10-18-2017, 10:16 PM | #51 |
Re: How should I fill firewall holes
nuthin wrong with that, it cleans it up really nice, as long as it doesn't rub or rattle it's all good.
your truck,your idea, you're good with it. thats what counts. |
10-18-2017, 10:28 PM | #52 |
I wanted an overall clean, smooth look so I did a steel overlay. As the pictures show, no welding was involved. I resisted "gluing" them on but a couple experienced bodymen convinced me that it was the way to go due to no warpage and minimal finishing associated with the process.
Fitting poster board templates After prepping I used 3M panel bond adhesive to attach the 18 gauge sheet metal panels. Edges beveled and blended with filler. Primed and painted... I'm really happy with the end result |
10-19-2017, 09:04 AM | #53 | |
Life lesson: Don't hold onto a stationary thing while using a spinning thing.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
10-19-2017, 07:48 PM | #54 |
If you know an electrician with a toolbox, he probably has a whole bunch of 1/2", 3/4", and 1" KO punch outs from metal boxes. Those work good too for larger holes. or just buy a few metal boxes from HD or lowes and take em out yourself.
Also roofing nails work good for small holes - they have a BIG head....
My Build: 57 Chevy Pro-Street |
10-19-2017, 07:52 PM | #55 |
just try to get the knock outs that are plain metal, not zinc coated.
10-19-2017, 08:59 PM | #56 |
Haha, I had some outside and ran out to check...dang it zinc.
10-19-2017, 11:54 PM | #57 |
it is just plating so you could always sand/grind it off if you need to.
11-27-2017, 08:30 PM | #58 |
borrowed from another thread, just throwing the link in here for a future couch mechanic
Hole fill kit https://www.bobdrake.com/FordItem.aspx?Item=HR-1580
09-04-2020, 08:12 PM | #59 |
How about bead rolled firewall filler panels from LS Fab? $140 and give a super clean and custom look to the engine bay. Instruction available on the website to help with the install and can be used a replacement panel or put over top the original firewall if wanted.
09-04-2020, 08:41 PM | #60 |
If you want the stock look, and are not afraid of work,
Drill hole with step drill to get it round and a normal size you can buy filler plugs for Clean area around hole to bare metal for a good weld Buy some "unholes" from welders series online Hold in with a magnet till tacked. Magnets distort weld so take them off asap Weld plug in after racks completed in 4 spots around the circle Beware of heat build up and distortion caused from that. If you have a helper have them hold a dolly on the backside while still smoking from the weld. Then hammer the weld a few times to help with the shrinkage caused from the weld heat/cool. Or, glue a larger plug on the backside and then fill the void with bondo if you dont have a welder |
11-04-2020, 04:56 PM | #61 |
I just made my own with snips and a bench grinder. you can weld a piece of wire hanger to the middle to get a hold of those small ones and magnets for the bigger ones. This is the area I started on to teach myself how to spot weld. A little bit of Rage gold and you are done. It takes a while but it wasn't too bad. I put blue tape over all the holes I knew I would be reusing so I didn't get carried away lol and filled up the rest.
