Old 10-07-2017, 08:08 PM   #51
Black_Sheep
Black_Sheep's Avatar
Re: Brother's keeper - '58 Stepside build
Got the lower dash, column and column drop painted white, then followed with 2 additional coats of white micro flake. Also applied the first round of straight clear. A couple of suicidal gnats landed in the clear so I'm going to let it dry so the bugs can hopefully get picked out...
Black_Sheep is offline   Reply With Quote
Old 10-14-2017, 06:44 PM   #52
Black_Sheep
I had to let the clear dry and sand the bugs out. I reshot the lower dash today with straight white and a few coats of clear. No metal flake this time around, no bugs either...
Planning to get the green laid down tomorrow.
Old 10-14-2017, 09:57 PM   #53
Advanced Design
Advanced Design's Avatar
Dash is looking good. Gotta watch the suicide gnats!
Advanced Design is offline   Reply With Quote
Old 10-16-2017, 11:05 PM   #54
Black_Sheep
Finally got some color on the jambs and inside the cab. After spraying the green I unmasked the lower dash and gave everything a few rounds of clear.
The color does not photograph well under fluorescent lights, I can't wait to see it in natural light.
Old 10-17-2017, 12:35 AM   #55
Scottish58chev
Looking nice
Scottish58chev is offline   Reply With Quote
Old 10-17-2017, 10:25 AM   #56
Dan in Pasadena
Dan in Pasadena's Avatar
Looks great!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-18-2017, 11:55 PM   #57
Black_Sheep
Thanks guys. My wife got home from California last night and she really liked the color. What a relief, she's normally not a fan of green.
Old 10-19-2017, 10:35 PM   #58
Black_Sheep
Gave the dash a quick cut and buff to clean up some dust nibs. The smoothed dash was a little too plain so I added a '63 Impala fender emblem to give it a little bling...
Old 10-20-2017, 10:13 PM   #59
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice touch!!
ChuckDriver is offline   Reply With Quote
Old 10-22-2017, 08:31 PM   #60
Black_Sheep
Getting ready to set the cab back on the frame so I cleaned a summers worth of dust, dirt and cobwebs off the chassis.
Old 10-28-2017, 09:03 AM   #61
Black_Sheep
This weekend’s garage goal is to set the cab back on the frame. There were several small jobs completed in preparation. The brake system was filled with DOT 5 brake fluid and bled. I also made a set of battery cables with 1 gauge fine strand copper cable, crimped copper lugs and mil-spec terminal ends. The cables are covered with a protective spiral wrap So they should be darn near bulletproof. Both of these tasks were far easier to perform before the cab goes back on.
Old 10-28-2017, 01:43 PM   #62
Black_Sheep
Cab went on so easy it was scary...
Old 10-28-2017, 10:14 PM   #63
Black_Sheep
In addition to setting the cab back on the frame today, I finished putting FatMat Rattletrap on the floor and firewall. Tomorrow I plan to fit the inner fenders which will need some minor trimming to work with the smoothed firewall and possibly get the column mocked up so I can make a new floor plate for it.
Old 10-28-2017, 11:30 PM   #64
oldman3
oldman3's Avatar
Looking great...Jim
oldman3 is offline   Reply With Quote
Old 10-29-2017, 12:35 PM   #65
Black_Sheep
Originally Posted by oldman3 View Post
Looking great...Jim
Thanks Jim
I slid the instrument cluster in just to see how it looked with the smooth dash
Old 10-29-2017, 01:26 PM   #66
Indian113
Indian113's Avatar
That Dash Turned out Super Nice, Outstanding color combo
Indian113 is offline   Reply With Quote
Old 10-29-2017, 05:04 PM   #67
Black_Sheep
I got the column assembled without any chips or scratches and mocked it up so I can make a new floor plate...
Old 10-29-2017, 07:34 PM   #68
MIKESAD50
Your truck is looking great.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 10-29-2017, 11:17 PM   #69
oldman3
oldman3's Avatar
Very clean and looks great...Jim
Old 11-04-2017, 06:07 PM   #70
Black_Sheep
I fabbed a floor plate for the column to support where it passes through the floor. With that done, I could get the trans linkage all dialed in.
Due to the smooth firewall a little fitting on the inner fender panels was necessary. I'm pretty happy with the outcome, inner fenders will receive a coat of matte white to match the firewall...
Old 11-05-2017, 09:31 PM   #71
Black_Sheep
After a lot of measuring and a little tweaking to get the cab square on the frame I torqued the cab mount bolts down. Same deal with the core support, it's now straight and square with the cab too.
I still had a couple hours of free time before my granddaughter's birthday party so I bolted the freshly painted grille brackets onto the grille with some 1/4" stainless flange bolts and made up a 6AWG cable to feed power to the cab. The insulated stud will provide a handy place to connect a timing light...
Old 11-09-2017, 08:43 PM   #72
Black_Sheep
I got the throttle pedal and cable installed the other night and figured out the brake pedal placement. I stopped by a local fab/welding shop to ask about having the pedal reworked and the owner turned out to be the president of the state Chevrolet and GMC Truck Club. Nice guy and he totally understood what I was trying to accomplish...
Old 11-10-2017, 12:46 AM   #73
BC Toy chest
BC Toy chest's Avatar
Nice work , gr8 looking ryde, keep the pictures coming.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 11-11-2017, 06:31 PM   #74
Black_Sheep
I got the fuse panel installed and started to run some wiring. The trans kick down, neutral safety switch and brake light switch circuits still need to be added, then the engine compartment will be done...
Old 11-13-2017, 09:01 PM   #75
Dads Burb
What steering column are you using? Looks like you are using the stock column support.
Also noticed that you had a smooth cowl vent cover. Is that one that you fabricated or is that the fiberglass one?
Any plans to add side plates where you extended the cab floor?
Dads Burb is offline   Reply With Quote
