www.youtube.com/watch?v=4sPBHONcfyo Bad news: it seems the thermostat is stuck closed. I put 1 gallon of coolant and about 3/4 of a gallon of water in the radiator a few days ago, and once I started it up, the level didn't drop as I was expecting. Watching the temp reading on the computer, it got plenty hot that the thermostat should have opened. So I got another task to take care of before its maiden voyage. It also idled really high (1700 rpms) for quite awhile, and then finally slowed down once. I looked for vacuum leaks, but didn't find any. I'm kinda thinking the computer is doing something. I also need to do some additional tuning, as I didn't turn off any of the emission stuff that I don't have, so I get all kinds of DTCs.
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 01-08-2016 at 10:16 AM. |
01-08-2016, 10:19 AM | #60 | |
These things are not like the small block days . |
01-08-2016, 10:22 AM | #61 |
Might be airbound....all stock cooling in the truck right? Took a few days of the truck just sitting for the air to bleed out. Basically I filled up the rad and ran the truck a bit, it did get real hot once. Refilled the rad and then just kept adding fluid to the overflow tank. It would bubble into the tank by itself and I needed to keep refilling the tank until the engine bled itself. I'm sure the pros on here have a faster method.
01-08-2016, 10:23 AM | #62 | |
01-08-2016, 11:56 AM | #63 | |
01-08-2016, 11:59 AM | #64 |
Turn your camera sideways next time. Sounds good. If will burp air but its best to fill block before startup. I remove top radiator hose at radiator and fill block till it runs out of radiator.
01-09-2016, 01:27 AM | #65 |
Filled the engine with coolant through the upper radiator hose and it works now! Thanks for the suggestion.
I also figured out the high idle issue: the tab on the throttle body was bent, holding the TB open at 3%. Bent it back a little and now it idles about 600 RPMs. I have to change out the gasket between the transfer case and tranny, connect up the fans, and the VSS, and then I think I'm ready for a test drive. |
01-09-2016, 09:39 AM | #66 |
Nice job on the swap. How did you download a tune to the pcm?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
01-09-2016, 10:10 AM | #67 |
Great!
5 days, right on schedule. Good job. My latest 5 day project has turned into almost a 2.5 year project. Important stuff in life gets in the way of projects. He used hp tuners software.
01-09-2016, 10:31 AM | #68 |
Congrats good job!
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
01-09-2016, 02:03 PM | #69 | |
At this point my tune is a stock tune with the DTCs turned off for the crap I don't need and VATS turned off. |
01-11-2016, 01:13 AM | #70 |
I got the transfer case input seal changed as well as one of the rear wheel cylinders that was leaking changed. Added some tranny fluid, connected up the VSS, and went for a cruise tonight (no fans needed when its 22 out )
So I drove it pretty easy initially, and didn't really have any problems. I made it to town (about 5 miles away) and it was idling pretty low, so I tweaked my tune real quick to have it idle at 600 rpms when warm and came back to the house. Added a little more tranny fluid, and took it for another spin. This time I got on it a little more. This engine has way more power than the 454 had (which isn't saying a whole lot....). I did notice that the tranny shifts at 3500 rpms which is right when the LS engines start taking off; I'm hoping once I have the kickdown switch hooked up I'll get some more RPMs out of it. I got out on the interstate and up to about 85. The engine just purs along about 3500ish rpms just happy as can be. Then I headed back home. One thing that I did notice, my speedo and speedo on HPtuner is not working any more. I'm wondering if when I took out the TC if I got some dirt in the connector so its not getting a signal any more. I'll have to check that out. The TC was filthy dirty from probably years of leaking and driving down dirt roads. I probably removed 10 pounds of oil mud cake from the TC skid plate. So left to do includes the fans and mounting/hooking up the AC compressor. I'm planning to use the compressor off the 454, so I'll have to come up with a custom bracket and do something with the belt tensioner. I also will probably change the alternator, it sounds like poo, like the bearings are shot (its still charging). I guess I'll check on the price, and maybe I can replace the bearings in it. Oh yeah, I also need to figure out something with the temp gauge. I've just been using HPtuner while I've been driving around. Otherwise, I have some stuff to take care of on the truck itself: New interior door handle, new door locks (I don't have a key for them), passenger seat belt, fix some of the wiring on the front axle (not sure if 4wd is actually engaging). So it took me a little longer than 5 days, but overall, I would say that I swap into a 88-98 chevy pickup has to be about the most straight forward LS swap there is. |
01-11-2016, 08:32 AM | #71 |
Use a 98 Camaro temp sensor. Two wires to PCM and third goes to dash gage. No mechanical mods needed. If you use a spare TPS pigtail to your harness, it will plug into sensor but be sure to use correct wire connections.
01-11-2016, 10:00 AM | #72 |
Glad to hear its better than the old 454. I just bought a 2003 truck with a 4.8 to swap into our 1968 suburban this spring in place of the original 327. I was hesitant to use a 4.8 but after reading about them there not a lot of a difference between the 4.8 and 5.3.
Have you played much with the governor spring and weights on a T400 ? That's the best way to tune shift points pretty easy as well.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-11-2016, 10:12 AM | #73 |
You could also take the gauge temp sender from the 454 and turn it down then thread for 12x1.5 mm and put it in the passenger side head, worked pretty good on my swap. I even bought 12mm copper washers to seal it. Dash gauge reads right in the middle (210) when engine is up to temp at 190.
01-11-2016, 04:02 PM | #74 | |
I haven't done anything with the transmission, so we'll have to see. And quite honestly I have never messed with a non-electronically controlled transmission other than taking them in and out.....just another thing to learn. |
01-11-2016, 05:33 PM | #75 | |
The Older Generation
LockDoc
