11-14-2019, 01:24 AM | #51 |
Old member
Re: Daughters 68 step...
Just did a big order from GMC Pauls just now. A bunch of $$$$.$$ and this should just about get the truck back on the road. I hope to find a 67/68 front grille used but not dented up to go on it. Maybe some fenders to if I'm lucky.
11-14-2019, 07:34 AM | #52 |
No grass growing under Andy's feet !
11-14-2019, 10:19 AM | #53 |
Old member
Thanks,
I have a dead line of Dec 31,2019 to have this truck out of my friends shop. He is selling it and I need it done, well at least drive-able anyway. The bed will not be done by then I'm sure, seeing how I don't have one for it yet. I know I can't cut the LWB bed down before then. I just want it moving under it's own power by 31!
11-14-2019, 10:49 AM | #54 |
Andy, you are a busy guy for sure!! I am sure you will get it done.
Question out of curiosity for a relative newbie to the board, why do you have your posts in bold red? Not an issue for me, just curious if there is a back story.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
11-14-2019, 11:26 AM | #55 | |
Old member
Just got in the habit of posting this way. I've had people get upset about it to. Has nothing to do with any type of posting about hollering are anything, I didn't even know about that when I started doing it.
11-14-2019, 11:28 AM | #56 |
That's great!! I totally agree. Nice to see some change! I have read many of your posts and they are very informative. Thanks!
11-14-2019, 11:28 AM | #57 |
i was curious about that as well but figured it was just to know where his posts where in a thread, never crossed my mind there might be another reason.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10” |
11-14-2019, 11:46 AM | #58 |
Old member
Thanks guy's. I try to help whenever I can.
11-14-2019, 02:57 PM | #59 |
Andy , if you were closer I have a grill I would let go . But we are 4 hours apart and shipping would be killer .
11-14-2019, 07:34 PM | #60 |
Old member
Would you meet me part of the way if I was to come that way say to summit racing are some other place?
Could you send me some pictures? I went over today and did some welding and tearing a part the doors to get ready for new parts I ordered last night. I was very pleased with what I got done. My welding is getting better and better but it's still got a way's to go. I got all the door hardware removed from both door's and even got the door latches blasted and blown off. Ready for primer. Got the glass out but have to reseal the drivers side it came out of it's brace. Have to look and see if my old 71 window cranks will work. They look better than these do.
11-14-2019, 08:51 PM | #61 |
Give 'Fastenal' a try....shipping might not be all that bad....
11-14-2019, 09:54 PM | #62 | |
Old member
What are you reffering to sir?
11-14-2019, 10:46 PM | #63 |
11-14-2019, 10:54 PM | #64 | |
Old member
11-15-2019, 10:01 AM | #65 |
I don't think it needs to be strapped on to a pallet, perhaps just wrapped.....
11-15-2019, 10:17 PM | #66 |
Old member
A little more done. Got the vent wings out after them soaking in PB blaster over night the top 3 screws wouldn't move yesterday. They came right out today!
Got the windows both a part and blasted the supports and channel's they run in. Glove box hinge blasted, and front park light housings done and the front grille is looking much better than I first thought it would. Still working on it though and waiting to see how it turns out.
11-19-2019, 07:48 PM | #67 |
Old member
We set the cab down on the SWB frame today. Getting ready to start cutting out the old rocker panels. She was all excited, then I told her it had to come back off once we have them tacked in place. The mounts set down good and bolts lined right up. All new hardware.
11-19-2019, 07:59 PM | #68 |
Before you put a bed on the SWB frame could you measure the distance from the back of the cab to the first bed mounting bolt hole and then measure from that bolt hole to the other bed mounting holes. This will help me if I shorten my own LWB frame. Thanks D
11-19-2019, 08:47 PM | #69 |
Old member
I sure will tomorrow. I will do my best to remember.
11-20-2019, 08:22 PM | #70 | |
Old member
11-21-2019, 04:24 PM | #71 |
You may know this already but shine a light from inside the cab on your gas filler panel to make sure you don't have pinholes in your welds. Due to the temperature (condensation) difference inside/outside the cab this will get moisture in the body filler and rot from the inside out. I wasn't aware of this and had a bunch of pinholes in mine before someone told me to do this.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
11-21-2019, 08:07 PM | #72 | |
Old member
Thanks and yes I have been checking it. I finished up the passenger side repairs today. Being my first welding on sheet metal panels I had a good friend come over and give me some good instructions on heat settings and feeding. He is the retired welding instructor for the local vocational school here. The welder had .030 wire in it and he suggested we swap it to .024 and man what a difference it made. I had a good day. I started working at 9:30am this morning and I'm basically 2 days ahead of what I thought I would be on the truck right now. Is it perfect heck no but man it feels good to know I can repair sheet metal panels if I ever have to again.
11-21-2019, 10:17 PM | #73 | |
Here are the frame specs for both the 127" (top) & the 115" wheel bases.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
11-21-2019, 11:10 PM | #74 |
Thanks for the measurements guys! Now I know where to move the trailing arm cross member too. On the blueprint sheet the 0 line is the front of dash. All measurements are taken from this point. Forward( to the front) backward ( to the back).
11-22-2019, 12:09 AM | #75 | |
I have been informed that EZ grind wire is the real deal. I will refrain from using that (P) word Pro that is. I purchased some from my Local welding supply store. I got it at a good price. It's a little bit higher on e__ -Bay I have not used it yet. Because I am not to that point yet. This is just a Suggestion. This throwing that out there / .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
