Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-21-2016, 06:42 PM   #51
rayray767
Re: Lks Dcvn - 1972 2WD Blazer Build
Can't wait to see it 😉👍
rayray767 is offline   Reply With Quote
Old 08-25-2016, 06:26 PM   #52
lks dcvn
lks dcvn's Avatar
Quick update pix...
Loosely installed the ECE LS motor mounts - did not drill the cross member yet as I want to clean it up a bit more still.
Also got the tires (275/60/15) mounted on the 15x8 rally wheels and had some time to install them today. Trim rings and center caps need some minor work prior to final install.
Waiting on drop spindles and then will dig into the front end rebuild and cleaning up the rest of the front suspension.
lks dcvn is offline   Reply With Quote
Old 08-25-2016, 07:12 PM   #53
jjzepplin
jjzepplin's Avatar
I think you've done your good deed for the day! Looking real nice!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-01-2016, 03:36 PM   #54
Tynee
I miss this truck.
Tynee's Avatar
I like it.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 01-07-2017, 08:57 PM   #55
lks dcvn
lks dcvn's Avatar
Finally an update 4+ months later.
I spent my limited free time over the past few months removing the rest of the non-metal parts (wiring harnesses, dash cluster, heater components, etc.) to prep the body for a media blast to see what lurks at the bare metal layer before digging into the resurrection.
Yesterday - the 2wd Blazer and several new parts were loaded into a trailer bound for TN. I also picked up another 2wd Blazer chassis to go with the tub sitting in my spare garage bay.
I coordinated to split the rest of the build between two different shops in 2017.
Body and chassis work - the plan is to take the original tub sitting on the chassis, media blast it and then determine the amount of work ahead to bring it back to solid metal.
I'm already aware of the following areas of concern:
  • new 71/72 front clip (fenders, hood, grill, bumper, etc.)
  • new pair of 72 blazer doors - moving over old OEM door internals
  • One piece front floor replacement
  • Cowl panel rust repair - still deciding on shaving the firewall/cowl trench
  • torsion box replacement
  • outer rocker replacement
  • B-pillar repair on both side - each with their own level of rust/rot
  • Replacement of both rear wheel tubs
  • Repair of rear floor near tailgate area
Chassis will be blown apart, media blasted and then powder coated matte black with all suspension components. Chassis will be given a 2.5/4" drop using ECE components that were shipped down with the truck, new front end suspension rebuild with Moog parts and cross member mods to allow the exhaust to tuck up closer to the body.
Paint will be the original 1972 524 Red-Orange and the bottom of the tub will be Line-X'd to prevent future wear and rusting. Still on the fence about having the inside done with Line-X as well as I'm not sure if I am going to do carpet or not yet. Thoughts from the group on if Line-X'ing the inside of the tub?
Next will be an American Autowire Update Series 510089 to make sure the wiring is up to snuff.
Top has cracking and the hatch struts need replaced - might go to gas struts here - and once complete - the top will be used sparingly so still not sure if I want to pursue a lot of work on the top yet.
Drivetrain - (Street Machinery) - After the body work, paint and chassis are complete - Boris and the gurus at Street Machinery perform the rest of the items on the blazer including:
  • LS motor install - including all cooling and fuel needs -
  • 4L60e/4L65e/4L80e install - depending on which LS gets installed
  • stand-alone LS harness
As for the extra 2wd blazer chassis/tub - I am going to start another build thread once I get that going...
Old 01-07-2017, 09:57 PM   #56
rayray767
Line-X'ing the inside of the tub is always a cool look without carpet. It's also a Protector against moisture problems when having carpet ...
Unexpected rain / morning dew / spills etc...
Old 01-09-2017, 12:51 AM   #57
Beau2a
Beau2a's Avatar
I had mine Rhino Lined over the weekend.
Beau2a is offline   Reply With Quote
Old 01-09-2017, 12:52 AM   #58
Beau2a
Beau2a's Avatar
One more
Old 01-09-2017, 02:03 AM   #59
HARDCORECASH
That looks great Beau2a!!
HARDCORECASH is offline   Reply With Quote
Old 01-09-2017, 04:54 AM   #60
mcmlxix
Collector of Projects
mcmlxix's Avatar
Originally Posted by invicta455 View Post
I would like to know the brand of the head lights also
http://www.quadratec.com/products/97009_8100.htm
Rich
1972 K5 Blazer CST Click HERE
Old 01-11-2017, 08:51 PM   #61
lks dcvn
lks dcvn's Avatar
That looks really good. Are you putting carpet over that Beau2a or leaving it just like that?
Old 01-11-2017, 08:59 PM   #62
Beau2a
Beau2a's Avatar
Hey thanks. I think I will eventually put carpet over it. For now just gonna drive it like this. I'm really happy with how it turned out. It does a nice job cutting down the noise.
Old 01-11-2017, 09:12 PM   #63
rayray767
Super cool looking !
Old 02-19-2017, 08:12 PM   #64
lks dcvn
lks dcvn's Avatar
The blazer made it safely to start the body work. After removing the orange tub from the body it became apparent that the tub would be a lot of work so the Blue tub was sent down last week to use instead and the spare 1970 2wd chassis was also sold.
The original 2wd chassis has been media blasted and is pending powder coat. The blue tub will be blasted, mated to the frame with Wes's new blazer body mount kit and then body work started with the top in place.
I ordered up some Dead End Garage bolt in exhaust cutouts for the x-member and a red head steering gear box this week. They are on their way as the frame is going to be put together with new MOOG parts as well as the ECE 2.5/4" static drop.
Old 02-24-2017, 03:25 PM   #65
lks dcvn
lks dcvn's Avatar
Digging into the blue tub...found some spots I'm glad were found now so they can be cleaned up and repaired.
Looks like even in Montana - these things rust away from the inside out.
Old 03-18-2017, 11:11 AM   #66
lks dcvn
lks dcvn's Avatar
Frame has been blown apart to make sure no rust is hiding and being prepped for powdercoat - a few more pix...
Old 04-01-2017, 09:07 AM   #67
DaHos
DaHos's Avatar
I see some things very similar to mine in these pics !!! Keep er up !!!
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 04-12-2017, 08:31 PM   #68
lks dcvn
lks dcvn's Avatar
Frame is back from powder and assembly has started - hoping for rolling chassis by the end of the week.
Old 04-12-2017, 08:36 PM   #69
raggedjim
raggedjim's Avatar
Nice, makes me question not pulling the tub off the frame...
Good work, Rg
raggedjim is online now   Reply With Quote
Old 04-12-2017, 11:34 PM   #70
gringoloco
A guy with a truck
gringoloco's Avatar
Wow, just wow.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 04-20-2017, 12:07 AM   #71
lks dcvn
lks dcvn's Avatar
This is the fourth 2wd 70-72 I have owned since I joined the forum. I'm at a spot now where I can build one up and keep one for awhile. This one is getting the full treatment...
I also picked up a 71 4x4 blazer project to tinker with while this one is being built. No pics or build thread for that one yet. It's getting some work done to make it safe/reliable for the summer.
Old 04-21-2017, 10:04 AM   #72
jaros44sr
jaros44sr's Avatar
tell your mechanic to hurry up,lol
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-22-2017, 10:11 PM   #73
lks dcvn
lks dcvn's Avatar
Talked to my mechanic this morning actually - rotors, calipers and ball joints were replaced today on the project blazer after they dug into the front suspension... I think that's the last of the repairs so after confirming no more leaks from almost every possible spot including the gas tank - I should get the truck back this week (finally)!
Old 04-30-2017, 06:57 PM   #74
lks dcvn
lks dcvn's Avatar
I was wrong the alternator was the next thing to fail the inspection over the weekend - new alternator pending for the 71 Blazer project...
Old 05-08-2017, 05:59 PM   #75
1956cameo
1956cameo's Avatar
Your project is looking good. Looking forward to seeing the 4wd that you picked up.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
