Old 10-09-2003, 12:35 PM   #51
Spoof
Spoof's Avatar
I'm curious too, how much did you cough up for all the materials?
If you don't wan't to talk about it...I know where your coming from!
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 10-17-2003, 05:22 PM   #52
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
did u have to do anything with the bumpstops?
-Ron-
OldSkool71 is offline   Reply With Quote
Old 10-17-2003, 05:39 PM   #53
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I had to remove the rear ones (just the rubber part, the bracket is still on the frame). I left the front ones alone. I drove it about 200 miles today. It rides very well. No bottoming or other ugly characteristics.
Spoof, total from Early Classic was 800 dollars. This got me front spindles, rear 6 inch springs, super track bar, shock mount relocator kit, 4 KYB shocks, raised sway bar bracket kit, and front brake hoses. And shipping was 60 bucks of that! I already had 2 inch front drop springs from Summit, which I payed 89 for. Summit doesn't charge shipping.
Other things included new rear brake shoes (15), two front calipers (22), 2 new inner front wheel bearings (8), front grease seals (8), brake pads (20), brake caliper bolts (10), banjo bolts to hold brake line to caliper (6), master cylinder (13), and the little clips that go on the back of the brake pads (2). Also needed lugnuts (I scrounged them up, they don't match, I hate them).
It wasn't cheap, but I don't cut corners on brakes and suspension. My little girl rides with me, and her life is worth spending a few bucks for safety. I got the rear end from Matt67350. I cleaned and painted it and changed the oil in it. I also got a front end from him too. I pulled the rotors, outer wheel bearings, dust shields, and grease caps off of. I sold what was left over to Hutch.
It was worth it.
Old 10-17-2003, 05:41 PM   #54
Tx Firefighter
After
After
Old 10-17-2003, 06:32 PM   #55
gr8scott51
gr8scott51's Avatar
nice stance
Looking good. It was worth it.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 10-17-2003, 06:50 PM   #56
Spoof
Spoof's Avatar
That strikes me as a fairly reasonable cost. ECE is worth anything over and above anything else. Good on ya.
71 GMC 1500 LWB
