Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 10-02-2019, 09:20 AM   #51
VWNate1
VWNate1's Avatar
Thumbs up Re: Progress on 46
Sounds good to me ~
I didn't realize the 261 head would fit on a Babbit Pounder .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 10-02-2019, 08:09 PM   #52
dennislbrooks
dennislbrooks's Avatar
Re: Progress on 46
yea, the steam holes in the 261 head just get plugged off on the 235 block. The steam holes are only needed on the siamesed cylinders of the 261. Going the other way, a 235 head on a 261 block would require drilling the steam holes on the 235 head. My 53 is not a babbit engine.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 10-03-2019, 09:14 AM   #53
VWNate1
VWNate1's Avatar
Post Re: Progress on 46
Now you've got me piqued .
I thought full pressure oiling didn't arrive until 1954......
The rocker oiling changed a little bit over the years, I seem to recall needing to get creative when shuffling heads between years on early 235's .
-Nate
Geezer
Old 10-03-2019, 07:11 PM   #54
dennislbrooks
Re: Progress on 46
1953 with auto transmission - cars -- had hydraulic lifters and replaceable rod bearings. All 1954's had replaceable rod bearings.
Old 10-03-2019, 09:46 PM   #55
VWNate1
VWNate1's Avatar
Thanx ! .
-Nate
Geezer
Old 09-11-2020, 01:58 PM   #56
docrock
docrock's Avatar
Re: Progress on 46
Beautiful Build! I will be starting my next 42 project soon and provided a lot of inspiration
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 09-11-2020, 04:06 PM   #57
docrock
docrock's Avatar
Re: Progress on 46
Originally Posted by dennislbrooks View Post
On the front I used the 6 to 8 lug adapters which are 2 inches thick. Dually front wheel sits in the front wheel well just right with no rubbing of tire on a left turn. Has 16" radials on the front and drum brakes all the way around. I changed the front axle earlier in a thread to a 57 half ton because of getting drums for a 46 3/4 ton.
It looks like the wheels tucked under the fenders further. The wheels don't rub on the tie rod ends? Do you know what your wheel mounting surface measurements were before the adapters?
Old 09-12-2020, 05:22 AM   #58
dennislbrooks
Re: Progress on 46
Those are 1 ton 16" wheels from a late 70's C30 dually. I have no problem on tie rod ends. Center link (from 46) threads may need cut further on the RH thread end to achieve a toe of 1/4".
I would use a 1955-59 3/4 ton front axle if you can find one and forget the adapters. Spacers can be used if necessary. Axle still needs shortened same as 6 lug. I missed a chance at one close. Dang
http://www.67-72chevytrucks.com/vboa...d.php?t=700070
The truck is at my uncles house but the measurement you want is 5 inches less than a stock 55-59 1/2 ton or 3/4 ton. Believe it or not I do mark all my none year parts with a paint pen for future repairs.
Old 12-22-2021, 06:42 PM   #59
docrock
docrock's Avatar
Re: Progress on 46
Do you have any pics of this truck finished??
Old 12-23-2021, 05:59 AM   #60
dennislbrooks
Re: Progress on 46
A few
Old 12-23-2021, 06:01 AM   #61
dennislbrooks
Re: Progress on 46
Another, all have a nice holiday.
Old 12-23-2021, 07:28 AM   #62
dennislbrooks
Re: Progress on 46
last
Old 12-23-2021, 01:04 PM   #63
docrock
docrock's Avatar
Re: Progress on 46
It came out beautiful. I like the 8 lug all around and srw. I liked the black wheels it looked factory. My second 42 project will be on a 70 chassis. Not sure what to do with the front axle. It is IFS and is too wide for the look that I am going with. I need to narrow it about 4 inches or get dually wheels and try to make a spacer that pushes the wheels out but still under the fender and not rub the tie rod ends. Or I have a stock 46 axle without spindles and build something off of that.. Not sure what to do but thanks for posting the pics, it really looks great
Old 12-24-2021, 03:25 PM   #64
VWNate1
VWNate1's Avatar
Thumbs up Beautiful 46 !
That's glorious, painting the inside of the doors red is a nice touch that makes it pop .
FWIW, those who have the pre 1951 year model trucks, it's a very simple thing tp upgrade them to Bendix brakes from any old 1951 ~ 1967 front axle that was discarded by a Hot Rodder , no need to change the master cylinder even .
I hope the "needs 1/4' toe in" was a typo ! never more than 1/16" is necessary and will make it drive so much nicer plus not scrub the tires to death .
-Nate
Geezer
Old 12-24-2021, 09:36 PM   #65
dennislbrooks
Re: Progress on 46
Thanks guys. I agree with no more than 1/16". I have put in a sm420 to replace the orig crash box 4 speed.
Old 12-25-2021, 01:23 PM   #66
VWNate1
VWNate1's Avatar
Post Toe In
FWIW ;
I usually begin at zero toe slack adjusted then go from there .
Chevies with beam front axles used a lot of caster so when you let go of the steering wheel it snaps back to center quickly .
This is why the factory adverts said " If it drives like a truck, it's NOT a CHEVROLET !"
-Nate
Geezer
