07-25-2018, 11:03 AM | #51 |
Re: "Outkast" 1985 C10 in Hawaii
I'll throw another vote for the grey. I really don't think there is another choice. These trucks just seem to look right with those old aluminum caps on them. I got one for mine and planned on just putting it on when I needed it it but it has stayed.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
08-06-2018, 11:23 PM | #52 |
After removing the rear bump stops, any trouble with the axle hitting the frame?
08-07-2018, 02:38 PM | #53 |
Not at all... I just have a flip kit so, there is about 5" of travel without the bump stops and brackets. I have had some weight in the back too - a couple full kegs and giant coolers of ice and she never hit the rails.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
08-15-2018, 05:38 PM | #54 |
Well, I finally got her running smooth, its been a challenge. The PO had the original distributer in the newr crate GM 350 and it didnt have any advance on it, mechanical or vacuum. So, Got a MSD HEI dizzy with vacuum advance and got everything tuned like it should be and bada bing bada boom!
I put my rallys back on too... the US Mags just look plain for an aftermarket wheel on the white... I get more props with the rallys on for some reason.
09-20-2018, 03:38 PM | #55 |
Sorry I have been off the site for a bit. Since I got the truck running good, I have just been driving the hell out of it and working on my Harley so, no real updates on the C10.
I am about to do some changes in the interior so, stay tuned for that. I am keeping it relatively stock but, trying out something I did with my 67 that turned out really well.
10-22-2018, 07:25 PM | #56 |
Finally finished up restoring the shell and putting it back on.
10-22-2018, 11:18 PM | #57 |
Perfect!
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
10-23-2018, 07:24 AM | #58 |
10-23-2018, 11:56 AM | #59 |
Thanks all, it turned out pretty good. Now I need to move on to the next task of getting some sounds in the truck. Someone cut the doors out for 6x9s along the way and a hole to get to the window motors. It looks like they used a butter knife to do it... I am going to make a panel to cover the bottom of the door and hopefully match the look. Then move the 6x9s to the back in the corners with a singe 12" KICKER sub.
I need to find a good fitting saddle blanket seat cover. I got one off amazon and it barely covered the seat and the damn string that holds it on all broke because of the slippery pleather seat. Any ideas?
10-23-2018, 10:58 PM | #60 |
Honestly, I wouldn't bother with the 6x9s. Properly tuned front speakers + a sub will be plenty. What do you have for amp and head unit? Let me know what 12" you have and I can help you design a box.
I haven't read any good reviews on saddle blanket seat covers. It sounds like they don't make them like they used to. I'm just going to do a new cover from Acme via rock auto. If you need new seat bottom foam you can get thru ebay: https://www.ebay.com/itm/12548992-MF...0/162357301815
10-24-2018, 04:59 PM | #61 | |
My only concern is the mounting depth of the 12. I dont want to have to move my seat up if I dont have to. By my measurements, I have 4" at the top of the box and 8.5 at the bottom which makes the 5.5" mounting depth of the 12 really close.
10-25-2018, 01:34 PM | #62 |
Hey 808, good progress. Canopy looks good too!
10-27-2018, 09:45 PM | #63 |
Those measurements sound about right. Box volume is more critical than depth, and you can adjust that with width. My box was .7 cu/ft not counting the port area. For a sealed 12, it will have to be a bit wider than what I built. What's the model # of your kicker 12?
10-28-2018, 06:49 PM | #64 | |
I am also debated just building a box for one sub and running all the power through it... It will give me room to put crap behind my seat too. What do you think?
10-28-2018, 10:41 PM | #65 |
These?:
https://www.kicker.com/comp-12-4-ohm-subwoofer If you can fit it, I think it will work OK. My box is 7.5" at the bottom with the seat all the way back. I'd go sealed with as big of a box that you can fit. I wouldn't go ported with that sub/amp combo, plus the box size would be huge. You would also need the theile/small parameters from Kicker and run it through a modeling program to calculate volume and port tuning. Kicker doesn't provide enough parameters to run it through a modeling program, so I wasn't able to come up with an "optimum" size. However in the owners manual, it says 1.25-3.5 cu/ft sealed. Here's a calc that I use for box dimensions/volume: http://www.bcae1.com/spboxnew2.htm That's slightly too much amp for those speakers. But, it should be fine if you keep the gain set low. Wired parallel (optimum), it will see a 2 ohm load. Wired in series (8 ohm) I don't think there is enough power. Whether you run one or two comes down to how much space you want to sacrifice. What were you thinking about for changing amps?
10-29-2018, 08:59 PM | #66 | |
I plan to cut the box out Wednesday and start slamming it together to finish it by the weekend. We will see. As for the amp, thats what I have right now and dont want to spend too much on another right now - we will see what I can dig up though. I am still saving to turn my life savings over to ridetech for a bag set up "someday".
11-05-2018, 03:15 PM | #67 |
Here is my Monday status report. Got the box for the 12s build and made some wings for the 6x9s... Its still kind of raw - debating on what I am going to do about covering them but, I got a cool idea... gotta check back to see where this goes.... !
11-09-2018, 09:04 PM | #68 |
This weekend its on like donkey kong! Gonna finish up the box, cover it and start wiring up my amp and massage chair (my 12s). I have installed my Alpine Power Pack too. Then its time for tuning. Alpine has an app for that... pretty cool!!! Hopefully, I will have more pics on Tuesday.
Happy Veterans Day to all who served!!! Freedom aint free!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 Last edited by 808_67C10; 11-09-2018 at 09:05 PM. Reason: bcuz I cant spell |
11-10-2018, 10:04 PM | #69 |
Excellent! git-r-dun
11-11-2018, 07:11 PM | #70 |
Dig the C Shell
Just a Hillbilly in the Hood http://67-72chevytrucks.com/vboard/s...d.php?t=622194 |
11-12-2018, 08:15 PM | #71 |
11-13-2018, 11:22 AM | #72 |
Got it covered. Not sure if I like it yet... I wanted it to look a lil retro to match the truck. That fabric was a nightmare to work with. It frayed and came apart with every cut. It sounds pretty damn good though... the mass volume of speaker helps. Now I need to spend some time and tune it. The Alpine app is pretty complicated and I have a lot to learn to get it where it should be... for now though... she pumps!
11-15-2018, 01:44 AM | #73 |
Thanks bro... I get good and bad comments about it! I appreciate the support! The comments have swayed to the positive side now that its grey though... plus, I can put my dogs in the back of the truck - that makes it all worth it for me... till I have to clean up the drool all over the truck!
11-16-2018, 04:09 PM | #74 |
Actually! I've been thinkin bout going with an old school c shell myself for my longer jaunts...and you've encouraged me to go ahead with it...sometimes function beats form and I'm getting a little too long in the tooth to try and look like everyone else...keep doin your thing, Brother!
also...the horse blanket speaker upholstery is starting to grow on me...
11-16-2018, 04:23 PM | #75 | |
