Old 05-03-2017, 09:11 AM   #51
weq92f
weq92f's Avatar
Re: Funky clunk sound driving me absolutely insane!
Originally Posted by AirSpeed View Post
Mine is four wheel drive, I did just replace the ball joints but it didn't fix my problem.
Shoot, you have leafs in front. Nevermind.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-03-2017, 12:03 PM   #52
fatbass
fatbass's Avatar
Could it be oilcanning of the floor? I've seen less than perfect replacements of floorpans that cause this kind of clunking as the body flexes with the frame on turns.
Also, check the bolts holding the seats to the floor. If they are loose the seat can thump the floor during turns.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 05-04-2017, 02:29 AM   #53
El Dorado Jim
do you have the travel tanks ?,gas tanks under the bed, one of them could be loose... I assume you checked all of your crossmember bolts? motor mounts, transcase mounts...I know you probably have
El Dorado Jim is offline   Reply With Quote
Old 05-15-2017, 12:12 PM   #54
AirSpeed
AirSpeed's Avatar
Originally Posted by Kennuck View Post
I had a shock that would clunk like this. The shock mounts were fine and the shock still worked but would clunk internally. When I grabbed the shock and had my son bounce the suspension I could feel it in the shock, Replaced the shock and all was good.
Finally got a chance this am to disconnect the shock, tied it back and went for a drive, still clunking. I did learn the shocks are worn out though, hardly any compression in them, could push them in with two fingers. Ordering new shocks today.
AirSpeed is offline   Reply With Quote
Old 05-15-2017, 12:17 PM   #55
AirSpeed
AirSpeed's Avatar
Yea, I've checked every single nut and bolt, linkage, mount, body panel, replaced drag link, ball joints, tie rod ends, I even replaced the entire brake system. I've had several people look just in case I missed something but no luck! I only have the stock gas tank. It's a mystery!
Old 05-15-2017, 12:22 PM   #56
AirSpeed
AirSpeed's Avatar
My pan is stock and I have a truther ton of sound deadener on it, doesn't really sound like sheet metal, it's a definite clunk sound like something is hitting something. Seat bolts are tight. Wish I could get it to happen by rocking the truck or something but it refuses to happen unless I'm driving it.
Old 05-15-2017, 01:07 PM   #57
fatbass
fatbass's Avatar
Then it can only be one thing...
Poltergeist.
'71 C/20 350/T350.
Old 05-15-2017, 01:12 PM   #58
AirSpeed
AirSpeed's Avatar
Poltergeist.
Already thought of that, had an exorcism performed on the truck last week, found an old hippie spiritualist to come over and do it, didn't help! Now my truck smells like pachouly oil and burnt sage!
Old 05-15-2017, 11:45 PM   #59
El Dorado Jim
Old 05-16-2017, 01:06 PM   #60
El Dorado Jim
Originally Posted by Daves70 View Post
My vote is a cracked frame behind the steering box. Hope I'm wrong. Good luck.
I know you said you checked for cracked frame, did you look behind steering box.....?check your steering box for loose bolts.or cracks at the bolt holes for the steering box..kind of stupid questions I am asking, but it is frustrating to me as well not being able to figure it out...
Old 05-16-2017, 02:51 PM   #61
67ChevyRedneck
67ChevyRedneck's Avatar
Sounds like you need to mount a gopro style camera under the truck and point it in the direction you thing the noise is coming from.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-16-2017, 06:56 PM   #62
AirSpeed
AirSpeed's Avatar
I've got one and a monitor in my dash, as soon as I find the magnetic mount.
Old 05-16-2017, 07:08 PM   #63
AirSpeed
AirSpeed's Avatar
I checked it, there are two loose rivits but they're not making any noise, it barely moves but I'm going to grind them off and put some bolts in it. The sound is definitely on the passenger side. It's frustrating as hell! I've been under, over, inside and out of the truck, tightened every nut and bolt, replaced all the bushings, drag link, ball joints, wheel bearings, brakes, tie rod ends, I even cleaned out the glove box and searched under the seat. I tried spraying lube on every component one area at a time to see if I could get the sound to change but no luck. I am at a loss! It's the only noise in my truck, I can drive down a dirt road and have no rattles, just that annoying creaking clunk! I can't wait to find it!
Old 05-16-2017, 07:11 PM   #64
harpo231
harpo231's Avatar
Is a truck still a truck if it doesn't make a noise of some kind ?
harpo231 is offline   Reply With Quote
Old 05-16-2017, 07:26 PM   #65
paul blair
Something inside the door? maybe in vent pocket or rocker! Loose lug wrench or jack. Seems You have checked everything else.
paul blair is offline   Reply With Quote
Old 05-16-2017, 08:28 PM   #66
dbguettl
Have you checked to see if either your rear drive shaft yoke, or the slip yoke on the front drive shaft is "sticking". Try pulling the yoke and putting a little grease on them so it slides easier as the distance changes between the transmission/transfer case and the front and rear axles.
dbguettl is offline   Reply With Quote
Old 05-16-2017, 09:05 PM   #67
AirSpeed
AirSpeed's Avatar
Thanks, I pulled the drive lines, found the front had loose bolts where it mounts to the transfer case and missing a bolt, fixed that, the yoke is well lubed and slides easily. The u joints are good on the drive shafts and the front axles.
Old 05-22-2017, 02:02 PM   #68
jbarron
Anymore updates on this.
I have the exact same noise on one of mine.
Very annoying.
I've done all the same checks and could not find it. Even replaced the cab bushings.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 05-22-2017, 05:13 PM   #69
AirSpeed
AirSpeed's Avatar
Very annoying.
Still no luck! Maybe one day one of us will figure it out! I'll keep it updated.
