Old 08-22-2016, 09:37 PM   #1
jeh
jeh's Avatar
Re: '67 K10 swb big block "The Mutt"
Looks like a busy summer, also some awesome sunset pics!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 08-22-2016, 10:45 PM   #2
tommys72
tommys72's Avatar
That's a lot of field there in the pics
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-22-2016, 11:19 PM   #3
BlueBullet
BlueBullet's Avatar
Looks like a lot of fun!!
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 08-28-2016, 11:38 PM   #4
JMD
JMD's Avatar
It was the best decision I ever made! Had way too much fun, met some amazing people, saw some beautiful country, and got paid to do it
Haven't gotten very far on the truck at all unfortunately. I'm in the midst of moving, starting school, and starting a new job but I did manage to get the fuel tank cleaned up and bolted down. Slow and steady wins the race right?
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 09-13-2016, 12:38 AM   #5
JMD
JMD's Avatar
Been making some slow but steady progress lately, mostly just waiting on parts. Today I got the guage cluster installed and started laying out the wiring, I can't wait to see how this Dakota Digital stuff works!
Old 09-14-2016, 08:37 PM   #6
jeh
jeh's Avatar
I think your really gone to like the Dakota Digital stuff!!!!!
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 09-25-2016, 12:15 PM   #7
NewType72
NewType72's Avatar
Wow does that polar pedal ever look nice and clean in there. Great stuff subd for sure
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-25-2016, 05:53 PM   #8
JMD
JMD's Avatar
It's a very nice product! The only gripe I have with it is that it was advertised as a bolt on assembly that wouldn't need firewall modifications...Not entirely true but oh well.
Old 09-26-2016, 01:41 AM   #9
JMD
JMD's Avatar
Exclamation Re: '67 K10 swb big block "The Mutt"
Went through the heater controls today and ended up replacing the heater core and a few seals. I'm happy with the way the way the temp control faceplate turned out considering what I started with.
Old 09-26-2016, 11:43 AM   #10
NewType72
NewType72's Avatar
Trust me we fought that with a porterbuilt front dropmember product we got. I'd much rather fight a gasp pedal at this rate lmao
- Dylan
(209)-985-7721
Old 10-15-2016, 10:53 PM   #11
JMD
JMD's Avatar
No huge progress but I did spend a solid 6 hours trying to install an oil pressure sending unit. I had to remove the oil galley plug on the front of the engine and of course I stripped the allen head out. I was thinking I would have to pull the engine and drill that sucker out but luckily an easy out did the trick! I was pretty nervous for a bit though.
Also installed power steering lines and the drag link. Apparently there's no good way to hook up a 75' power steering pump to a '67 gear box so I'm stuck with this contraption for now...it'll work but it sure is ugly.
Old 10-24-2016, 09:09 PM   #12
JMD
JMD's Avatar
Was going to spend the weekend finishing up the wiring but got sidetracked...For the life of me I couldn't figure out why I had a constant 12 volts to both sides of my brake light switch. After a lot of head scratching and foul language I found that my new steering column was shipped with the hazard switch in the "on" position which was causing all of my issues
In order to turn the hazards off I had to install the button, which led to installing the turn signal lever, steering wheel, and shift linkage...And then it was time to shut the shop down for the weekend. Oh well, guess the wiring will have to wait until next weekend.
Old 11-26-2016, 02:32 PM   #13
JMD
JMD's Avatar
Lots happening with this build, finally got it running! Unfortunately the PO didn't know the difference between an internally and externally balanced engine, and I didn't bother to check Boy does that make a difference! So I got the pleasure of dropping the transmission and installing a balanced flywheel and damper.
Also had 2.5" dual exhaust run to a pair of Flowmaster 50 series mufflers. I'll get the tailpipes installed once I know where the bumper and hitch will fall.
Old 11-26-2016, 02:38 PM   #14
JMD
JMD's Avatar
Now that it moves under its own power (for the first time in 4 years!) I was able to get it on a trailer and over to the body shop. Here we are test fitting the new hood.
Old 11-26-2016, 02:53 PM   #15
JMD
JMD's Avatar
Unfortunately the aftermarket hood and fenders are, well...garbage. The drivers side lines up ok after a good amount of grinding, welding, and "persuading", but we were unable to get rid of the 1" gap between the front corner of the hood and the drivers side fender. There is also a sizable depression in the hood where it meets the cowl. About 1/4" low. I am in disbelief. I'm currently waiting to hear back from my supplier to see what can be done but I'm not gonna hold my breathe.
Old 11-28-2016, 01:56 AM   #16
JMD
JMD's Avatar
Started assembling the bed. Again, pretty disappointed by the fitment of this aftermarket stuff. Lesson learned I guess.
Old 01-20-2017, 01:04 AM   #17
JMD
JMD's Avatar
Doors are done! Feels good to be over that hurdle.
Old 02-02-2017, 12:50 AM   #18
JMD
JMD's Avatar
Moving along on the front clip. Finally found a hood and a pair of '68 fenders that were in ok shape. Took a bit to get them straight, but they fit much better than that repop crap. It amazes me how much work goes into painting a truck.
Once again I wish I would have spent a little more time and money finding OEM parts. Putting the internals of the doors together was a nightmare. It would have been WAY cheaper to buy a pair if beat up OEM doors, cut the rust out of them, and patch them up than it was to make this aftermarket junk fit nice.
Old 02-02-2017, 12:54 AM   #19
JMD
JMD's Avatar
Here's a prime example of the poor quality contol practices of the aftermarket industries. This picture is looking down at the top of the core support where the upper radiator clamp mounts. See anything wrong with the location of the holes?
Old 02-03-2017, 03:15 PM   #20
DeepOceanStepside
DeepOceanStepside's Avatar
Just ran into the same issue on my aftermarket core support...i dont know why the heck they do that.
1970 Base Step Side Dark Olive 250 3ott restoration
1972 k5 4x4 250 3ott project
1970 long bed light olive 283 th350 driver SOLD
DeepOceanStepside is offline   Reply With Quote
Old 02-04-2017, 10:28 PM   #21
JMD
JMD's Avatar
Who knows. The first aftermarket core support I had on the truck was really for a 69-72, but it fit perfect. Then I switched to a correct one from the same company but the holes are all out of whack. The only difference I can think of is that I bought the first one about 4 years ago... Maybe quality control was a lot better back then.
I had some undercoating sprayed in the doors and on the floor pan, both inside and out. It's supposed to provide some sound deadening. Also did the final fitment of the front clip minus the hood. Hopefully we'll get to the hood tomorrow and then it's on to paint!
Old 02-18-2017, 10:38 PM   #22
JMD
JMD's Avatar
It was a beautiful day to work on the truck today!
Old 03-10-2017, 12:50 AM   #23
JMD
JMD's Avatar
Finally home!
Old 03-10-2017, 06:38 AM   #24
GR8-68
GR8-68's Avatar
Wow !!! This is looking great
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-11-2017, 04:50 PM   #25
StanleyRosiello
StanleyRosiello's Avatar
Badass rig man. With everybody going super low with these truck (to each his own... and I still love these trucks low or high) its refreshing to see a guy with his truck riding high. Can't wait to see it finished.
StanleyRosiello is offline   Reply With Quote
