Old 06-30-2017, 07:09 AM   #51
Grumpy old man
Grumpy old man's Avatar
Re: 250 6 engines and parts
Originally Posted by Beetle View Post
Grumpy, I will have a 250 PS setup available here soon. I am about to pull my 250 6 out. What would you need? Check my build thread the second one down in red for pics. PM me if you want. I ain't lookin to get rich off the stuff, just know there's folks out there that need it.
Pm sent , thanks I'm always looking .
Grumpy old man is offline   Reply With Quote
Old 06-30-2017, 12:18 PM   #52
Grumpy old man
Originally Posted by 70shortstep View Post
Any chance you have one of these?
I found your parts and pulled them for you PM me a phone number to send pictures to . I was using photobucket and now I have to find a different way to past pictures
Old 06-30-2017, 01:14 PM   #53
70shortstep
Registerd User
70shortstep's Avatar
Pm sent. Thanks
John
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=613398
70shortstep is offline   Reply With Quote
Old 07-12-2017, 05:10 PM   #54
slepysal
slepysal's Avatar
Looking for the manifold hold down clamps Ca 95112
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 06-11-2018, 07:15 PM   #55
ElCoSix
Hi,
I have a 67 El Camino with a 250 that I'm restoring. The bolt is broken in the front of the crankshaft. I know it wouldn't be the biggest sale you ever made, but do you have one of those bolts - or do you know the thread size and thread pitch? I'm trying to get the broken bolt out and running out of ideas, but if I can figure out the exact thread size and pitch maybe I can at least clean out some of the threads near the top of the hole with a thread chaser, and that would get me to the next step. (If I can get a bolt started and stable enough I'm thinking maybe a machine shop could drill down the center of the good bolt so I can use it as a drill guide. That way I can get a good, centered pilot hole drilled and maybe then have better luck using an extractor or even a reverse direction drill bit.
I'm really hoping I don't have to tear it apart to get this done.
Thanks a lot for any advice or help you can give me.
Scott
ElCoSix is offline   Reply With Quote
Old 06-12-2018, 01:04 PM   #56
70STOVEBOLT
70STOVEBOLT's Avatar
250's dont have a crank bolt. The damper presses on.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-12-2018, 03:45 PM   #57
jfnar
I don't know if this even exists but I'm looking for a three groove water pump pulley that matches the groove spacing on my 292 balancer. The gap between the front and middle grooves is a little bigger than the gap between the middle and back grooves. Thanks.
jfnar is offline   Reply With Quote
Old 06-12-2018, 04:41 PM   #58
70STOVEBOLT
Never seen a 3-groove water pump pulley. A 250 pulley is different than a 292 pulley though.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-05-2020, 04:51 PM   #59
rdhowe2006@yahoo.com
rdhowe2006@yahoo.com's Avatar
I am in need of a IL 6 Cylinder 230 or 250?
rdhowe2006@yahoo.com is offline   Reply With Quote
