Old 11-13-2018, 12:12 PM   #51
68 P.O.S.
Re: Carbed 5.3 won’t start please help!
Looks much better now!
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 11-13-2018, 12:57 PM   #52
jjzepplin
jjzepplin's Avatar
Yup!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-13-2018, 02:57 PM   #53
geezer#99
geezer#99's Avatar
You got the primary transfer slot set.
How’s the secondary transfer slot look?
Old 11-13-2018, 05:52 PM   #54
Rdwagoner
I didn’t mess with secondary at all. The secondary transfer slot wasn’t exposed at all to begin with. Didn’t get a chance to fire it back up today. I got side tracked making the adjustment and installing some gauges. Will fire it up Thursday and see how it runs.
Rdwagoner is offline   Reply With Quote
Old 11-16-2018, 05:50 PM   #55
Rdwagoner
Alright gentleman, I went to crank her up today and it just turns over. I have spark, I had my neighbor hold the plug to the block and it lit him up! Lol
I’m gettibg a cam sensor fault on my MSD software while trying to crank. I got one last time but it still fired up. Not today though, will that sensor being bad not let it crank up? Any ideas?
Old 11-16-2018, 10:11 PM   #56
AussieinNC
Moderator
AussieinNC's Avatar
OK..you have spark...
What about gas ? Spray a little ether down the carb and hit the key...if it gord to start...check for fuel in tank....clogged line, stuck flaot etc
If it doesnt fire ...it is most likely the crank sensor gone bad....
Cam sensor errors are not a common non start issue...did you put new ones in during the build...
Check all connections...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-16-2018, 10:22 PM   #57
Rdwagoner
Fresh gas in tank, new fuel lines from tank to new carb. Fuel in bowls, new sensor on order as of this evening.
Old 11-19-2018, 12:06 AM   #58
Rdwagoner
Replaced the cam sensor and the crank sensor. Fires up and runs now. I still have the check the transition slot because it seems to not want to run at all with the slots adjusted to a square. I had to open up the slots more in order to get it to run decent. I do have an aggressive cam so maybe that why?
Old 11-23-2018, 02:55 PM   #59
68Stepbed
68Stepbed's Avatar
I had a similar issue with the sensors. Here's a quick rundown of how the sensors work. The cam sensor typically only works to tell the ECM/MSD what position it's in in order to send spark to the correct side to start the engine. Once started, the ECM/MSD never reads the cam sensor again until the engine is shutoff and restarted. So, if there's a cam sensor fault, it sends spark to random cylinders until it hits one on the correct stroke. Many times, this may cause the same scenario as a distributor being installed 180 degrees out.
As for the transfer slot issue, there's a couple options. First, you need to make sure you have the correct size power valve(PV). That carb comes with a 6.5 PV. Typically, the PV number needs to be HALF of what your optimal vacuum is at idle. Which means a 6.5 PV needs at least 13" of vacuum.
Here's a good video explaining power valves.
https://www.youtube.com/watch?v=RvlmJoeIcpw
Check out this video for transfer slot and idle circuit tuning.
https://www.youtube.com/watch?v=JDPwY0LbRVY
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
