#51 |
![]() Join Date: Dec 2014
Re: Bent hood
My 1978 has a bent hood, too, and am looking at replacing it with a steel cowl induction hood. Does anyone have experience with the 73-80 steel cowl induction hoods bending? It seems like the design would keep it from doing so.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#52 |
![]() Join Date: Mar 2009
Re: Bent hood
I was on a junkyard tour a while back and found what looks like the LMC brace on this truck... bent anyway. Maybe installed wrong, I dunno. Truck wasn't wrecked in front. Seems like a flimsy solution to me.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD '77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD rust repair on the '77 http://67-72chevytrucks.com/vboard/s...d.php?t=740291 |
#53 |
Re: Bent hood
I could not find any pics of what I did, but here is my post from another thread
Placed two (2) 3" 2x2's under the hood in the channel at the side, one (1) near the front and the other just in front of the hinge. Took a 4x4 and placed it under the 2x2's and clamped in place with some rubber clamps. Placed a 6" 2x4 on the hood on a towel. Measured the distance I need to squeeze the hood and put a 3/4" pipe clamp on there and squeezed slowly. Over squeezed a little and waited. Removed and checked. Repeat as needed. No damage.
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
#54 |
![]() Join Date: Nov 2010
Re: Bent hood
Did you do anything to strengthen it so it wont happen again?
#55 |
Re: Bent hood
No, I am sure those brackets would work. The picture above is not an LMC bracket, they are more rigid. But if you get in a crash with them on, the hood will not bend, it will go through the cab and take you out. I have two little kids at home who wants to keep their daddy around for a while. I just oil the crap out of the hinges and all is good
#56 |
Re: Bent hood
I had the same problem with my 74 Blazer hood. Wound up even buying the megabuck $$$ billet hinges that helped the problem but since my hood had a slight bow it still wasn't perfect. I'm going to try the pipe clamp method and if that doesn't work-look for a better hood to paint. The moral of the story-test fit ALL panels before paint.....
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
#57 |
Re: Bent hood
I'll start this by saying, I keep my hinges greased, it doesnt have any bracing and I havent had an issue with my stock hood. When I started driving my truck my Dad pointed one out with a bent hood and told me "Boy, every time you open this hood spray the hinges with some oil so it doesnt do that." Now maybe I havent done it every time per say but if I'm working on something they get sprayed before its closed.
Now some of you guys worried about taking a hood to the dome crack me up. If you get in a wreck bad enough to put the hood all the way to the back glass you got more sutff to worry about as well. Like an engine in your lap and a steering wheel in your chest. This is almost as bad as a small fender bender to the side causing the truck to explode because of the gas tank location.....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#58 | |
Re: Bent hood
#59 | |
Old Heap Driver
Re: Bent hood
As mentioned before, a little grease, WD-40 etc, will keep the hinges working properly.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#60 | |
Re: Bent hood
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
#61 |
Re: Bent hood
X2! I was thinking the same thing. I've yet to see a convertible square as a result of rear ending somebody. Lol
#62 |
![]() Join Date: Jun 2000
Re: Bent hood
I installed the LMC hood braces, too, but IMHO, it's more important to keep all the hinges well lubed.
#63 |
Re: Bent hood
When I bought my truck a previous owner had installed braces. I have no idea what brand they are. They must work good because the hood is not bent at all, and the springs are stiff. I lubed them up and it helped a bit, but not a lot. I guess I'm going to have to replace them eventually.
1978 GMC K25 1984 Chevy Scottsdale K10 built 350 4"lift - SOLD |
#64 |
Re: Bent hood
From the pics that have been posted, it looks like their nothing more than angle iron available at the local hardware store,a couple holes drilled, cut to length and bolted beneath the hinges?
#65 | |
Old Heap Driver
Re: Bent hood
I'll try and get a picture of my friends truck that has the LMC setup.
#66 |
Re: Bent hood
This is a weird thread. If you oil the hinges you can open the hood with 2 fingers, like when it was new. You shouldn't have to force the hood to shut. If I had any spare time I would post a video of how easy they open and close. So how much are used oem hoods worth nowadays? $300? I should sell my straight ones and put bent ones on my work trucks.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#67 | |
Re: Bent hood
#68 |
Re: Bent hood
You have to relube to get them moving all the povits points on the hinge. spary rust buster slowly work the hinges. there a lots a ways to loosen them up. If there really tight
losts of rust bust and maybe a torch heat up the povits points and more rust bust then lightly work the hood hinges. It may take more then one day to get them loosen up. When they do lube them up good, Do not let them dry out keep them lubed. You can sand blast around the povit ponits, hit them with some rust bust. Bolt back on truck, bolt a 2x4 by 4-1/2 to 5 feet to the hing to work the hings one @ at time make sure you keep square so not to twist the hinges slow and steady. never let hinges get to dirty & dry out keep the povits points lubed you never kink the hood.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#69 |
Re: Bent hood
If your hood hinghes are a tight & you try to close the hood it's staring to shimmy left and right or one side closes faster your hinges need lubed. There rusted gumed up one of the time you close it it's going the kink on you. That a tell tail.
