Closed Thread
Old 05-15-2016, 09:46 AM   #51
wahl4m
Re: This 72 C10 just signed it's organ donor card....
Is the floor around the gas pedal -any good for a patch ?? Thanks mike {shipped to zip 50211-probably go in a postal box ?}
wahl4m is offline
Old 05-15-2016, 06:47 PM   #52
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Originally Posted by FIREBALL View Post
Hey Fred, I'm in search for the two L shaped brackets on the front bumper, one on each inside holding the top portion of the bumper. Im also after any rear tailgate molding trim clips, ones Im after are on each side of the tailgate handle the long strips of trim, I had a few break on me. Thanks Kurt
SOLD,,,, THANKS.... I just took these off. I think they are what you are talking about. How does $15.00 shipped. sound. Thanks, Fred.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline
Old 05-16-2016, 03:18 AM   #53
1972larry
Fred I need one chrome / black wiper knob and both chrome bezels for headlight switch and wiper switch
1972larry is offline
Old 05-16-2016, 04:33 PM   #54
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
Fred I'm away till Thursday morn let me check something when I get back Hm and I'll get back with you then if that's ok
Live life one day at a time!
FIREBALL is offline
Old 05-16-2016, 05:23 PM   #55
bowhunter5846
What kind of shape would the steering column be in? Bearings good? How much to send to 68801? Thank You!
bowhunter5846 is offline
Old 05-16-2016, 05:42 PM   #56
specialtyretail
Let me get it pulled and get you some pics. Thanks, Fred.
Old 05-17-2016, 02:56 PM   #57
BenC/10
How's it goin Fred, looking to convert my gas pedal assembly from the rod version to the cable version, I'm assuming this truck has the cable version? if so would it be a "bolt on" installation if i got the whole pedal assembly from you? Thanks, Ben
BenC/10 is offline
Old 05-17-2016, 03:55 PM   #58
specialtyretail
Hey Ben, not sure about it being a bolt in deal or not. I do not think I have the cable, just the pedal assembly. Thanks, Fred.
Old 05-17-2016, 03:58 PM   #59
Gus350
68 C 10
Gus350's Avatar
What does the tailgate look like and the cowl. Thanks Kevin
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline
Old 05-17-2016, 05:46 PM   #60
crud
I'm interested in the parking brake levers/arms that connect to the cable at the rear behind the brake drums, if you have them.
Thanks.
crud is offline
Old 05-17-2016, 06:01 PM   #61
BenC/10
Lol I actually searched the forum and found that it can be modded to fit into mine. I would be interested in picking up the pedal assembly if that's all you have. Maybe you can snap me a couple of pics of it too if you have some time.
BenC/10 is offline
Old 05-17-2016, 06:11 PM   #62
specialtyretail
Kevin, tailgate and cowl are both sold. Thanks, Fred.
Old 05-17-2016, 07:48 PM   #63
chainsawman
chainsawman's Avatar
Thanks Fred.Stuff came today.
chainsawman is offline
Old 05-17-2016, 10:43 PM   #64
Gus350
68 C 10
Gus350's Avatar
Thanks if you get another gold one let me know need one for a future build thanks
Kevin
John Wayne
68 C10
70 C20
Gus350 is offline
Old 05-17-2016, 11:35 PM   #65
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Here's a small list. PM if you like: The steel has to be right please (ie show quality, no dents), OEM and correct:
1. Pair of OEM outer grille brackets. If you just have a LH side I'll take it. Really, I only need the LH side, but if you don't want to split up no big. I don't need the hardware, but if necessary I'll take that too.
2. Spring from under the bench seat that holds the rod for the seat adjustment.
3. Hardware for the ground strap from bed to frame. I don't know what it's supposed to be because mine was missing.
4. Four 1/2" head tapered screws with integrated washers for mounting the cowl panel.
5. Anti-Dieseling Relay hardware. I have no idea what the hardware is supposed to be, because mine was missing.
6. Five 5/16" head tapered screws to attach the wire gutter to radiator support. I'm not sure if there's supposed to be five or six.
7. Four phillips head tapered screws with integrated washers for the glove box perimeter (i.e., glove box liner screws). Nice finish preferred. I'll take them all if nice or need be.
If you or anyone else has A/C parts
8. Blower Vent Tube for A/C. If by chance it's super then I'll take it.
9. I'm also interested in the small parts (retainers, screws, nuts, clips etc.) for an A/C system, from the evaporator box forward. Some of those retainers are nylon. Would prefer the nylon is nice, but it doesn't have to be.
10. Center A/C vent housing (aka assembly), good condition and good teeth. I could use a nut or two for attaching the vent to it as well. These have a washer molded into the head.
11. One or two screws to mount the Vacuum Reservoir to the evaporator Box. These have a washer molded into the head. I don't recall head size, 3/8" I imagine.
12. Spring that connects the air door to the outer cowl. It's approx. 4.25".
Note: I've requested these parts from another source, but he's semi-retired. If he comes up with these parts as well no problem. Nothing wrong having more than I need. At this point it's less than
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 05-18-2016, 12:16 PM   #66
OLEBEATER
OLEBEATER's Avatar
Received the inner fender brace yesterday. Looks good. Thanks........Roland
OLEBEATER is offline
Old 05-19-2016, 01:47 AM   #67
Dustmaker65
Dustmaker65's Avatar
Interested in Power Brake Ass. Will need everything from pedal to porportioning valve, minus Master Cylinder. Shipped to 61554
Thanks! Jimmy
Jimmy Hoelzel
Dustmaker65 is offline
Old 05-19-2016, 02:06 AM   #68
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
Fred, just sent u PayPal for the front bumper brackets thanks again....Kurt
FIREBALL is offline
Old 05-19-2016, 06:29 AM   #69
wahl4m
checking on the floor parch around the gas pedal ?any good ? thanks fred
wahl4m is offline
Old 05-19-2016, 09:05 AM   #70
specialtyretail
I do have a pair of outer grill brackets. $42.00 shipped for the pair. I will try to get pics tonight. Thanks, Fred.
Old 05-19-2016, 10:38 AM   #71
specialtyretail
Thanks! Jimmy
The truck has sold. All I have is the booster, Thanks, Fred.
Old 05-19-2016, 11:49 AM   #72
71CHEVYSHORTBED402
Awesome, thank you.
Tony
Old 05-19-2016, 05:54 PM   #73
72 Super
72 Super's Avatar
Hey Fred, I recieved my parts yesterday, they look good. Do you have the front bumper bolts, if so what kind of shape are they in ?
Thank you,
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline
Old 05-19-2016, 06:16 PM   #74
BenC/10
Any news on the gas pedal setup? browsing the parts board and havent seen anyothers
BenC/10 is offline
Old 05-20-2016, 08:17 AM   #75
specialtyretail
Awesome, thank you.
Pics of brackets...
Closed Thread
