Old 12-24-2017, 09:23 PM   #51
72Cheyenne454
72Cheyenne454's Avatar
Re: BBC Turbo 400 to LT4 T56
What an awesome truck and a nice job with the fab work.
I'm watching daily for updates.
Miles
72Cheyenne454 is offline   Reply With Quote
Old 12-25-2017, 02:36 PM   #52
88Stanger
88Stanger's Avatar
great build so far!!!
88Stanger is offline   Reply With Quote
Old 12-27-2017, 10:36 PM   #53
Trackman101
Trackman101's Avatar
Unhappy Re: BBC Turbo 400 to LT4 T56
Thanks for all positive feed back!
I guess I'm in the dog days of the build now. I am waiting for some aluminum to be broke for the fuel tank conversion and for the fan shroud set up. In the mean time I have been tinkering with wiring. I've rerouted the wiring up front to go under the radiator instead of above and have added a couple wires for the electric fans and oil cooler fans. All the wiring is removed that crossed up by the cowl. Mounted a couple of the Dakota Digital components in behind the gauges. The main control box is held in place by a bracket attached to the steering column brace and industrial strength double sided sticky tape. (the gorilla tape is holding the insulation secure!) Plan to start wiring it in the next few days.
..found an issue with my light switch
Trackman101 is offline   Reply With Quote
Old 12-30-2017, 08:29 PM   #54
Trackman101
Nothing glamorous...
Wiring is actually going better than I thought. I've got the Dakota Dash wired up, battery cables ran, starter hooked up,alternator feed connected. I am not suggesting I will not have some electrical gremlins when It comes to starting it but it is progressing faster than I had planned.
Found a little ambition and started working on the metal work to the tunnel to get the huge wiring cable into the truck and placed under the seat.
Old 01-01-2018, 12:08 PM   #55
BossHogg69
motor exploder
BossHogg69's Avatar
Those rear Michelin's don't stand a chance against the torque they're about to deal with... If I see correctly, they're a 345/30/20? I'm running the same width tires you're running (275 fr/345 rr), but on a 19" rim.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-02-2018, 12:29 AM   #56
Trackman101
Correct 345/30 20 on the back.
I'm running a 275/40 19 on the fronts.
I regret a little bit going with a 12" rim on the back. It really limits tire options.
If I did it again I 'd go with 11" wide and run a 305/35 drag radial. Still could I guess but it would look a little goofy.
Old 01-02-2018, 08:13 PM   #57
Trackman101
Got around to unboxing my Ididit column. (sold the original shift column with the old engine and trans)
Should there be a notch/slot cut out to align the column to the dash bracket? I purchased a 67-72 column but it came with universal instructions. I am surprised it didn't come with a slot to align it.
Old 01-02-2018, 09:21 PM   #58
BossHogg69
motor exploder
BossHogg69's Avatar
My Flaming River column didn't come with any locating notch/tab/mark either. I installed it loosely and rotated it around until I thought it was 'straight'. Maybe the Ididit is similar in that regard?
Adam
Old 01-07-2018, 06:48 PM   #59
Trackman101
Finished modifying the fuel tank for the pump and Holley hydramat. I can't take credit for the nice welds. I am only set up to mig weld aluminum at my garage. Unfortunately it didn't pass my pressure test after I installed the mat, pump and fuel sender. I found two pin holes in the corners. Once I get those fixed I'll connect the fuel line, vent and electrical and mounted it back up into position. That should be it for the fuel system.
Old 01-08-2018, 12:46 PM   #60
Trackman101
Fan shroud is built. The ECM comes with a 2 fan relay set up which is nice. I've got a monster 2 speed fan and and a little guy to help out. The 17" comes on at 195 I think and high speed and the second fan will activate at 212 I believe. The factory settings are higher than I am comfortable with coming from a big block but I'm sure the GM engineers know what they are doing.
I've got it mocked up but have a ways to go with mounting it in.
Old 01-08-2018, 02:51 PM   #61
nuke1
nuke1's Avatar
awesome build so far!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-26-2018, 11:42 AM   #62
Trackman101
I've got the high hump trans cover notch finished and mounted back in the truck. It will be interesting to see how well the carpet fits. Power steering lines built for my experiment with hydroboost using a Mustang set up. I think that's it for plumbing!
I am still messing around with a cold air box on the driverside and still haven't come up with a real good plan yet for mounting the GM fuse block. I wish the harness was another 4 inches longer.
I need to get some ambition and finish a bunch of things that I've half finished.
Old 01-29-2018, 01:58 AM   #63
Oly72C20
Wow! What an amazing build! I have been away from the forum for quite awhile and man am I glad that I found this thread! I can't wait to see the final outcome!
Joe
Oly72C20 is offline   Reply With Quote
Old 02-09-2018, 12:11 PM   #64
Trackman101
....the dog days of February.
A pic of the tunnel and pass through for the ecm harness.
Not much to report. Still working on the airbox. Somehow it's turned into a complicated piece. Once it's done I think I am done fabrication and can send off a bunch of pieces to powdercoat. Bench bled the m/c.Power steering fluid is in. Finally came up with a place for the GM fuse block. It requires some billet hood hinges to allow it to fit where I want. Battery cables are built. I lied when I said I as done the plumbing. Still waiting for a fitting for the hydraulic clutch and the A/C system still has some head scratching to do .
I am wanting to paint my radiator, condenser and heat exchanger. Obviously powdercoating those pieces are not an option. Can anyone suggest a good product that will bite to bare aluminum?
Old 02-15-2018, 09:46 PM   #65
Trackman101
....3rd times the charm
Finally got the correct hydraulic clutch connection for the T56 Magnum.
With a little luck I might get a few pieces back from the powder coaters tomorrow and do some final assembly for the radiator ,supercharger heat exchanger and air box.
Old 02-16-2018, 06:52 AM   #66
builtbyKane
builtbyKane's Avatar
It's looking great so far. Hopefully you found a paint solution to share with the rest of us.
builtbyKane is offline   Reply With Quote
Old 02-16-2018, 07:50 AM   #67
BossHogg69
motor exploder
BossHogg69's Avatar
I don't have a blower or heat exchanger, but I did paint my aluminum radiator in same base coat & satin clear I used on everything else under the hood. It's held up well so far.
Adam
Old 02-16-2018, 08:58 AM   #68
meenaggie
I have had good success with Eastwood Radiator Black. I used their Satin Black. Lay on thin coats and spray the fins from multiple angles. I took the shroud off and painted it as separate pieces so I could get all the surfaces coated. Don't spray it in direct sunlight on a hot day or onto a warm surface . . . that can cause the finish the be rough as the paint will start to dry too quickly. This product is more sensitive to that issue than other spray paints I have used. Nice truck by the way.
https://www.eastwood.com/ew-radiator...in-finish.html
meenaggie is offline   Reply With Quote
Old 02-16-2018, 08:45 PM   #69
Trackman101
I think I have the rad in for the last time. Air box is done except for a small lexan window I need to glue in. New hood hinges are expensive as hell but are a high quality piece. I now have room to mount the GM fuse block between the passenger hinge and a/c. Time to throw some fluids in!
Old 02-16-2018, 10:54 PM   #70
72Cheyenne454
That is slick. Looks factory... like it came right off the GM assembly line.
Nice job!
Old 02-16-2018, 11:14 PM   #71
Jason7121
Jason7121's Avatar
Could you tell me what brand the hood hinges are and where can I get them. Your build looks awesome!
Jason7121 is offline   Reply With Quote
Old 02-17-2018, 01:55 AM   #72
Trackman101
Thanks for the positive feedback.
I ordered the hinges from Ring Brothers. They are bloody expensive but they are very high quality and the only ones I could find that would work with the factory ac/heater box.
..I emailed them for a discount and they sent me a 10% off code.
Old 02-17-2018, 02:21 AM   #73
Jason7121
Jason7121's Avatar
Ok perfect I was looking into ring brothers but wasn't sure how they would fit .
Old 02-17-2018, 07:31 AM   #74
BossHogg69
motor exploder
BossHogg69's Avatar
x2 on the Ringbrothers hinges. I put the black anodized 'air frame' hood hinges on my truck a few years ago and the are very nice. Open & close very smooth and look great.
Adam
Old 02-17-2018, 09:04 PM   #75
clay68c10
clay68c10's Avatar
Wow!
I just read thru this, very nice work you are doing there. Very cool you are going with the Tremec. I'll be using a TKO in mine.
Is that the Capt Fab master cyl kit?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
