Old 03-29-2019, 11:21 AM   #51
GreyGhost85
Re: L83 GEN 5 Swap
Originally Posted by vannatta20 View Post
Yes I am. Please pm for my contact info
Are you making your own harness or purchasing a standalone?
GreyGhost85 is offline   Reply With Quote
Old 04-18-2019, 04:32 PM   #52
Dmarkmc
Re: L83 GEN 5 Swap
I have down quite a few gen v swaps. They can be wonderful or a nightmare. First you need to fit the engine and adapt a power steering pump. Next you need to find a harness or get yours modded. I do mod them if interested. Once it is all in you need a fuel system. A standard fuel ls system will work fine. After that you need it programmed. Deleting the security sytem will get it running but not always driveable. Only certain computer os will work on a swap. 8 speeds are much harder to get working than a 6speed. I have only had about 3 successful 8 speed swaps. If you have the orginal tcm for The 8 speed it should work. I can test both computers at my work before hand. If you get everything working together you can get performance like this...
https://youtu.be/uj078sfLnhs
Vannatta20 - what have you used for gas pedals on your C10 swaps? I've got the factory 2015 truck pedal that came with my motor but I sure don't see a very good way to mount it. Any input would be appreciated!
Dmarkmc is offline   Reply With Quote
Old 04-22-2019, 07:28 PM   #53
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: L83 GEN 5 Swap
I used this one.
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
