Old 04-04-2020, 10:11 AM   #51
cornerstone
cornerstone's Avatar
Re: Pre-Start Concerns... Gen 5 sat dormant for 3+ years
Originally Posted by bigmoe View Post
You do have a heavy main ground from the batt - to the head? All grounds on the engine harness hooked up?
No sir, I ran the ground from the battery to the frame. I do have a ground strap going from the frame to the head though... I bet that's one of the problems. All grounds are from the GenV harness are attached to the block or head.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-04-2020, 10:16 AM   #52
bigmoe
bigmoe's Avatar
I suppose that would work provided it's all heavy enough gauge. Factory runs directly to the head, then down to the frame.
bigmoe is offline   Reply With Quote
Old 04-12-2020, 06:54 PM   #53
cornerstone
I had the connectors installed backwards on the injector rails. Mitch from Swaptime was gracious enough to text back and forth til the problem was solved a few days ago. As soon as it fired I knew what my next project would be... stop the giant exhaust leak. In order to do that I needed to relocate the oxygen sensor bung on the header. It was pointing directly at the trans cooler lines and the 2 couldn't occupy the same space. I drilled a hole where it wouldn't have any clearance issues and welded in a new bung, then just plugged the old bung with the proper size bolt.
Once I got the header installed I started it up again. This time I heard some not so good sounds. Almost like it sounds when a starter motor is catching on the flywheel, but not exactly consistent with the rpm. Even though I have only run the engine a total of less than 5 minutes, this is a newly developed sound. I was thinking perhaps it is a problem with the torque converter bolts... the factory says to replace them and not to reuse, well I put the used ones back in anyways. Do y'all think that is absolutely mandatory?
Brian
Old 08-19-2020, 08:44 AM   #54
GerhardH
GerhardH's Avatar
Hi Cowboy,
how is going with the engine and the earth-moving works?
Stay safe
Best regards GerhardH!
Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20
1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400
http://67-72chevytrucks.com/vboard/s...d.php?t=760400
GerhardH is offline   Reply With Quote
