07-11-2016, 10:14 AM | #51 |
Re: Door panels 67-71
Subscribing, may need some light green for my 69 soon.
07-11-2016, 05:28 PM | #52 | |
68 C 10
Thanks Kevin
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
07-11-2016, 05:38 PM | #53 |
$100.00 , that covers the extra cost . Still way below anywhere else . Grumpy
Pm sent .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-12-2016, 05:24 PM | #54 |
Ttt
07-13-2016, 05:25 PM | #55 |
Ttt
07-13-2016, 05:39 PM | #56 |
How about red door panels for a 69 Chevy 1/2, could you make those? Would they have the water proofing/backing? Let me know as I'd be interested in a pair of door panels in red.
"If you aint first your last!!" 1969 GMC C1500 Stepside Shortbed - daily driver Mando |
07-13-2016, 11:01 PM | #57 |
Can I get a quote on a dark green metallic set of door panels, a dash pad cover and a bench seat cover with the hounds tooth inset? Thanks
07-13-2016, 11:18 PM | #58 |
Yes , they would have sewn pleats on high quality sew foam mounted on waterproof door board . $100.00 + shipping
07-13-2016, 11:24 PM | #59 |
[quote=TBohne;7652593]Can I get a quote on a dark green metallic set of door panels, a dash pad cover and a bench seat cover with the hounds tooth inset?
hounds tooth and dark green metallic and I would recover your visors to match the rest of the new interior .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-14-2016 at 03:53 PM. |
07-14-2016, 05:32 PM | #60 |
I'm totally happy with my door panels!! They are what I thought LMC's would be when I ordered from them.. LMC's are one piece PLASTIC and I would have to shave off some bottom for them to even fit!
Thanks GRUMP |
07-14-2016, 05:34 PM | #61 |
No problemo ! Glad your happy with them .
07-15-2016, 07:06 PM | #62 |
Interior kit
seat covers door panels french seamed dash cover recover your visors .............. $400.00
07-16-2016, 12:51 PM | #63 |
Would you be able to do something like this?
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
07-16-2016, 01:49 PM | #64 |
No problem , I've been building interiors for almost 40 years for a living , that seat pattern just uses a little more material with the double horse shoe inserts you can see the outer panel go's completely across the seat so the pattern has to be cut up the roll of material instead of across the roll ,also it has double French seamed stitching on the outer edge which takes longer to sew .
I suggest some type of seat insert stitching ( it makes them stronger and last longer that's why Chevy did it ) Seat cover sewn on high quality 1/2" backed sew foam Door panels in that design (door panel design would need to be adjusted if your using armrests ) A double French seamed dash cover to match seat stitching Recover your visors to match double stiching New hog ring pliers and hog rings to install cover New door panel screws You pick materials within reason $600.00 in real leather add $300.00 Search albrightssupply.com for material samples and colors .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-16-2016 at 05:30 PM. |
07-17-2016, 01:02 PM | #65 |
ttt
07-17-2016, 05:54 PM | #66 |
Grumpy, I have replied PM on Dodge Buddies.
07-17-2016, 06:25 PM | #67 |
07-17-2016, 06:33 PM | #68 |
Back to you
07-17-2016, 06:51 PM | #69 |
do you make panels for the rear door and fake door on a 1971 suburban?
07-17-2016, 07:21 PM | #70 |
Sure, I don't have a burb here but I can run over to the chevytruckfarm and use one of his for the patterns . He had a few he's parting out that still had doors
07-17-2016, 07:35 PM | #71 |
I would like a set in black, just let me know how much and how you would like payment.
Gary McGinnis 2096568861 gary@gwmcginnis.com |
07-18-2016, 07:28 AM | #72 |
07-18-2016, 10:00 AM | #73 | |
07-18-2016, 11:12 AM | #74 |
I have a 68 Burb and would also be interested in a full setup if you can swing it.
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
07-18-2016, 12:58 PM | #75 |
Sure let me get a full set of patterns for the burbs and I'll get back to you .
