11-24-2016, 11:44 PM | #51 |
Re: AWD c10
Thanks! I'd love to come over but as it stands right now my wife is at her wits end with me being in the garage. I'm sure we all know has this dance goes.
11-25-2016, 10:42 AM | #52 |
Re: AWD c10
Oh so well LOL. But, I'm hoping that she'll enjoy it as much as I do once it's done.
11-28-2016, 03:44 PM | #53 |
Re: AWD c10
Just found this thread - freaking awesome. I remember your original post in the steering/suspension section and always wondered if you scrapped the idea or went ahead with it. It made my day to see that you were able to take it around the block under its own power (as a '69 C10 this time). Nice work!
12-02-2016, 05:34 PM | #54 | |
Re: AWD c10
12-02-2016, 05:38 PM | #55 |
Re: AWD c10
We've had issues with the 241 in certain cases, seems in 2wd you can abuse them, but in 4 hi they just can't take the power. I personally think you'd be happier with the transfer case out of the SS, at least I would be.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
12-03-2016, 08:26 AM | #56 |
Re: AWD c10
Yes, I think you are correct. I found a 149 that will be coming my way for a good deal, always a bit sketchy buying something like this sight unseen.
12-03-2016, 12:54 PM | #57 |
Re: AWD c10
I know what you mean by that. I think we've all have made that decision and have benefited from it or well you know.
12-05-2016, 10:53 PM | #58 |
Re: AWD c10
So I did just about the worst think you could do to an AWD transfer case, aside from throwing it across the garage, I took the front driveshaft off and went for a spin. Ah I'm so crazy! Back to reality, I did this because there is a "test" to see if the viscous coupler is working or locked up, mine was locked up, of course, so I had nothing to lose. Pulled out of the driveway and the front was smooth as silk, so this confirms that the t-case is a paperweight. I have a 149 that will coming in a few weeks so in the mean time I'll fab up the raised bed floor.
12-08-2016, 11:14 PM | #59 |
Re: AWD c10
So great to see this build sir. I am in the process of doing the same with a Yukon AWD donor vehicle. Love the look of the truck and the wheels you've chosen. Do you know the BS of the wheels? Did you ever get the transfer case issue lined out?
Thanks Dave |
12-09-2016, 08:52 AM | #60 | |
Re: AWD c10
The t-case is going to be shipped Monday and keeping my fingers crossed its all good, just never know. It's a np/nvp149, all mechanical, nothing electrical, can't wait. Good luck with your project and ask all you want about lowering that Yukon! |
12-09-2016, 09:05 AM | #61 |
Re: AWD c10
I was thinking the Yukon axle width would be wider than the original C10 and that was why you used the backspacing. I'm just now getting started so I will be needing advise. Was very glad to see the steering shaft you came up with, that one had me worried.
12-09-2016, 12:27 PM | #62 |
Re: AWD c10
The width is much wider but the new wheel style makes it so the wheel is flush with the just inner fender lip. The rear I cut the inner out and rolled the lip, then pushed the lower fender out for a pro touring/ wide body look, it's only pushed out 3-4"
The steering was $$$, the rack takes a 17 mm if I remember and it was a double u joint, then a DD to a 36? Spline. Well not a lot of money but for what your getting, then again steering and brakes are the most important |
12-12-2016, 09:41 PM | #63 |
Re: AWD c10
Some yoga welding while I wait for my transfer case.
12-13-2016, 11:02 AM | #64 |
Re: AWD c10
12-17-2016, 10:10 PM | #65 |
Re: AWD c10
New case arrived!
12-17-2016, 10:13 PM | #66 |
Re: AWD c10
Learned this from my operating room job. Just cut it open, much easier.
12-17-2016, 10:17 PM | #67 |
Re: AWD c10
Nothing like balancing 80lbs on your sternum and wiggling your way from under a 4000lb machine. Didn't learn that from my Emergency Room job.
12-19-2016, 01:32 PM | #68 |
Re: AWD c10
Very cool build. Yet another build that makes me question the decision to sell my Trailblazer.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
12-19-2016, 11:30 PM | #69 |
Re: AWD c10
Have you seen the guy over on the 60-66 suburban build forum? He bought a trailblazer SS and cut the body off and grafted the burban on top, super cool. Today I bought a gasket to go between the transfer case and transmission, all along knowing full well that I should wait until the case is in the proper spot. Trying to wedge 80lbs of metal while laying on back into a spot that it just barely fits, I tore the gasket. Perfect, I knew I would, just had to get it out of the way. So off to buy another and install tomorrow night, without tearing it.
01-05-2017, 09:14 AM | #70 |
Where did THAT bolt go?
Re: AWD c10
Cool build man!!
The Swiss Car Club......A drinking club with a car problem.... |
01-05-2017, 04:52 PM | #71 |
Re: AWD c10
Thanks! I installed the new to me transfer case and it worked great. I don't have my seat installed yet so I'm just sitting on a tool box racing around the neighborhood. It's so much quicker/faster than before it just about scares me to drive it, so I know I'm headed in the right direction!
01-05-2017, 05:10 PM | #72 | |
Re: AWD c10
You talking about that Eagletucky guy that just posted above? Yea, Ive been through his build. He is the first one that got me thinking about the trailblazer.
