08-17-2021, 04:52 PM | #51 |
Re: High School Build IV (Tyler)
Nice!
08-17-2021, 10:01 PM | #52 |
Those students of yours are doing a Nice job.
Great Work!!!!!! ,,...//
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
08-18-2021, 06:21 AM | #53 |
6>8 Plugless........
It's great to see you guys and gals being able to get back to work on the truck. It's even more cool that she is his sister and is working on the truck. Plus the fact she does rust repair and painting. Pure awesomeness!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-18-2021, 01:20 PM | #54 |
Inside
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
08-19-2021, 08:34 AM | #55 |
Proprietor of Dale's Corner
I'm glad it's making progress again. Looking good!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-23-2021, 02:46 PM | #56 |
Donor
08-25-2021, 10:48 AM | #57 |
Motor and transmission out
08-25-2021, 10:16 PM | #58 |
That's going to be Cool
08-26-2021, 01:15 PM | #59 |
That's a pretty clean LS! Usually they look like a rusty grease ball around here.
08-26-2021, 01:48 PM | #60 |
It might have got pressure washed before pictures
08-26-2021, 01:57 PM | #61 |
Turning 2wd into 4wd
09-09-2021, 10:15 AM | #62 |
We found a 4wd 4l80e - so we didn’t have to cut down the 2wd
Used a 47-52 front crossmember
09-09-2021, 10:32 PM | #63 |
Great Plan
09-10-2021, 06:44 AM | #64 |
That worked out nicely!
09-10-2021, 07:06 AM | #65 |
It looks like it fits good.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man Last edited by Ol Blue K20; 09-10-2021 at 07:09 AM. Reason: grammer |
09-15-2021, 09:15 AM | #66 |
Gotta move spring hangers
Putting in the 3/4 ton 63” springs
09-15-2021, 09:44 AM | #67 |
It's going to be a nice truck.
09-15-2021, 10:48 AM | #68 |
Are you going to do a shackle flip too while you're at it?
09-15-2021, 01:32 PM | #69 | |
What is the advantage?
09-15-2021, 06:37 PM | #70 |
No need for a lift block between the spring and axle that way and less axle wrap.
09-16-2021, 01:00 PM | #71 |
Removing and relocating saddles on the 03 rear end
09-16-2021, 02:54 PM | #72 |
14 bolt mocked up
After moving hangers - 03 springs gave us 3” of lift With that and 2” easy rides in the front it should ride pretty good
09-16-2021, 03:21 PM | #73 |
I like the numbers. Should work out nicely.
Gotta ask.... What wheel choice are you thinkin?
09-17-2021, 10:17 AM | #74 |
03 wheels painted black as of now
09-23-2021, 02:13 PM | #75 |
03 rearend is in
