02-04-2016, 01:39 PM | #51 | |
Old member
Re: I waited
02-04-2016, 01:56 PM | #52 | |
Re: I waited
My wagon is the first vehicle i have installed air ride on. You can find the whole build thread in the alternate section. I went straight for a full blown accuair elevel setup with 2 tanks 2 compressors etc. Functionality it is awesome to just tap a button and it goes straight to ride height and dont have to worry about it. The install definitely took some time and patience to get it right. My 2nd car i put air ride on was a very simple manual valve setup from ezair ride on my brothers 64 chevelle. Much more simple to setup and the speed of it is quicker than i was expecting. Bottom line as with any parts for our rides is you get what you pay for and a well setup system using less complicated parts can sometimes be the best. As mentioned above if you simply replace your springs with the air springs and do not either cup the lower arms or go with drop spindles and blocks in the rear you truck will not be able to ride very low and it will also not air out very low when you drop all the air out. I am happy to help or answer questions based on my limited experience with air ride. |
02-04-2016, 02:10 PM | #53 | |
Re: I waited
02-04-2016, 04:15 PM | #54 | |
67-72 parts collector,…
Re: I waited
Only ride height sensors. If you are just using the VU4 valve manifold and Speed Switch controller,... you should add gauges to monitor your air pressures.
02-04-2016, 08:33 PM | #55 |
Old member
Re: I waited
The SwitchSpeed kit,
was the one I was looking at. It has the presets correct so you can learn the settings and just hit the buttons I thought. I could run the gauges I guess but was hoping to not have to. I could mount them out under the bed cover are some where besides the cab!
02-04-2016, 08:51 PM | #56 | |
Re: I waited
02-05-2016, 12:09 PM | #57 |
Re: I waited
Andy,
I ran my air lines for gauges into the cab using an existing hole in the firewall. See attached pictures. I've circled the hole I'm using and I circled the lines coming into the cab as they are now. I removed the existing grommet and replaced it with one with a larger ID. No new hole required. You might be able to remove the clutch cover and run them in there too. I'm not sure without looking if that would be a good location or not. But trust me, you'll want to be able to see your gauges as your driving. That way you'll know if there's a problem, and you can add or remove air to adjust the ride accordingly. - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
02-05-2016, 12:38 PM | #58 | |
Old member
Re: I waited
The house contract was signed by all the parties this morning so the house buying will be going through I guess and hope will know something by the end of this month.
02-05-2016, 01:02 PM | #59 |
Re: I waited
I am pretty happy with my AirLift AutoPilot V2. I still have air lines in the cab because they were there from my DLoe valve setup and I wanted to mount the valves inside the cab out of the elements. It works in automatic or manual mode, allows me to rise to a particular pressure each time and I can view/modify the pressure on the control pad.
With the switchspeed and no gauges, I am not sure how you would know you are at ride height. It looks to me like the presets aren't for pressure, but for valve speed to adjust how the bags fill. More than once I overfilled my bags using the manual setup because of lack of speed control. |
02-05-2016, 03:45 PM | #60 | |
Old member
Re: I waited
02-05-2016, 04:05 PM | #61 |
Re: I waited
02-06-2016, 03:01 PM | #62 | |
Old member
Re: I waited
I finally drove it to work today. I got the air fittings all leak free to the front helper bags yesterday and tied into the dual gauges.
02-06-2016, 11:56 PM | #63 |
Re: I waited
Hey Andy,
Cant wait to see your truck sitting low. Post some pics when ya get 'er eating weeds.
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
02-07-2016, 09:00 AM | #64 | |
Old member
Re: I waited
you know I will! I don't know about eating weeds but I hope it looks better than now.
02-07-2016, 01:12 PM | #65 |
Re: I waited
hey Andy4639. Hit me up when you get a chance. I just read this thread today and I wasn't aware you so many questions. Ill help you as much as I can.
