03-20-2018, 02:00 PM | #51 |
GM Addicted
Re: Install thread- Holley EFI Sniper on '72 402 big block
My concerns are really for the fuel pump having to draw the fuel up the stock line in sending unit then down to pump. Also as stated with a carburetor you have fuel bowls which are little reservoirs for fuel. With EFI you do not have that, A GM TBI unit can’t compare it only requires 15 psi not the 60 the efi requires. I’ve read a few people wanting to route the same way you are and landed up putting bungs on bottom of tank.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
05-13-2018, 02:06 PM | #52 |
A pause in progress since finding the crack in the intake manifold. Got the intake off and the heads cleaned up, in anticipating of installing a replacement intake manifold. Then, everything back together, add coolant, start er up, and pick up where I left off.
Clean left. Dirty right.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
05-13-2018, 07:20 PM | #53 |
subd
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
05-13-2018, 11:30 PM | #54 |
I fitted the Sniper EFI to the 396 in my truck and picked up a bunch of low down and midrange torque. The throttle response is way better. But the gas pedal was so touchy I had to make a small extension for the linkage where the rod hooks up.
Yours appears to be a cable so you may not have the same issue. Overall I’m very happy with mine. Here’s a pic of the extension
John 69 c20, 396, th400, dana60, ps, ac |
05-14-2018, 12:09 PM | #55 |
Cool! I'm at almost the same point, hooked up the linkage on my Sniper last night.
I'm excited to see how it drives. I had a Q-Jet on an oval port manifold on roval port heads and I've also put the port-matched intake back on so that should help as well. I'm not doing computer timing control, did you? Here's the fuel lines I bent up yesterday!
05-14-2018, 05:12 PM | #56 | |
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
05-14-2018, 05:58 PM | #57 |
Those lines look great. No timing control on my setup.
05-15-2018, 09:54 AM | #58 |
As long as none of my lines leak (this is my first time ever doing stainless with AN fittings) I think it'll be a killer setup. Like you, I'm going to forego timing control at least at first as well, maybe do that as a second project, but I haven't heard great things yet about it.
I haven't checked the geometry yet, I have solid pedal linkage as well. I had to drill the hole larger to accommodate the linkage though. Once installed with plastic bushings it was nice and solid, but I'll have to wait and see if I have the same sensitive pedal that you did.
05-15-2018, 11:17 AM | #59 |
I'm not having the computer control timing. As I understand it, I have to buy a specific distributor that has a plug in for the Sniper system. I've watched the video of the setup. It's out of my level of experience, so I'll likely get some help if I go that route in the future. I like the idea of combining EFI plus timing control to get max performance, all automatically with a computer.
05-15-2018, 11:44 AM | #60 |
Assuming your distributor is well set up for your engine, I don't think there's much performance advantage to be had. But it can in theory help smooth the idle by adjusting individual spark pulses. That's the only feature I'd actually like.
They give you a coil driver so that you don't have to run a full ignition box, that's kind of interesting. I have an MSD dual sync with the same purple and green wires, but I'm not sure if I can make it work with the Holley and am a little scared of biting off more than I can chew in trying to do the install with a non-supported third party pickup!
05-15-2018, 05:38 PM | #61 |
A lot of people have had trouble getting their msd distributors to play nice with the timing control function. I think the Holley dual sync is probably the best option if you want to use timing control and of course more expensive than msd. For me, not worth it at this stage.
05-17-2018, 01:58 PM | #62 |
Got mine all up and running (not a truck, but I'll try to stick a photo in anyway). The throttle is SUPER touchy, as you say. I'll order a Holley throttle extension or make one, I guess.
Was yours better with the extension? With a deep four speed a 4.10 gears it's a little touchy to drive! By which I mean "almost impossible to drive safely" as it is. They really ought to include that extension if they're all like that.
05-17-2018, 06:20 PM | #63 |
I'm curious for those who have installed a Holley Sniper kit and have used the supplied Holley electric in-line fuel pump, is the electric pump noisy?
Thanks, Miles |
05-17-2018, 06:20 PM | #64 |
Sorry about the thread hijack Ekliptix but I figure this is useful info.
davepl, the throttle extension made a big difference for me. But Holley also has a progressive linkage available which you can adjust the snipers software for. It reportedly makes a big difference. Here’s the info on it. https://forums.holley.com/showthread...I-WAAAY-Better
05-18-2018, 10:37 AM | #65 |
I'm not using the Holley pump, but a Tanks Inc module which has a factory style pump inside the tank. You can hear it a little.
Yesterday once the fuel got hot after 30 minutes or so of driving it was noticeably louder. Much quieter in tank than the old Holley blue or black pmp hanging off the frame though!
05-18-2018, 11:15 AM | #66 |
Proprietor of Dale's Corner
Subbed
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
05-18-2018, 07:39 PM | #67 | |
Who Changed This?
05-19-2018, 04:28 PM | #68 |
Yes, the passenger side port is the return line, so there's a constant high-speed flow of 60psi fuel past it at all times. When there's no draw from the engine, the pump is basically pumping full blast at all times circulating fuel, so it'll never sit in the lines.
It could over time heat up the fuel in the tank though! Now there's a 16' fuel line run that'll help cool it down but I might consider adding some insulation on the intake if I can make it kinda stock, thanks for the idea!
05-20-2018, 08:51 AM | #69 |
Subscribed. Planning on this for Walt, when I get the 468 swapped in.
05-20-2018, 10:09 AM | #70 |
Ahem .. practice on mine ?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
05-20-2018, 04:40 PM | #71 |
Never even considered a return system such as this heating up the fuel in the tank. This could explain some hot start issues I've been having!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-20-2018, 06:57 PM | #72 |
You buy it & I’ll come and help install it! . Sorry for the thread jack.
05-23-2018, 01:46 PM | #73 |
I hope to get it running again this weekend.
Cracked vs new Ready to install the new intake. Torqued to spec |
05-24-2018, 08:07 AM | #74 |
I bet by now you can’t wait to get the truck out on the road.
Wise choice on the 4 hole spacer. I used an open one and had a very noticeable squeal on hard acceleration. I installed a 4 hole spacer and it’s totally gone.
05-24-2018, 10:50 AM | #75 |
For anyone following along, two things:
1) That "Notch" in the two-plane intake is important. If your intake is sealed all the way such that the two planes are totally separate, TBI EFI will not run well (or for some brands at all) because the MAP sensor is only on one of those sides. I can't tell if the old 4-hole was separate side to side, but the new one looks OK. The ZZ502 intake from Chevrolet has a notch too, but smaller. 2) Holley offers a linkage extension as well as progressive conversion linkage. I have ordered the progressive kit because otherwise it is VERY touchy. Consider that it opens all four barrels right off the start...
