Old 09-04-2016, 01:15 PM   #51
Run Away
Re: Run Away's '69 C10 LWB Project Log
The bow in the lower A pillar is bothering me. I want to fix it.
How do I do that?
Bend it straight with some sort of clamp? Pound it out from the inside and hope I don't tweak the whole pillar? Cut it out and weld it back in? Bring it to work and play with the torches to shrink and pop it back out?
No progress yesterday, but I did move everything around and got the trailer/cab inside the garage. Now I can work later (gets dark early now) and out of the bugs and wind. It's also raining all today and tomorrow. Hope to get some more work done today and tomorrow.
Run Away is offline   Reply With Quote
Old 09-04-2016, 07:56 PM   #52
notchbackgta
Cut a groove in the bowed area with a cut off wheel, then hammer and dolly it flat, if you close the gap when you hammer it, use the cut off wheel to open the gap again and hammer it again. Just so you take a little material out of the bow so you don't stretch something else
notchbackgta is offline   Reply With Quote
Old 09-05-2016, 09:53 PM   #53
swamp rat
swamp rat's Avatar
Definitely getting the metal too hot by 1) welding too many spots in an area, and not letting it cool compleatly or 2) sanding too quickly and sanding too much of the surrounding metal, and or 3) the sanding disk is too fine of grit and or worn down so creating even more heat by pressing the sanding disk too hard against the surface. I like to use 36 or 50 grit disks and i keep them fresh, i try to sand only the spot weld and not the surrounding metal as every time you do you thin the metal.
The spots need to cool completely before welding the next set, the metal should feel cool to the touch, try and keep the spots well away from each other by an inch minimum. Every time you introduce heat to a weld seam ether by weld or sanding it shrinks when it cools, the best way is to go around to each spot where possible and Planish each spot weld after it cools, this means to put a body dolly on the back of the weld spot and strike the front of the spot with a hammer to flatten them, This stretches each spot weld to counter act the shrinking, then repeat another round of spots, planishing and sanding.
I cant help much with your welder setting as i have a different welder, i can tell you that .023 wire is better than .035.
There will be a number of places and situations where you can planish the spot weld, even more important to take your time and let it cool, don't try to accelerate the cooling by use of air nozzle or water., that can make the metal brittle.
The area in question there is a bracket welded to the back side that holds the nutplate in place so it cant really be hammered outward (cant remember if the back side is accessable?) so possibly a slice as mentioned, then some heat and pull it out may work, do you have a stud welder for pulling dents?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-05-2016, 09:57 PM   #54
swamp rat
swamp rat's Avatar
Do You see the blue bar just below your forum name in the upper right? in that bar you can click the search button then click on advanced search, type in Planishing or planish welds, then pick threads or posts below it for a lot of reading material on the subject.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-07-2016, 11:00 PM   #55
Run Away
Thanks for the tips guys.
This is good info, I've heard the term before but didn't know what I meant. I will definitely search up on it. I have 0.025 wire in my welder right now I think. I don't have a stud welder.
I went out after I posted that and was able to get rid of the bow with a hammer and dolly. It's not perfect, a bit lumpy but the overall width of the pillar on that side is exactly the same as an untouched pillar measured at the same location.
Old 09-07-2016, 11:14 PM   #56
Run Away
With everything inside now I could work in the rain and dark.
Hammer and dolly on the inside of the pillar got rid of the bow
I need to bring home my 2" air grinder and some roloc disks to finish this area up. Grinding down welds with a 4.5" grinder at full speed isn't easy for the more delicate areas.
I also welded in some metal on the pitted areas here. Is this a bad idea?
Moved to the drivers side. Here I discovered a difference between the two cabs. My '69 cab has a much more pronounced body line beside the windshield, the '71 cab just has a gentle dip.
I made sure it all lined up everywhere else and used a chisel and hammer to try and make the transition from the one piece to the other a bit more gradual.
Old 09-07-2016, 11:16 PM   #57
Run Away
The bottom of the pillar wants to sit about half an inch too far back
Welded and ground
Old 09-25-2016, 03:37 PM   #58
Run Away
Fitted the passenger side inner brace
Some tacks
Plug weld from the front
Fully tacked
Ground
Primed
Random holes in the pillar, as well as cracks by the hinges. Drilled the ends to stop. Did the same on the passenger side, but no pictures
Old 09-25-2016, 03:38 PM   #59
Run Away
Flattened and bent some old copper plumbing from my house. The crack on the drivers side lower hinge was over top of the free-floating plate, and I didn't want to weld the two together.
Old 09-25-2016, 03:39 PM   #60
Run Away
Filled all sorts of holes in the wing panels, including the radio antenna hole.
The drivers side wing had rot up by the base of the windshield
Old 09-25-2016, 03:40 PM   #61
Run Away
Starting to get better at spot welds, I turned the welder way up. Must be pretty poor wiring to the garage. Penetration is better now.
Welded in and ground. Leaving the top part loose until it's fit to ensure best fitment.
Then it's just a matter of lining up the old spot welds to fit it up
Small hole on the trough thing on the drivers side wing. Drilled it out and tried filling it with weld using the copper pipe as a backing rather than cut a small round plug.
I've got patch panels for the lower A pillar bits, but I'm going to leave replacing those parts until the floor is located properly. That way the gaps will be nice and even.
It means I won't be able to get to the back side of the weld for the inner wing, but I'm choosing fitment over better protection.
Old 09-25-2016, 05:57 PM   #62
Run Away
Welded the drivers side wing up and primed while it was mocked into place.
The passenger side wing had rot too.
All welded
Back side
Ground
Primed. I made the upper hole where the dash bolts through too big, but it looks nicer than the ugly square I had before. It's all going to be hidden up under the dash anyways...
Old 09-25-2016, 06:01 PM   #63
Run Away
Welded the drivers side wing into place
Back side of the welds
Welding the passenger wing into place. Just have to line up the old spot weld on the leading edge for this side.
I apologize if I'm jumping all over the place. It's difficult to write this up in order as I'm usually working on 2-3 sections at once so I don't get too impatient waiting for welds to cool. This way I can weld one side, weld the other, grind one side, grind the other and repeat. Keeps my busy.
Added a few more welds along to top of the drivers side
Ground down the inside on the drivers side
Same on passenger side
More welds along the top of the passenger side
Overall look.
Next up is the inner cowl panel, seen here mocked up
Just have to line up the old original spot welds
The passenger side has a bunch of rot on both the tip of the wing and the inner cowl as seen here
There's also some holes more along the middle of the inner cowl I'll have to patch.
This support here I forgot to have blasted and coated. The stock blower motor fits inside of it.
Not sure what I'm going to do about it. I'm not planning on re-installing a factory style heating unit, I'm going to convert to a Vintage Air system that's all contained in the dash. If I end up using it and send it out to be blasted and coated, I should send the dash along with it to save money. Which means I need to make up my mind on putting in a dash with the factory uncut radio, or a dash that's already been cut and mount something like a double DIN unit.
Old 09-26-2016, 11:15 PM   #64
swamp rat
swamp rat's Avatar
Welcome back! Looks like you kicked butt and took names this weekend! I missed your last post, i was down and out for a bit..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-27-2016, 01:23 AM   #65
NewType72
NewType72's Avatar
My lord!! I feel like I was scrolling forever through weld and weld, but you are kicking ass and taking names, great work!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 10-08-2016, 09:49 PM   #66
Run Away
Thanks! Sorry for all the welding pics, seems like that's all I'm doing....
Cowl before
Pitted and rusted through sections cut out
Cut out pitted metal on the wing panel
The bits from the original cab going back on
Patches tacked in
Welded in. Made a huge mistake here, you'll see later.
Old 10-08-2016, 09:51 PM   #67
Run Away
Mocking the original cowl
Mocking the aftermarket cowl
Both don't fit very well, but the factory one fit better. This is where I should have stopped and tried to figure out what went wrong.
Weld
Grind
Old 10-08-2016, 10:45 PM   #68
Run Away
These little supports that go inside the outer cowl got accidentally left out when I got everything blasted, so I cleaned them up the old way. Just waiting the 24hrs for the rust converter to do it's thing before paint.
When I removed the outer cowl I wasn't careful at all because I thought I wasn't going to use it. Put a bunch of dents into it.
I didn't take an after picture, but I spent a bunch of time with a hammer and dolly putting it back to a point where I think body filler would be enough.
Welded in the filler pieces. Just have to line up the old spot welds to put it back to where it was.
Same thing on the drivers side
Ground the patches all smooth
Old 10-08-2016, 10:48 PM   #69
Run Away
Mocking the cowl again.
Fitment issue on the passenger side
With the firewall too
Fitment issue. Basically when I line up the outer cowl to the inner cowl, the passenger side of the outer cowl doesn't follow the contour of the "wing".
Drivers side all lines up nice
The outer cowl is aligned to the inner cowl by sticking screwdrivers through the holes where I drilled the spot welds.
If I start by making the passenger side tight first
Here's how the cowl lines up. Note the drill holes only half overlap.
How did this happen? I forgot to clamp the driver's side lower pillar before welding in the inner cowl.
See that gap? It's supposed to be flush. I also suspect the passenger side A pillar front half I welded in isn't quite right, the wing is "toe'd in" if that makes sense. I think the windshield opening is right as there is a horizontal brace right behind it where the dash used to be, and I can't see how that would move. Add all those up with the rotted out bit of metal where the inner cowl and passenger wing piece meet meaning there was no original spot welds for me to line up meant the inner cowl was welded in with the firewall side just a bit too narrow.
Don't think I can remove the inner cowl from the wing panel how I welded it in, there's so much weld joints I'd destroy both panels. I think I'm going to cut the inner cowl in half, or almost all the way though and use the outer cowl to line things up properly. Thoughts?
Old 10-09-2016, 01:48 AM   #70
swamp rat
swamp rat's Avatar
Ref: post 57 & 59 If that A pillar is suppose to be flush against that brace and its in too far in then that can affect the door and the fender alignment, not to mention fitting in a new floor, i would suggest measuring the new floor width at the lower A pillars. I think all the welding on the inner sections may have pulled the lower A pillars inward, It looks like the lower A pillar isn't twisted from what i can see in the pic's. Is the passenger side still flush with the brace?
Not sure which part you refer to as the wing panel but if you feel that only the driver Lower A pillar has moved inward then maybe instead of cutting the inner cowl in half ( if you mean at the center of the windshield) maybe try and re drill out the spot welds on the driver inner curved panel that has the vent hole on the side?
I am curious how much pressure or force would be required to move that A pillar outward to contact that brace and try and get that floor in there before going forward?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-09-2016, 12:17 PM   #71
Run Away
Yes, the passenger side pillar is welded to that brace. All the bracing I put in place before I removed the top half of the cab from the original floor. Here's a pic:
The drivers side A-pillar ended up having to be replaced completely (which I wasn't expecting when I braced the cab) so when the replacement pillar was lined up along the windshield area it didn't line up at the brace anymore. It didn't pull inwards from welding, it was always like that, even when it was just clamped into place.
Good call on the floor though, I will probably measure the widths to confirm.
The wing panel is what I call the curved inner panels with the vent holes.
Moving the drivers A pillar against the brace isn't too hard, I can squeeze it together with one hand. It's clamped into place now with vice grips.
Rough sketch of what I think is going on:
Old 10-09-2016, 02:48 PM   #72
swamp rat
swamp rat's Avatar
I was more concerned about the A pillar spacing but if you can pull and clamp it in place its probably not an issue.
I saw the space left on the passenger side too, although i was pretty tired when viewing, if you don't think you can re-drill the spots on just the top seam? then yea a well placed saw cut would allow you to pull that piece over (i think) then weld in a pie slice. it would be nice if you could just pull it over as is and clamp the inner and outer together and be done with it.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-10-2016, 01:54 AM   #73
Run Away
Well, I don't know what happened overnight, but everything fits much better now. Maybe I was just too tired yesterday and needed a break.
Photographic evidence below. Note the round file and screwdriver holding the middle centered and clamps on both sides holding everything together.
Also had my dad come over and help me set the windshield back in place to make sure it still fits. Didn't set it in all the way (old gasket that I cut, trim still in) but I don't see any issues. I do think it's maybe time for a new windshield, the edges of this one are pretty clouded.
Rinsed the rust converter off these guys. Not sure I like how it worked. Dug out an old can of POR15 and gave everything a coat.
Cleaned up the underside of the dash and all the inner cowl areas that will be inaccessible once the cowl in on and painted it all too.
Tomorrow is Thanksgiving, so I'll be able to put a bit more time into it, maybe. Going to add some seam sealer to the inside of the cowl and weld the supports in. I might cut and try to spread the inner cowl still as an extra 1/4" would still make things fit better.
Old 10-11-2016, 03:34 AM   #74
swamp rat
swamp rat's Avatar
Hey glad to see a new day and clear head made for better progress! Don't forget to add seam sealer on the outer seams of the inner cowl too before welding on the outer cowl, also the seams at the bottom of the windshield.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-11-2016, 07:14 AM   #75
Aus69c20
Aus69c20's Avatar
Great progress.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
