01-19-2018, 07:20 PM | #51 |
Re: Anyone running CB's in their truck these days?
This thread just brought a smile to my face, I was thinking I was the only one left out there in CB land. The CB radio still has it uses for things. As stated above at Bonneville, also Off Roading, Boating, Swamp buggies, Backwoods/Basecamp coms.,Even Air to bush supply drops. They are overlooked mostly in todays electronics world. But they are still available, and with free airtime, Also stated above about "SKIP" radio and sidebands, I have a hopped up old Galaxy with them, its been shelved for years but I used to talk all over the country and some over oceans with that radio, add a little Linear heat from top a big hill and the air waves would take you world wide at times I have a Cobra 29LTDW now. I'm an avid outdoors-man so weather comes in handy now and then. I had it peaked, and tuned back in the late 90's and it still works great to this day. I never power it by 12volt "socket", hard wired to + terminal of the battery and a sufficient ground also under the hood compartment. I used a HD inline fuse, that has a power kill switch also. For my antenna, I have to say, I love my Wilson's. I have a magnet mount 1000 on my 72, but have a "Lil Wil" mag mount for other Vehicles,ATV's, Boats, etc... There are alott of aftermarket gadgets, doo-dads, decals, noise toys, all over flEbay for the 29. The magnet mount antenna are great as you can place them anywhere metal, for paint protection, Just put a scrap of silk between the mount and the surface. all the Wilson antenna's are very easy to set SWR's by a pair of set screws at the base of the stainless whip. "FWIW" on all my vehicles, toys i also use a simple Red/Black quick 12 volt disconnect and have the same end pre wired/installed, and several mounting brackets for the Cobra 29 so I can just swap the radio and the antenna if needed from one ride to the next. If I Buy another one, It will be this one. IMO i think it still has a Nostalgic look to it, and the night colors go good with the factory gauges in our trucks.
72 C/10, LWB, 5.7, Auto, with A/C F.B.I = Full Blood Indian Appalachia/Eastern Cherokee,"Tsalagi" Last edited by cherokeejohn; 01-19-2018 at 07:34 PM. |
01-19-2018, 09:54 PM | #52 |
Got this one from a neighbor . Not real sure of application. He said it was from a 70's Chevy pickup. Kind of cool with 8 track AM FM and Cb all in one.
01-19-2018, 09:55 PM | #53 |
01-20-2018, 01:48 AM | #54 | |
I had [have still] a string of Johnson Messenger transcievers. I [''Whiteface''] and II [''Blackface''] are tube-type and as big and long as mailboxes. Then the Messenger III [ or 123?] is solid state and about the size of yours. Not sure if any of them work, but those tube rigs really broadcast it out, even barefoot. They were built with 5 watts final out, not the 3.5, later mandated by Uncle Charlie. With a good base location [Burbank side of Hollywood Hills] and a HyGain CLR omni antenna, I once got out with my Whiteface on the north/south skip layer [E or F?] and QSO'd with a YL on the south slope of Mount Saint Helen's. It was about midnight and it was 1967. I have a Radio Shack SSB mobile on a tiltstand I can place in the passengerside footwell, that can switch between vehicles. It works, but with the magmount stubby, the SSB effect is wasted. Also need to trick up the glaring white early model LED screen with some translucent blue gel. Well threes and eight there Buddy, the OrangeSunshine is over and out.
01-20-2018, 02:22 PM | #55 | |
That's a square radio Paul - I really like them also. Difficult to fit in a 67-72 without dash mods that you may find difficult to make work with the 67-72 dash indent for the stock radio that is really sized to be proportional to and wrap the face of a 67-72 radio. I wish they were a direct fit, that would sure be nice wouldn't it? If you EVER think you might buy a squarebody, I'd get that thing working and horde it away. I never thought I'd buy a square - but then I changed my mind I'd be curious to see if anyone else has successfully integrated a square radio into a 67-72 and how they did it, etc. We really never see these in 67-72's, and if it were an easy swap, I bet thousands of folks would've done it in the 70s and 80s. |
01-20-2018, 02:35 PM | #56 |
BlahBlahBlah
I say keep it rolling with CB info here instead of splitting it up. This can become the "official cb in your truck" thread =)
Ive already learned a lot.
01-20-2018, 05:24 PM | #57 | |
For my part, I don't care where they put the CB-related threads, as long as we keep the QSO going. We can keep it here or the Mods could move us over there, but most folks don't think of CB as an audio device anymore. It seems more like it's a quaint, obsolescent vintage accessory to them, since they have no working knowledge of the 2-Way medium and its traditions.
01-20-2018, 05:53 PM | #58 |
01-26-2018, 11:09 PM | #59 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-27-2018, 01:11 AM | #60 |
I purchased this CB on the board a couple years ago from 70cst and I now have the truck I want to put it in. Not sure what all is involved or what is needed to get it up and going so been following this thread trying to figuring out all the different items needed......any advise would be great. To start with I will need a mounting bracket any available for this unit. Can someone advise proper power supply ? Should it come from fuse box ? Key switch ? Types of available antennas ? The truck I want to put the CB in apparently had one at one point as the ash tray has the microphone clip attached to it. (see pic) Thanks for any help.
01-28-2018, 09:46 AM | #61 |
I have this GM CB in one of my trucks
01-28-2018, 05:14 PM | #62 | |
Or, if you want it to move between trucks, you could power it with a cigarette lighter plug. If you connect to the fuse box, it's your decision whether you want the radio to be turned on even if the key is out, or go off with the key. Antennae: The 1/4 wave 108''[?] whip is the best. Twin Truckers [''Rabbit Ears''] are cool and if you're sporting West Coast Junior mirrors, you can mount them there. If moving the rig between trucks, you'll want a magnetic mounted stubby. These are OK for copying the mail, but don't get out [transmit] very well. The antenna socket in any CB rig is an SO-239 and the antenna line connector is a PL-259. Antenna cable is a sheathed coaxial type with internal resistance of 50 Ohms, type RG-58/U. It's important you get the proper resistance cable as without it you will burn up the final stage of your transmitter. Don't transmit without an antenna or a dummy 50 Ohn plug, or you will ''let the Blue Smoke'' out. Truck stops are the best current source for these things, as Radio Shack has folded. If the manufacturor's supplied mounting bracket has been lost, you can make your own out of light gauge strap steel. You'll want a piece, less than 2'' wide, that's the width of the rig across the back, plus the sides. Bend the sides down, radius them and drill 1/4'' holes in the centers of your 'ears' for the mounting thumbscrews. These screws can be had from Ace Hardware and are 1/4''-20 with round, black plastic knobs. If you want to go cheap and fast, you could use perforated 'plumbers tape'.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-28-2018 at 05:27 PM. |
01-28-2018, 05:44 PM | #63 |
Stan 67 swb BLU MULE posted via flip-fone |
01-28-2018, 05:57 PM | #64 |
72 BB C30 Super LongHorn
Gonna have to pull out some of my stuff for sharing
Built in slider for extra channels
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 01-28-2018 at 10:48 PM. |
01-29-2018, 11:38 AM | #65 |
Breaker breaker good buddy...what's your 20? Catcha on the flip flop!
1970 C10 Short Stepper with 71/72 front clip. |
01-31-2018, 09:42 PM | #66 |
Great info thanks ‘68OrangeSunshine.......
02-16-2018, 11:40 PM | #67 |
Have a new to me 1969 GMC C2500 looking for a vintage 70/80s cb to put in my truck any idea where to start looking for one?
02-17-2018, 01:34 AM | #68 |
Swap meets, C-list, yard sales, flea markets, flea bay, truckstops, guy down the alley. Where-ever. Being vintage specific is getting picky. I would just want one that worked. The early ones just had 23 channels. Not so fun if your Buddy's up on 40 and you got no ears that swing that way.
02-17-2018, 02:08 AM | #69 | |
Put in Vintage CB ---------------------------------------------------------------------------------------- Up until about 74 all the CB's were 23 channels. Some might have had Upper Side Band and Lower Side Band. After about 74 CB's went to 40 Channel.
02-17-2018, 02:12 AM | #70 |
I'll repost but this will be my CB Radio "Kris XL-50, Varment Amp, and Avanti Mirror mount Dual Antenna.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 02-17-2018 at 02:59 AM. |
02-17-2018, 02:44 AM | #71 |
Lets talk CB ...
Ancient Mariner -AM radio/frequency Baby Bear- Cop in training, or rookie Back ‘em up -Slow down Back off the hammer -Slow down Bear Bait -Speeding car Bear Cage- Police station or jail Bear Cave -Police station or barracks Bear Trap -Stationary police vehicle with radar Bear in the air- Helicopter or other police aircraft Beat the bushes -To drive ahead of the others and try to lure out the police Beaver Bait- Money Beaver Fever -A CBer who misses his girlfriend or wife Benton Harbor Lunch Box -Heathkit CB-1 Black’n White- Cop Breaking the ‘ol needle- Strong signal Bring it back -Answer back Brown paper bag -Unmarked Police car Brush your teeth and comb your hair-Radar trap ahead Bubble gum machine- Flashing lights on top of car Bumper Lane- Passing lane Cash Register -Toll booth Chew ‘n choke -Restaurant Checking My Eyelinds For Pin Holes -Tired or sleepy. Check the seatcovers -Look at that passenger (usually a woman) Chicken Coup- Weigh station Chicken Coup is Clean -Weigh station is closed. Christmas Card- Speeding ticket Coffee Bean- Waiter or waitress Coke stop- Restroom Colorado Kool Aid -Beer Comic Book -Truckers log book Concrete Blonde -Hooker Convoy- 2 or more vehicles traveling the same route. Cooking Good -Reached desired speed. Copy -Receiving a message: “Do you copy?” Crack’em Up -Accident Cut Some Z’s -Get some sleep Dead Pedal- Slow moving car or truck Dead Key- Activating the microphone, but not talking. Same as “keying the mike”. Diesel Juice -Fuel oil Doing the Five-Five- Traveling at 55mph Don’t Feed The Bears- Don’t get any tickets Down and on the side -Through talking but listening. Dream Weaver- Sleepy driver who is all over the road. Dress For Sale -Hooker Dressed for the ball -You have your “Ears ON”, listening to the road conditions Drop the Hammer -Go as fast as you can Dusted my britches -Passed me
02-17-2018, 02:49 AM | #72 |
02-17-2018, 03:02 AM | #73 |
How much juice does that Varmint kicker push?
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-17-2018 at 04:32 AM. |
02-17-2018, 03:06 AM | #74 |
If you are talking power - about 100 watt Amp Draw - I am guessing about 30 amp max
02-17-2018, 04:34 AM | #75 |
I aways got out barefoot. But power is its own reward.
