Old 12-25-2019, 01:46 AM   #51
Madkidd007
Madkidd007's Avatar
Re: 90 crew 1 ton Cummins 47re swap
Something for you to think about, I’m running a 24v plate which moves the air hole forward to the next set of holes. Hence a few inches further forward
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 12-25-2019, 01:45 PM   #52
74project
Great idea on the intake.. the lines r for the transmission I got from frozen boost..nice stuff good price..
74project is offline   Reply With Quote
Old 12-30-2019, 12:57 AM   #53
74project
Picked up an 81 shortbed at an auction for 3500 bucks.. no plans with it just regret selling my old 85..
Old 01-03-2020, 11:38 PM   #54
74project
Tank is almost done.. fits perfectly just now have to find a way to hang it. Either weld brackets to the tank and attach to frame..but frame flew could crack tank.. or use some strip metal and use to support tank.the white truck I sold to my buddy.. it was one of my first swaps I super regret selling..owell.
Old 01-03-2020, 11:43 PM   #55
74project
Still trying to figure out this firewall patch number..
Old 01-09-2020, 12:04 AM   #56
74project
So I dont know if anyone has used spray foam in the fenders or am I the only retard here? Well I know about the rumors of what could happen but I just had to try it out.. so far so good it has really made them sound like a solid fender. My goal from the beginning was to make a comfortable, reliable, truck or I am headed to the dealership..
Headliners suck for the crew cab here in Vegas.. when it's a buck 50 glue melts and they sag. I think I'm going to try the black spray foam in the roof and keep the paint for a clean roof look. Something has to be in the roof (spray foam) or a headliner due to the heat. It gets so hot u can't even touch it from the inside of the truck.
Got the new heater core installed and took out all of the old firewall matting.. boy is that stuff flammable..I took a video of it..
Old 02-02-2020, 07:28 PM   #57
74project
Made some battery cables..for some reason I have been unable to post..
Old 02-05-2020, 03:08 AM   #58
randy500
Tank looks beautiful. Is that mig welded?
randy500 is offline   Reply With Quote
Old 02-06-2020, 12:16 AM   #59
74project
Hello,
Got the tank set up.. hard to position by yourself this thing is huge but it does not hang down that low..coat it in raptor liner today. Would like to start it up soon....some other thing still trying to figure out...super pumped about the fenders.. they are super solid with the spray in foam. I am going to also do the whole roof and back part of cab..TIG welded.
Old 02-06-2020, 12:22 AM   #60
74project
Heeded the 14" Bilstein shocks.. Amazon has been really good at all of my returns..
Old 02-06-2020, 07:35 PM   #61
burnin oil
Back around 2000 one of the military commands tried sprayfoaming the square frames on Hummers to keep the dirt and salt water out. Short lived experiment. All the test frames rotted out way quicker. I wasn't to surprised. It really is no different than guys putting newspaper behind body Bondo. The patch stayed but all the wet mess made the metal adjacent to the repair rust and drop out an even bigger section. If you use foam atleast make sure that it is closed cell so that it doesn't act like a sponge.
burnin oil is offline   Reply With Quote
Old 02-09-2020, 12:10 PM   #62
74project
Yea I was just trying out the new black spray foam for RV's and boats. Nothing rust out here in Vegas I will post a pic of my bare metal fire wall on the 54. It's about 4 years old and no rust. Worst case in 5 years I buy new fenders but they are so solid..
Well got 50 gallons of freedom mounted.. might fire her up this weekend...I will try to grab a video of it..
Old 02-09-2020, 07:09 PM   #63
Sicksty8
Sicksty8's Avatar
Nice swap! Curious how you'll be controlling the 47re. I did a similar swap with a 24v and a 47re in my 69 C30 and the stock PCM is giving me security issues I believe. Info on RE swaps seems to be tricky to find.
Sicksty8 is offline   Reply With Quote
Old 02-10-2020, 05:41 PM   #64
74project
I was thinking about the stand alone harness on Ebay..have you heard of any reputable stand alone harnesses?
Old 02-12-2020, 11:55 PM   #65
74project
Well my bottom lights do not fit due to the intercooler.. I can either get a smaller intercooler or can I change my front grille? I dont think it will fit behind my radiator..any help will be appreciated..
Old 02-13-2020, 01:12 AM   #66
Madkidd007
Madkidd007's Avatar
How about go led. I’m sure you can find something aftermarket they right size
Old 03-08-2020, 09:27 PM   #67
74project
Yeah got her started..2 months behind skeggie but it should be a lil more enjoyable putting everything back together over the next month.. will post some pics later...
Old 03-09-2020, 09:09 PM   #68
74project
Had to change out my radiator..it was too big. Have all the wiring almost complete. This build was much more work than previous builds... It fired right up the first couple times then I played with the afc live and it smoked out my garage.. so no more starting until I can pull in on my driveway. I think I have about 2 more weeks until I drop it off to get my driveline made. The lower radiator hose configuration is not as smooth as I would like it..that was another reason for the new radiator..
Old 03-25-2020, 08:50 PM   #69
74project
Awwww man tuff couple days..this virus has been here since late December in Vegas..had many sick people throughout January (gov always a lil behind)..but anyways got the ETRANS CONTROLLER all hooked up. Decided to go without the throttle position sensor and they say works the same.. O boy the trans was making a cavitation sound every time i started her up and couldn't figure why..I guess you have to put the transmission in NEUTRAL in order to get the trans fluid into the torque converter... who woulda thunk?? Well after the research on starting a dry fill transmission that's what you do fyi. Now she idles perfectly smooth.. It sounded as loud as cavitating a fire pumper... going to have to put the truck on hold for now until I can reason spending 1k for exhaust and a driveline... see u all hopefully in a couple months..
Old 03-25-2020, 10:23 PM   #70
Madkidd007
Madkidd007's Avatar
Keep that in mind also when checking the fluid level as older dodges don’t pump in park and same thing after pulling heavy the trans won’t cool down in park.
Old 04-04-2020, 09:52 PM   #71
74project
Hope everyone is doing well. News here in Vegas is not reporting the ACTIVE CASES.. only 1418. This has been here a couple months and I expect it to decline sooner than.. hope u guys are staying active and eating healthy... working on the truck bed.... it took 6 guys to lift and move it from the side yard and one guy to remove it huh? Nothing like good old steel trucks..
Old 04-04-2020, 09:55 PM   #72
74project
Some funny memes out..
Old 04-06-2020, 08:18 AM   #73
74project
Got the gas fill for under the truck bed. I need to go buy a bag of sand or find a 90 degree elbow.. I've tried every trick with the harbor freight tubing bender and no luck.
Old 04-08-2020, 03:48 AM   #74
jarrodblake
jarrodblake's Avatar
What power steering lines did you end up running?
jarrodblake is offline   Reply With Quote
Old 04-11-2020, 10:19 PM   #75
74project
I just bought a cheap Amazon stearing line..I dont even know if it's right..
