#51 |
Re: 69 swb turbo Ls swap
moving right along. I used db rods and minis in Taylor tx for my tank. very nice quality and he can build the top of your tank to fit any pump or sender. I used the stock fuel pump out of the donor truck (I know this won't work for you since you need more fuel).
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
#52 |
![]() Join Date: Feb 2014
Thanks sounds great I'll have to check them out! I got the donor truck out of my driveway this evening, so I have more room to work now. I talked to my buddy pat who does my transmissions and they got the trans torn down and everything looks good nothing bad so they are gonna put a shift kit in it and some bushings and it will be good to go!
Talked to autometer today since I already have all autometer sport comp gauges they said if I get the electrical version of my speedo it will be a direct hookup to the sender in my 4l80e so that's good news! Called 5-6 different lsx harness conpanies the only one I could get ahold of was modern vintage and talked to them for awhile and they had a lot of good things to say and were very helpful so they are on the top of my list now,hopefully will hear back from some other companies because I like to have options! Turbo and wastegate should be here tomorrow will post pics when I get the package!! 🤑🤑🤑🤘🤘🤘 |
#53 |
Post Whore
![]() ![]() Join Date: May 2015
I had good luck with psi harness..I had one little issue (blade connector to fuel pump came loose) but they were quick to respond..
#54 |
My turbo and wastegate came in today it feels like Christmas!! 🤑🤑
#55 |
The turbo smart power gate 60 is huge!! This is a very high quality piece! I cannot wait to start fabbing this stuff up!
#56 |
Kvn1011
![]() ![]() (Project Slow Motion) |
#57 |
Kvn1011
![]() Posted via Mobile Device Posted via Mobile Device
#58 |
Thanks!!
#59 |
Got my blow off valve ordered and on the way a tial q 50 mm black bov!
#60 |
Been awhile since I've posted but have been super busy with side work and have been collecting parts! Got a tick performance stage 2 ls2 turbo cam with valvesprings and titanium locks and retainers, also got a circle d triple disc billet converter, and also got the passenger side up and forward header all fit up, I will post some pics of the progress!
#61 |
Circle d triple disc billet converter
#62 |
Motor and trans are in ended up using the ict billet accessory setup with 98-02 ls1 power steering pump.
#63 |
Another shot from the front of the truck !
#64 |
Looking fantastic
#65 |
Thankyou!
#66 |
Got the primary tubes welded on the headers and the crossover all fit up!
#67 |
Another pic from upfront! Need to get some 4 inch tubing for the downpipe and figure out my wastegate placement and order my ls swap radiator so I can make my hardlines for the coolant lines around the crossover, but I have a bunch of orders for turbo kits and catch cans so it might be a week or so before I get back on it.
#68 |
Here's a picture of the passenger side header with the primaries welded and spike welded before I put the collectors on!
#69 |
Nice work. Is there more room between the front of the motor than it looks? If not are you moving your radiator to the front side of the core support to fit your fans? It's hard to tell. Looks like all business under there!
#70 |
Thanks! Yea from that angle it doesn't show how much room there is with the fans installed there is about an 1-1/2 between fans and the the tubing I kept the crossover closer to the motor then the fans, I still need to get my ls swap radiator and might switch to a low profile fan setup but I plan on running the radiator in the factory position.
#71 |
Man that looks tight! Will it cause any heat issues being that close?
#72 |
pictures make it look tighter than what it is, I plan on having everything ceramic coated so I'm not worried about it,
#73 |
Should look super nice. I can wait to see it!
#74 |
Thanks man! Once I get the new radiator in there I'm gonna decide if I want to move the radiator forward a little it looks like with a little bit of work I could move the radiator forward about 1-1/2 which I would be happy with! And if I get a low profile fan setup I could gain another 1-1/2 or so, so we will see!
#75 |
Love this build. Keep up the good work as your schedule permits brother.
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
