Old 01-08-2017, 08:26 AM   #51
lt1wrangler
Re: 1988 Crew Cab shortbed overhaul
My truck is missing the front sway bar, does anyone have one for sale?
lt1wrangler is offline   Reply With Quote
Old 01-08-2017, 04:24 PM   #52
lt1wrangler
The frame and actually turned out really nice from sandblasting and painting them with por15
Old 01-12-2017, 12:36 PM   #53
HunterRotten
HunterRotten's Avatar
Belltech has some good sway bars if you're interested. They are massive. The front ones are 1 3/8" if I remember are are just under $200 for the whole kit. Includes mounting hardware and polyurethane bushings. The rear sway bar is just a bit thinner but not by much.
If you want to hide the bar, then CPP has a bracket kit that will adjust how low or how high it hangs.
HunterRotten is offline   Reply With Quote
Old 01-13-2017, 10:20 PM   #54
lt1wrangler
Thanks! I'm on their site now.
Old 01-13-2017, 10:23 PM   #55
lt1wrangler
I finally got a chance to set a mock up drivetrain in the frame. I used ICT billet motor mount adapters to set the LS engine in there. It's a late 4L80 and 205 case. It really fits nicely. Next comes header mock up
Old 01-13-2017, 10:27 PM   #56
lt1wrangler
Few more of mock up
Old 01-14-2017, 04:59 AM   #57
MTCK
MTCK's Avatar
Cool what are you running for a motor?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-14-2017, 09:10 AM   #58
lt1wrangler
an 05 6.0L LQ9 motor with a cam and top end work. I like using the BP Automotive harnesses also, makes for a really clean look. I'm just wanting a really clean daily driver that i can tow with on occasion.
Old 01-14-2017, 05:18 PM   #59
lt1wrangler
I spent most of the morning just trying to figure out how I wanted the sending unit to connect to lines. I took a new sending unit apart and installed a new 3/8" line and flared for quick disconnect. I didn't like the way it fit together so I opted for an auxillary tank unit and flared it. Looks clean I think and eliminates compression fittings .
Old 01-15-2017, 11:52 PM   #60
mattcrp1
mattcrp1's Avatar
I like the flare you did. What tooling set up is that?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 01-20-2017, 10:54 PM   #61
lt1wrangler
I bought a hydraulic flaring kit from snap on, I'll check on the brand tomorrow cause I don't think it's snap on.
Old 01-21-2017, 02:29 AM   #62
COS399
COS399's Avatar
Just found this build and I'm in. Your making it look way to easy. lol
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 01-23-2017, 06:34 PM   #63
NorCalAnthony
Sweet build and great work so far! I've always wanted a CCSB 4x4 square body and having a LQ9/4L80E drivetrain is icing on the cake
For the springs, I'd take a look at Office Road Design (ORD). They specialize in stuff for square body trucks and do custom leaf spring packs from Deaver but built to their specs. http://offroaddesign.com/catalog/ORDCustomSprings.htm
NorCalAnthony is offline   Reply With Quote
Old 01-27-2017, 11:25 PM   #64
lt1wrangler
Started back to on frame. Got the springs and axles mounted. And decided to get the 205 case tore down and rebuilt.
Old 01-31-2017, 07:42 PM   #65
lt1wrangler
Transfer case done!
Old 02-03-2017, 06:43 PM   #66
lt1wrangler
Progress is slow while I'm finishing the suburban. Here's a few things we are working on. I did high steer arms with a 2wd box to keep the steering geometry right.
Old 02-03-2017, 06:44 PM   #67
lt1wrangler
Gas tank and new brackets mounted. I went with smaller tank because of the short bed conversion
Old 02-04-2017, 11:38 AM   #68
MTCK
MTCK's Avatar
Looking good. You running two tanks or just the one?
-Marcus
Project Plow Truck
Old 02-04-2017, 11:59 AM   #69
lt1wrangler
I guess just one but Im rethinking that decision lol. When i installed tat tank, I kept thinking how small it was!
Old 02-04-2017, 12:42 PM   #70
Kaysen
I just installed one tank on my k30 and already regretting it. Granted yours will get better mileage than mine but you'll still have around a 200 mile range before completely empty. I think it's be cool to put a 40 gallon burb tank in the back, and plumb the side tank in to refill the burb tank when it gets below half full. Truck is coming along nicely, good job sir.
Kaysen is offline   Reply With Quote
Old 02-04-2017, 02:30 PM   #71
MTCK
MTCK's Avatar
Yeah we get about 10-12 mpg with all our 6.0 6l90 combo work trucks. 160-200 miles! 40 gallons in my crew keeps the number of gas stops from being obnoxious when I daily drive it.
-Marcus
Project Plow Truck
Old 02-04-2017, 11:18 PM   #72
lt1wrangler
Does the burb tanks fit in the back easy? Can I use factory mounting?
Old 02-05-2017, 10:25 AM   #73
daddyjeep
daddyjeep's Avatar
I don't think you can fit the 40 gal with a short bed. I had to clearance my 25 gal for my passenger side shock. A lot of guys relocate the shock, but I already had everything painted when I realized I had a problem.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-05-2017, 10:32 AM   #74
lt1wrangler
Is there much difference in size to do the 31 gallon in the blazers?
Old 02-05-2017, 10:34 AM   #75
daddyjeep
daddyjeep's Avatar
The only difference between the 35 and 31 is the height.
04 1500 crew cab
