06-27-2019, 08:39 AM | #51 |
Re: Lowering Regrets
Yep, do this incrementally. Springs first. Lots of folks on here successfully running drops similar to what you’re wanting with big wheels.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-27-2019, 09:08 AM | #52 |
67-72 parts collector,…
This is my old '69 that member n2billet has now.
Its low with 20's and rides just fine. Front: 2.5" drop spindles 3" drop springs. KYB drop shocks Rear: 6" drop springs from ECE 2" lowering block ECE rear shock relocator ECE Super Track Bar KYB drop shocks Bolt-in C-Notch Stock 1-1/8" sway bar on shorter ECE sway bar mounts and poly bushings from Energy Suspension. Correct backspace wheels also helps it work. The tires in this picture are 245/40-20 and 275/40-20.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-27-2019 at 11:38 AM. |
06-27-2019, 11:12 AM | #53 |
20" wheels are great but they are not for me and how I drive the truck (500+ miles a week and at very high speed). I regret going from LWB/Stock Ride Height/Rallye wheels so I am trying to get back as close to that as feasible (basically reverse what I have done within reason).
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
06-27-2019, 06:08 PM | #54 | |
As for tires, if you plan to go back to 15's a 255/70/15 rear and 235/70/15 front looks good on that drop. You could also run a set of 15x8 gray spoke TTIIs on all fours with the same sized tires for rotational purposes and still have a cool, classic look. Aftermarket wheels have different backspacing that will clear the drop spindles and solve any clearance issues with rally wheels.
06-28-2019, 04:45 PM | #55 | |
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
