12-12-2003, 09:57 PM | #51 |
Just one question--how are you going to get it to hookup so you can use all that HP? Can't get my 502HO to hook with a 3.08 Posi.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
12-12-2003, 10:48 PM | #52 |
502
Sorry to hear about all your trouble. I have had a ZZ502/502 in my truck for four years now and could not be happier. It ran great right out of the crate and seems to be getting better with age, I did however get rid of the Holly carb it was a pain in the neck.
1971 GMC 1/2 ton 502/502 th 350 3.73 posi headers GM coral Ice pink Calgary Albeta Canada |
12-12-2003, 11:39 PM | #53 | |
I do have to change the rear tires and put a posi in it....that will happen this year.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
12-12-2003, 11:43 PM | #54 | |
Re: 502
I am really very excited to get the motor back...or should I say dynoed as well. I wouldn't be surprised to see 650 out of this thing....that would be great.
12-13-2003, 02:09 AM | #55 |
Shore is fun trying to get traction. I got the 850 vac. sec. carb on mine that GM sells. Runs fine -only changed the secondary spring(put one of the easy change kits on). Only problem with my motor is oil usage-1qt every 300 to 400 miles -no smoke anytime-no leaks but still goes some where. This is not a big problem with me as I have had it 3 years and only have 6,000 + miles on it. Oil usage has not changed from day one. Pace & GM says low tension oil rings--right. Still would buy another (572?). Good luck on your motor.
12-13-2003, 09:58 AM | #56 |
Thanks jhow. I can't wait to get it finished now. I heard about the oil usage...I didn't seee much with mine but honestly I didn't get a chance to drive it that much. It should be fun.
12-14-2003, 02:38 PM | #57 |
Yeah baby!
What carb would you guys recommend?
11.37 @116 |
12-14-2003, 03:05 PM | #58 |
carbs
If you are just using it for the street use the one GM reccomends--850 Holley with vac sec. part # 0-80531. They sell it. If you want a little more try the Street Avenger 870 Part # 0-80870.
12-14-2003, 03:07 PM | #59 |
oops
Here is the 0-80531
12-14-2003, 04:58 PM | #60 |
Personally I do not like vac sec. carbs.
12-19-2003, 09:20 PM | #61 |
dont bother with a vac secondaries carb just get a mechanical secondaries it will be better in the long run from a performance stand point
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-19-2003, 11:57 PM | #62 |
I agree from a performance standpoint but for a everyday driver you will be glad you have vac sec carb everytime you pass a gas pump.
12-20-2003, 10:16 AM | #63 |
Yeah baby!
It will be street/strip, I was thinking 850 double pumper. I run a 750 d/p now on the small block.
To control traction on the street there is a new gadget from MSD that measures crank acceleration. You calibrate it so that the crank is only allowed to accelerate up to a set rate. If it increases too quick the wheels are spinning. Has already been banned by NHRA as it is traction control. Only two months before the 502 arrives....
11.37 @116 |
12-20-2003, 12:37 PM | #64 |
68,
Sallee recommended the speed demon 850dp. Other guys I have communicated with said that a 900 to 1000cfm works even better on bigger heads say rectang ports...they were seeing 700hp and more with true valve openings at .700 or better. They were running full race fuel systems as well.
12-20-2003, 12:51 PM | #65 |
I have a 750DP on my 355 in my 56. Made it into a 4-hole idle carb with a rear block off a 850DP then drilled body. Works great.
12-23-2003, 12:44 AM | #66 |
Update 12/22/03:
Talked with Sallee today. Motor should be back by Jan 1 or so. It will go on the dyno before shipping....I should have the printout soon after... I will have a spare ZZ cam, ZZ502 valve covers, and Street avenger vac sec 870 carb.....
01-08-2004, 11:49 PM | #67 |
Update 01/08/04:
Motor was put on the dyno and started today for break-in. Unfortunately I won't have a dyno sheet until next week. It looks like I will have the truck back by the end of the month. Salle did tell me I will even get a video of the dyno which I thought was pretty cool. Heres to hoping for 650HP.
01-09-2004, 08:28 PM | #68 | |
01-09-2004, 11:27 PM | #69 |
seems like all the bigger c.i. engines have more troubles that just a 350 stocker crate motor.........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-10-2004, 01:39 AM | #70 |
Be sure and let us know the dyno #'s.
01-10-2004, 01:43 AM | #71 |
I will be out of town but will post what comes out of it.
01-14-2004, 03:49 PM | #72 |
Update 01/14/03:
Dyno numbers.... 663hp at 4800 and 625ft/lb's torque Motor ships today....
01-14-2004, 04:00 PM | #73 |
Formerly yellow72custom
Sweet.....sounds like a load of fun
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
01-14-2004, 04:01 PM | #74 |
Post Whore
Wow!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-14-2004, 04:07 PM | #75 |
I personally would not trust a GM crate engine without pulling it down and checking everything and I mean everything. I have three ZZ4 engines and I had major trouble with all of them. And they were not abused in any way. I thought it was the way to go, but so much for that. I'm so discouraged with them that I never even took the last ZZ4 apart. It has been sitting on the stand for awhile. Must just be my great luck....
