#51 |
Re: Bagged 65 c10. AKA the periwinkle pile
Keeping the stocker in the cab for now
#52 |
Started on the raised bed floor. 1x1 square tubing
![]() Also made a flip down door for behind the tailgate. The accuair vu4 manifold and harness will be behind the air tanks so access will be easy with the door. Im also gonna make a "hatch" door in the bedfloor above the air tanks where the large opening is so everything is very accessable ![]() ![]() ![]() |
#53 |
damn... I love this thread.
I think I could spend hours looking at your welds lol I weld MIG and TIG...sometimes come out well, sometimes look ****. Need to practice loads more to get to where you are. keep those photos coming!
My 65 stepside build/work on thread - http://67-72chevytrucks.com/vboard/s...d.php?t=693138 |
#54 |
Really digging this build.. Great job!!
#55 |
Photobucket was being tempermental lately but heres the progress
Had to slice the bedfloor in half to get it out of the truck to totally finish weld it. No pics of it finished, but its all welded back in for good now ![]() Fabbed up some rear shock mounts ![]() Upper shock studs ![]() And a pic with the shocks installed ![]() I had originally planned to mount the vu4 between the air tanks but changed plans. I made this bracket and utilized three factory hole in the rear crossmember to mount it ![]() ![]() ![]() Also decided to run some bulkheads to hide the airlines through the framerails ![]() ![]() ![]() ![]() Then i moved onto the rust to fix the rear horns ![]() ![]() ![]() ![]() ![]() And last but not least added a few more fish plates today. My welder was being a pain in the rear, just a bad day i guess, wire kept jamming so i couldnt run a constant bead on the whole thing. Ill dress some spots with a grinder before paint ![]() ![]() |
#56 |
I'm just glad to be here!
Nice job!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#57 |
Nice fab, and frame rust repairs.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram ![]() |
#58 |
Nice progress.very cool.thinking it out 2 - 3 time's or more .
The Snortin' Bull |
#59 |
![]() ![]() Join Date: Oct 2011
Very nice work and great pictures!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#60 |
Looks really nice. Gives some motivation for my next project!
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
#61 |
Thanks guys, appreciate it
#62 |
A guy with a truck
Nice fab work here.
In regards to your steering shaft: could you get away with using a single shaft from rack to column?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#63 |
Gringo, the upper a arm becomes a clearance issue at full drop when i tried to mock up a single shaft from rack to column
#64 |
Well guys back at it. I fabbed up some perches on the frame rails for front bed mounts. The stock rear mounts are still utilized. Heres some pics of the perches, i didnt get pics of the mount structure tied into the raised bed floor. Ill get those pics tomorrow
![]() ![]() Then we rolled the truck out and got a look at it with all the sheetmetal mocked up finally. Super pumped with how its turning out ![]() ![]() ![]() ![]() |
#65 |
Looking good!
#66 |
Heres some pics of the fromt bed mount structure. Bolts need to be trimmed
![]() ![]() The original wheel tubs in the bed were shot so my buddy ordered a new pair. As you can see in these pics they were a tad tall due to the raised bed floor haha ![]() ![]() Sectioned them 4 inches. Tacked up with the mig ![]() ![]() ![]() After i tacked them with the mig i decided to give the tig a try. I bought a 210 syncrowave and am just teaching myself tig. This is my second time welding sheetmetal and my first full panel ive attempted to tig ![]() ![]() I should be able to body work it a tad more and get away with no filler at all. Im pretty pumped |
#67 |
Metalwork looks killer
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#68 |
My buddy installed the porterbuilt gas assist hinges he ordered. I still need to weld the bracket to the underside of the hood
![]() The bed wheel wells are about 99% done. Im pretty pleased with how they look bare metal for my first time tig welding an entire panel. Should be able to get by with some high build primer and no filler ![]() ![]() Last edited by greengrenade; 06-13-2016 at 01:26 AM. |
#69 |
Looking good man. I started tigging my sheet metal and I'll never go back.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#70 |
Yea its much nicer than mig. The ability to hammer and dolly a tig weld makes the finished product so much nicer
#71 |
A guy with a truck
Super nice work. I need a TIG
#72 |
. Nice work on this one! . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
#73 | |
#74 |
Johnny im using 3/32" 2% lanthanated tungsten. Im new to this so im no expert. Check out jody on youtube, weldingtipsandtricks channel. He swears by the 2% lanthanated for most all applications. At least any application we would ever need. I was running around 55 amps max for the 16ga wheel wells but your foot controller will help you dial it back when needed
#75 |
Got the hood on and shimmed up right with the porterbuilt gas assist hinges. I gotta say for the price my buddy payed for these hinges the stainless hardware left a lot to be desired. Pretty poor quality. We switched everything to grade 8 hardware
![]() Whipped up this battery tray out of some angle iron and flat stock ![]() And mounted it on the core support ![]() ![]() |
