Closed Thread
Old 04-29-2018, 12:52 PM   #51
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Re: Parting 71 C30 dually
Originally Posted by jaybatta View Post
Hey Fred, any luck on the cab clearance light harness? Enough to make a pattern?
Joe
Hey Joe,,, nothing left but rust dust. Thanks, Fred.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline
Old 04-29-2018, 12:54 PM   #52
jaybatta
jaybatta's Avatar
Dang, ok Thank ya sir
Joe
1968 K20
1970 K20
Semper Fi
jaybatta is offline
Old 04-29-2018, 12:59 PM   #53
specialtyretail
I have some local guys that do these as well, I will ask them to keep an eye out for a harness for us. Thanks, Fred.
Old 04-29-2018, 01:04 PM   #54
jaybatta
jaybatta's Avatar
Awesome, thank you sir
Joe
1968 K20
1970 K20
Semper Fi
jaybatta is offline
Old 05-08-2018, 09:15 AM   #55
specialtyretail
Hey Joe, I went and pulled one Sunday from a buddy's stash of trucks. I have it listed if you are still interested. Thanks, Fred.
Old 05-08-2018, 09:21 AM   #56
jaybatta
jaybatta's Avatar
Which thread?
Joe
1968 K20
1970 K20
Semper Fi
jaybatta is offline
Old 05-08-2018, 10:15 AM   #57
specialtyretail
I have one on here, cab light wiring harness. Thanks, Fred.
Old 05-15-2018, 06:10 PM   #58
Dawgy
Hi Fred
New here.
I'm looking for a Eaton HO72 rear axle.
Needs to have the load bolt on the driver side near the pinion and the tapered pinion bearings. Pictures on both sides of the drive shaft will confirm that for me. Also needs to have a 5.14 gear ratio.
If you can verify that for me. I will bring cash and my truck for pick up.
Thanks Dawgy
Dawgy is offline
Old 05-15-2018, 07:52 PM   #59
specialtyretail
Originally Posted by Dawgy View Post
Hi Fred
New here.
Thanks Dawgy
Does this help? I do NOT think it is 5.14 ratio. Thanks, Fred.
Old 05-16-2018, 05:10 PM   #60
Dawgy
Hi Fred
Yes that helps a lot.
The last picture you can see the nut that locks what looks like a flat bolt.
That is the load bolt.
Also you can see the oil galley next to the vertical rib for the tapered pinion bearings. The roller bearing pinions do not have that. They look the same on both sides of the vertical rib.
What I can't see in the first picture of the Identification sticker probably list the axle ratio.
I hate to ask but would you be able to pop the rear cover and count the ring gear teeth?
If it's listed on the sticker don't bother with the cover hassle.
I would dread a 5.5 hour drive one way just to find out it has the wrong ratio.
This is my all time favorite axle.
Unfortunately you can't just buy a new ring and pinion. They don't make them anymore. What keeps the cost of this axle low is the cost of the rebuild kits are about $700 and hard to find.
Thanks Don
Dawgy is offline
Old 05-17-2018, 08:44 AM   #61
specialtyretail
Hi Fred
Thanks Don
Gear ratio is 4:10. Thanks, Fred.
Old 05-18-2018, 08:55 AM   #62
Dawgy
Hey Fred
In some of the pictures there looks like a number 7 stamped into the third member on the oil galley/bulge above the pinion. If you wire brush that or sand it can you see any other numbers?
Thanks Don
Dawgy is offline
Old 05-19-2018, 07:00 PM   #63
Dawgy
Hey Fred
Should look like this.
Hope my picture works.
Dawgy is offline
Old 05-19-2018, 07:14 PM   #64
specialtyretail
Sorry, just came another flash flood here. Don't think I will be crawling under the truck this evening.
Old 05-19-2018, 10:01 PM   #65
Krex
Bring cab to Dallas?
Krex is offline
Old 05-19-2018, 10:11 PM   #66
specialtyretail
Seriously,,,,, no... 700 miles one way..
Closed Thread
