Old 09-30-2018, 03:27 PM   #51
jdl71
jdl71's Avatar
Re: 66 k20
And what a shocker, something doesn’t jive. The wheel cylinders are 1” and 1/4, not 1” and 1/8” like the fronts, or like is listed in the fsm. Not really an issue I guess they weren’t pitted and the cups are still pretty supple. Gave it a quick hone and run through the parts washer so I will probably just put them back together. The drums are another matter, the machined surface measures about 12.5”. Once again referencing the manual, 1.25 wheel cylinders came on p30 and c30 with 13” brakes. Is it possible these drums have wore down half an inch?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 09-30-2018, 03:31 PM   #52
jdl71
jdl71's Avatar
Re: 66 k20
A second look gives me a 12.25 in measurement which makes even less sense. There’s a pretty good ridge in the middle all the way around so I know these have wear. I know the tape measure doesn’t look centered but it is. Am I measuring this the correct way?
Psalm 23
64 C10
66 K20
Old 09-30-2018, 06:35 PM   #53
jdl71
jdl71's Avatar
Re: 66 k20
What is this and what’s its purpose? It was on the inside of the drum.
Psalm 23
64 C10
66 K20
Old 09-30-2018, 06:37 PM   #54
jdl71
jdl71's Avatar
Re: 66 k20
And finally is there any reason to go past this point and remove the backing plate? Is there another seal behind there?
Psalm 23
64 C10
66 K20
Old 09-30-2018, 07:54 PM   #55
1972RedNeck
1972RedNeck's Avatar
Re: 66 k20
I think it is to keep any oil off the brakes if the wheel seal were to leak.
No and no, unless you want to clean it up and paint it.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-30-2018, 08:52 PM   #56
jdl71
jdl71's Avatar
Re: 66 k20
Thanks!
Psalm 23
64 C10
66 K20
Old 09-30-2018, 10:17 PM   #57
aotte1
Re: 66 k20
In post #54 you ask about a seal. On a 66’ C20, with Eaton HO 52 axle rear their is a cork seal. I am planning to use some “Right Stuff” on the outside of this, to seal it. My 64 C20, with same axle, had a seal, not sure of the marerial, it was in bad shape. Will try to find photos. Planning to take one apart this week.
Les
aotte1 is offline   Reply With Quote
Old 09-30-2018, 10:30 PM   #58
aotte1
Re: 66 k20
Front brake hoses
A brake hose speciality company made mine. Will try to remember to get you the company name and address. They may have been located in MI. If I forget please ask me for it.
Les
Old 09-30-2018, 11:49 PM   #59
Captainfab
60-66 Nut
Re: 66 k20
I would say that your drums are worn about .250". You will likely have to make the change to 14 bolt drums since those HO52 drums are no longer available.
Old 10-01-2018, 10:34 AM   #60
jdl71
jdl71's Avatar
Re: 66 k20
Rockauto actually does list them.
Psalm 23
64 C10
66 K20
Old 10-01-2018, 10:50 AM   #61
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 66 k20
Looks good.
66 C20 Service Truck:
Old 10-01-2018, 01:11 PM   #62
Lokin4AReason
Lokin4AReason's Avatar
Re: 66 k20
nice progress ...
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 10-01-2018, 06:39 PM   #63
jdl71
jdl71's Avatar
Re: 66 k20
Les
If you're referring to a seal between the backing plate and axle tube, I'm not going that far right now. I found the wheel seal that goes in the hub locally.
Psalm 23
64 C10
66 K20
Old 10-01-2018, 06:40 PM   #64
jdl71
jdl71's Avatar
Re: 66 k20
Front brake hoses
Les
I've got something cobbled together for now, but I would be interested in that. Thanks!
Psalm 23
64 C10
66 K20
Old 10-01-2018, 08:20 PM   #65
jdl71
jdl71's Avatar
Re: 66 k20
These are the shoes that were on the left rear. Yes they are both the same.
Psalm 23
64 C10
66 K20
Old 10-01-2018, 08:22 PM   #66
72cs20
Re: 66 k20
Next, brakes. What a nightmare. I knew going in that some of the stuff would be hard to find. I did not know how hard. Hoses do not exist anymore. This is the solution myself and my napa guy could come up with:
Jdl71,
The steering arm and brake hose set up on your truck are quite different from mine. Does your K20 have the rare HD Dana 44?
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 10-01-2018, 08:25 PM   #67
jdl71
jdl71's Avatar
Re: 66 k20
Originally Posted by 72cs20 View Post
Jdl71,
Unfortunately, yes.
Psalm 23
64 C10
66 K20
Old 10-02-2018, 12:26 AM   #68
Captainfab
60-66 Nut
Re: 66 k20
I stand corrected. I was under the impression that the drums were no longer available.
Old 10-02-2018, 12:53 AM   #69
raylube
raylube's Avatar
Re: 66 k20
I will soon be pulling my k20 with Eaton rear and may need drums also. Just wondering if you have verified those rock auto drum will work. Shoes are 2 inches wide and these drums spec is 2.43
raylube is offline   Reply With Quote
Old 10-02-2018, 08:10 AM   #70
jdl71
jdl71's Avatar
Re: 66 k20
It’s supposed to be here tomorrow. I saw that also so I measured the old drum and found that it’s over 2” wide on friction surface so it should work.
Psalm 23
64 C10
66 K20
Old 10-02-2018, 11:02 PM   #71
aotte1
Re: 66 k20
Custom Brake Hoses- please see photos. Have used them, no issues, on 64’ K10.
Les
Old 10-04-2018, 06:53 PM   #72
jdl71
jdl71's Avatar
Re: 66 k20
Les
Thank you Les.
Psalm 23
64 C10
66 K20
Old 10-04-2018, 07:23 PM   #73
jdl71
jdl71's Avatar
Re: 66 k20
Haven’t actually put it on, but looks pretty good to me.
Psalm 23
64 C10
66 K20
Old 10-05-2018, 12:13 PM   #74
Lokin4AReason
Re: 66 k20
looks about the same with it being a little wider in width ( as in width of the brake pad )
Old 10-05-2018, 01:49 PM   #75
jdl71
jdl71's Avatar
Re: 66 k20
It does look like that but i measured and it’s within 1/8 of an inch at most.
Psalm 23
64 C10
66 K20
