Old 07-23-2021, 08:03 PM   #51
skymangs
skymangs's Avatar
Re: 70 c10 project
The water pump is on, tomorrow paint! I am putting a reverse flow water pump and a serpentine drive from a 97 Silverado!
skymangs is offline   Reply With Quote
Old 07-26-2021, 08:18 PM   #52
skymangs
skymangs's Avatar
Re: 70 c10 project
Front of the engine is now masked and touched up!
Old 07-27-2021, 08:14 PM   #53
skymangs
skymangs's Avatar
Re: 70 c10 project
The front of the motor in fresh paint
The lower pulley installed
Old 08-02-2021, 09:47 PM   #54
skymangs
skymangs's Avatar
Re: 70 c10 project
Stabbed the distributor today and prepped/painted parts
Old 08-03-2021, 10:54 PM   #55
skymangs
skymangs's Avatar
Re: 70 c10 project
We removed the mechanical fuel pump and installed a block off plate
We re-installed the fuel rail
Old 08-05-2021, 08:47 PM   #56
skymangs
skymangs's Avatar
Re: 70 c10 project
we had to lift the motor because the power steering bracket was bolted to the motor Mount
This is what I intend to do to the upper plenum and valve covers.
Old 08-10-2021, 08:45 PM   #57
skymangs
skymangs's Avatar
Re: 70 c10 project
we put one runner on (they’re ding free
we also cleaned and painted the serpentine accessory brackets.
Old 08-12-2021, 09:25 PM   #58
skymangs
skymangs's Avatar
Re: 70 c10 project
we got both runners on, but IOT get the old power steering pump off (it was attached to the divers side motor mount. IOT get it off we had to unbolt and lift the front of the motor and lift it. Now we are strugling getting them back in.
Also got the fuel sender in.
Old 08-13-2021, 11:12 PM   #59
skymangs
skymangs's Avatar
Re: 70 c10 project
This is the new 6AN nylon braided fuel line we will be using throughout.
Old 08-17-2021, 11:13 AM   #60
skymangs
skymangs's Avatar
Re: 70 c10 project
We got the EGR block off plate installed
Old 08-18-2021, 11:08 PM   #61
skymangs
skymangs's Avatar
Re: 70 c10 project
We’re painting engine color between the fins on the Valve covers
The upper plenum and throttle body are on
This is a 58mm BBK throttle body (10mm bigger than stock) It should complement my 24lb/hr injectors and adjustable fuel pressure regulator nicely.
Old 08-19-2021, 10:01 PM   #62
skymangs
skymangs's Avatar
Re: 70 c10 project
Today we installed the engine harness through the firewall
we also mocked up a finished valve cover so you can see the look we’re going for
Old 10-27-2021, 12:04 PM   #63
skymangs
skymangs's Avatar
Re: 70 c10 project
We finally got the new motor mounts and pedestals in!
Old 10-30-2021, 11:11 AM   #64
skymangs
skymangs's Avatar
Re: 70 c10 project
We got the polished aluminum rams horn manifolds on
we fabricated the downpipes for the exhaust
Old 10-30-2021, 11:15 AM   #65
skymangs
skymangs's Avatar
Re: 70 c10 project
We bought some 3.5” pipe and cut holes in the crossmember
Then welded the pipe in to tuck the 2.5” duals above the frame
Old 11-20-2021, 10:18 PM   #66
skymangs
skymangs's Avatar
Re: 70 c10 project
We had issues with the ram's horns, with 2.5” pipe they wouldn’t clear the frame. So the easiest solution was to buy new header’s. These Stainless steel shortys are listed for a 70's F body.
Old 12-03-2021, 10:55 AM   #67
skymangs
skymangs's Avatar
Re: 70 c10 project
we started to build the exhaust
2.5 " full duals
We constructed full 6AN lines, fuel and return
Old 12-09-2021, 10:48 AM   #68
skymangs
skymangs's Avatar
Re: 70 c10 project
we finished the exhaust yesterday
2.5” true duals
Should sound pretty mean!
Old 12-09-2021, 10:46 PM   #69
skymangs
skymangs's Avatar
Re: 70 c10 project
we finished the fuel system today
That’s all real 6AN, front to rear
Old 12-11-2021, 10:09 AM   #70
skymangs
skymangs's Avatar
Re: 70 c10 project
we got the upper plenum on for the last time
Also built an AN line for the high pressure power steering hose
Old 12-14-2021, 09:11 PM   #71
skymangs
skymangs's Avatar
Re: 70 c10 project
We completely gutted the dash and wiring in anticipation of the new harness
Here’s how the motor is shaping up
