Old 01-18-2016, 07:40 PM   #51
slowcpe
slowcpe's Avatar
Re: LSx bang for your buck. Whats the best value?
I'm building a similar setup now. Here's the numbers I have (so far):
50k mile LQ4, 4L80e, computer, wiring harness and most accessories $1500 (a GREAT deal in my area)
243 truck heads w/8k miles $350
BTR valve springs, trunion upgrade, lifters, push rods, oil pump, timing chain $800 (approx)
BTR cam (haven't decided but probably Stage 3) $400
If I went this route about $800 for a good converter (but I have since sold the 4L80e in place of a T56)
Need for 400-450 whp: larger injectors, headers, mill heads, port heads (maybe), intake (mainly for looks), and finish off accessories.
Add all that up and a 6.2 might make sense if you don't want to fool with heads/cam or keep the 6.0 shortblock and add the L92 top-end setup. I personally would consider the latter but I've accumulated too much stuff already to stray from the cathedral setup.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-18-2016, 09:45 PM   #52
jessemthompson
I have an 07 5.3 (the 315 hp gen 4) with headers, exhaust and a spectre intake tube with a black bear tune and it blows the tires off my truck in first and second gear. Idk how in the world it would hook up with 450 horsepower.
jessemthompson is offline   Reply With Quote
Old 01-18-2016, 11:51 PM   #53
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Originally Posted by N2TRUX View Post
Lets look at another angle, stock vs modded cost. Lets say a 6.2 cost 4000.00 and a 6.0 cost 2000.00 (again just theory) If you add headers and a tune ONLY to the 6.2, how much HP would you net? What mods, and how much would you spend to get the 6.0 at to same HP?
cam would be the equalizer....well that and heads.
My SS has an LS2 which is a genIV aluminum 6.0 but with cathedral port heads (243's) and it makes 395hp/400tq with stock cam/manifolds/heads/tune. An LQ4 with LS6 cam and a tune would do about the same. The LY6 in my '68 is like a genIV LQ4....an iron block 6.0 (with VVT which is cam based and easily removed) but with the L92/LS3 rectangular ports. LY6's are rated at like 365hp before mods.
there will be those that disagree but I feel thats the best "bang for your buck performance choice" (below something with more displacement)...would be a 6.0L (iron or aluminum take your pick) with the big port L92/LS3 heads....and cam of your choosing.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-19-2016, 03:17 AM   #54
Cobalt964ruf
Cobalt964ruf's Avatar
L33 5.3HO aluminum block with less than 10k miles on it, ls2 cam and springs, longtubes, and a tune 450hp. $1800.00. L33 5.3ho comes with flat top pistons, and 243 heads stock. the l33 responds very well to the ls2 cam and springs. did this build a couple years ago. now l33's are ridiculous prices. so i have been hording l33's and lm7's for awhile now. have 14 at last count.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 01-19-2016, 12:23 PM   #55
First c10
First c10's Avatar
Originally Posted by cobalt964ruf View Post
l33 5.3ho aluminum block with less than 10k miles on it, ls2 cam and springs, longtubes, and a tune 450hp. $1800.00. L33 5.3ho comes with flat top pistons, and 243 heads stock. The l33 responds very well to the ls2 cam and springs. Did this build a couple years ago. Now l33's are ridiculous prices. So i have been hording l33's and lm7's for awhile now. Have 14 at last count.
did you say 14 ???
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-19-2016, 12:54 PM   #56
jrblanke
I didn't read through the 2nd or third page, but I can share what I have spent on my engine so far on my swap.
I purchased a wrecked 06 trailblazer with the LH6 for 1800. On top of that, here is what I have purchased.
Eliminate the DOD equipment -$550
Vinci trucker camshaft, valve spring kit, push rods - $900
shorter oil pan kit - $200ish
Trailblazer I6 converter - $160
Oil pump, timing set, front/rear cover gaskets - $250ish
My engine came with headers from the previous owner, and I am not upgrading the intake.
I would also recommend finding a 4l80, and dont spend the time/money upgrading the 4l60e. It seems the more I read about them, the more I wished I had waited for a 4l80 2wd. I am converting my 4l60e from 4wd to a 2wd and figured while I had it apart, it would be a shame not to upgrade common failure parts like 3-4 plates/discs, sunshell, etc. I'll have $$350 in the trans before i'm done, and I'll still have a 4l60e.
It seems to me that the cheapest engine would be a non VVT or DOD engine with the 4l80e.
jrblanke is offline   Reply With Quote
Old 01-19-2016, 02:44 PM   #57
jrblanke
I also wanted to add that it seems that the Gen IV rewire and wire harnesses and tuning are more expensive than gen III.
Old 01-20-2016, 06:11 AM   #58
Cobalt964ruf
Originally Posted by First c10 View Post
did you say 14 ???
yes lol
Old 01-20-2016, 02:52 PM   #59
PowerdbyChevy79
PowerdbyChevy79's Avatar
I can get a 5.3 engine,tranny,harness,pedal for about $1800 from a wrecked Silverado..well I heard that an 5.3 with cam,243 heads and a tune will get you 300 to the ground,..for 450 you will need heads for sure..ive seen cam packages go for $600-$1000 depending where you get it (parts only) now lets say your'e going to put all that in a engine that has 50k miles,80k or 100k miles.....so then we talk about rebuilding the engine..whats that another $1000-$2000 depending who rebuilds it..so were pushing 5kplus...for a 5.3....now looking for a 6.0 or a 6.2..i can get one (out of a wrecked car) from $3k-$5k engine, harness,tranny,pedal...and you will need a tune for sure and maybe a cam for 450...then we talk about the miles again.. are you going to want to put money in a possibly high milege car that been hotrodded..cause you know they have been..especially a GTO, ..a crate LS3 with 480 at the flywheel will run about 8k...easy to say but look at everything..i just bought a 5.3/4l60e for my 89.. im just going to stab it in and drive it as is..it will be a daily..now for my 63.. im wanting a LS with some power and ive been doing my research and more and more im leaning towards a crate engine..yes its costly up front but all the hard work is done I wont have to open an engine or notjing..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-23-2016, 08:01 PM   #60
roundhouse
around Atlanta theres several wrecking yards that sell 5.3 with harness and computer, for $650 and you can hear it run before they pull it
what yall ought to be hording is the old 350s a good running roller cam 350 will easily bring more $$ than a 5.3 now.
roundhouse is offline   Reply With Quote
Old 01-25-2016, 11:01 AM   #61
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats seems to be below average for a 5.3, but closer to what a used motor should be.
I see no reason to stock up on 350s. I can be a cheap crate motor if I need one.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
