Old 09-11-2016, 01:01 PM   #51
davepl
davepl's Avatar
Re: Idle vacuum - why only 10 inches?
I'd say my brakes work fine, though I'm sure they'd be better with 18" than with 11". But all of my vacuum accessories function acceptably.
In fact the only operational problems I'd like to improve on are the RPM drop when the AC compressor kicks in and the amount it heats at idle. Otherwise it performs admirably.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-11-2016, 03:49 PM   #52
jocko
jocko's Avatar
yeah, something is fishy. PB's don't work well with only 10" of vac. This is interesting.
Old 09-11-2016, 07:52 PM   #53
davepl
davepl's Avatar
I don't have a "before" to know the level of assist that I could expect with a higher level of vacuum, though. But we have a big vacuum reservoir and in most cases that'll trap and save any transient high vacuum periods like from startup, blipping the throttle, coasting down, and so on. So you're not actually only working with the idle vacuum, even with a big cam.
Maybe they'd be better with more?
Either way, I've checked with three gauges now, they agree...
Old 09-11-2016, 09:46 PM   #54
rsgt
rsgt's Avatar
Try adjusting the valves with the engine running. Go 1/4 to 1/2 turn pass clicking. I have seen vacuum increase when they where tighter that that.
rsgt is offline   Reply With Quote
Old 09-11-2016, 10:11 PM   #55
garyd1961
Believe it or not my crate engine wasn't running right when I first installed it. I told one of the guys(master tech) at work how it was doing and he said the valves are too tight without even thinking about it. I was going to set the valves but couldn't rotate the motor and watch the valves by myself. I knew the factory sets them at one full turn so I just backed each valve off 1/2 turn and it runs great.
I told the master tech what I did and said I would go back and re-adjust them when I had some help but he said why, if it 's running good leave it alone.
I usually set valves with the motor running but this was a new motor and I spent a lot of time detailing under the hood.
garyd1961 is offline   Reply With Quote
Old 09-12-2016, 12:25 AM   #56
toolboxchev
I had an idle problem within 8 months of installing a new booster. My friend told me to check it. Did the soapy water spray with it and I was surprised, 8 month old lifetime warranty replacement was the culprit again.
I could not believe it. Dont know what to suspect at this point. break out the can of whoop a$$
toolboxchev is offline   Reply With Quote
Old 09-16-2020, 12:51 PM   #57
70STOVEBOLT
70STOVEBOLT's Avatar
Did this problem ever get solved?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-16-2020, 05:41 PM   #58
MagmaJct
MagmaJct's Avatar
No, it hasn't. The truck failed emissions last year (finally). I rebuilt the carburetor, but haven't taken it to be tested yet. I just started full time school, as well as working full time weekends. So the truck's sitting in the side yard with a tender on the battery.
I think the only way this issue will ever be resolved is with a tear down and rebuild. As long as it passes emissions, and it remains a hobby vehicle, I'm not going to do a rebuild due to other obligations.
Thanks for asking! I don't like abandoned threads that are left open ended.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 09-16-2020, 05:50 PM   #59
70STOVEBOLT
I was directing the question toward the OP
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 09-16-2020, 05:53 PM   #60
MagmaJct
MagmaJct's Avatar
My apologies. I had written a similar post several years ago, and I thought your response was to that. I had participated, so I got the email alert.
Hopefully the OP sees this and responds.
Old 09-17-2020, 08:08 AM   #61
70STOVEBOLT
No worries, I did not see that you had posted on the thread.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
