#51 | |
Re: Budget Shortbed: welding, grinding, rust oh my
#52 | |
Post Whore
![]() Join Date: Feb 2016
![]() Hijack completed. Please continue with your great work. HO455
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#53 |
Not a hijack at all! That's a great point, lighter guage structures mean better gas mileage, less expense in raw components, and all sorts of other things that tickle the corporate pocketbook. Alot of OE robots are set up to production "weld" the light guage components because it really is a great solution for that. I have to assume that they do thier fatigue stress and element analysis on the design with consideration to the brazed joints.
#54 | |
#55 | |
#56 |
Last night I rough fit the rocker and hung the door. There was a little bit of massaging on the front peice to get it to sit in the right spot. The backside came up about a quarter inch short of the top of the B pillar, but it can be clamped into place. I also ended up taking a section of the cab corner out to contour it to the rocker, and achieve a consistent gap between the two. The only ill fitting area left is the bottom spotweld seam on the b pillar end. Once I start welding it in, it should be easy to knock all the corners in tight.
#57 |
I mounted the door, and after an hour or two, I think I've ended up with the best fit I'm going to get by myself.
I don't like it as it sits. If I can get another person to help me shift it up, and clockwise just a bit then it may be decent. I don't think I'll need to do any major rocker adjustments either way, but that could change. |
#58 |
I finally finished the driver side metalwork completely. I was able to get the door positioned better too. I also had to make two last panels just inside the inner rocker. Time to do it all over again on the next side
#59 |
excellent welding/work. Thanks for taking the time to photo and post
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
#60 |
![]() Join Date: Apr 2008
Good progress
71 C10 72 K20 72 K10 Super Kirk |
#61 |
Post Whore
Good work!
If I may on your door alignment if you have a problem getting it all to come in even all around you might have the same problem as the drivers door on my Burban. The window frame was not welded in the correct position and prevented me from getting a good alignment. Another plus of owning a truck built on Friday. ![]()
#62 |
I know you still have plenty of work left to do, but the work you have done to date is pretty awesome. Pat yourself on the back.
Cleverly disguised as a responsible adult... |
#63 |
I've been busy working and not posting so here's an overdue update.
I completed the metalwork on both sides and sealed and painted it all. The cowl vent area on the passenger side was thin enough to poke a finger through, so I cut section out and found a real mess. I had to make panels for the vent tunnel, and floor of the cowl side. I'm guessing most trucks have a similar dirty secret. I checked the other side, and it was similar but not as bad. I decided to vacuum it out as best as possible and por15 it from inside and out which was real tough. I also cleaned and applied por15 to the cowl to firewall lap from inside the cowl, and seam sealed it. I continued seam sealing everything that looked suspect. |
#64 |
I guess I didn't take any other floor pics. Here's the cowl.
#65 |
More cowl stuff. I took a short break to restore an old finger break I've had that needed some work before I could form my new panel.
#66 |
Trying to match the oxidized hugger orange, I'm trying Chrysler hemi orange. We'll see when I do the doors, I know it won't be perfect but I'm not extremely concerned.
I also picked up a Dodge buddy bucket which I'm really excited about. I'll make some mounts for it shortly. I figure I might as well put a halfway decent interrior in it now, and I have some extras from my 69 CST that will fill in the gaps. |
#67 |
Post Whore
Once again great work!
#68 |
![]() Join Date: Dec 2009
Nice pattern making for your Sheetmetal.
Great job. What kind of finger brake are you using? .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#69 |
Thanks!
Thank you! I folded the paper over the panel I cut out and rubbed the bend lines and edges with my dirty hands to transfer the lines to the paper. It's an older 24" Di-Acro, and is 300 some pounds if I remember correctly. I got it broken, I think it took a fall, but after I fixed the handles and reassembled it you'd never notice. |
#70 |
amazing work for sure, looking great !
...I have the same Diacro brake, that thing is like a tank ![]()
#71 |
![]() Join Date: Aug 2004
Nice job man!
That’s a cool little brake, perfect for this kind of work.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#72 |
Thanks guys. It is a nice little tool to have around. I welded up the holes in the doors and am doing some bodywork on them in preparing to match the condition of the rest of the truck, should be interresting. A side note, if you have big holes to fill, I use carriage bolts, or even roofing nail heads as a patch. Just watch welding plated material without decent ventilation, it can make some bad fumes. I've been meaning to pick up some acid to remove plating for odd projects like this.
#73 |
![]() Join Date: Oct 2015
I agree with everything said so far. Nice work for sure. Really appreciate your time in documenting all this for all to see. Well done.
#74 |
looking good. I just finished replacing inner and outer rockers, lower hinge post, kick panel bottom, floor at kick panel, and factory screw ups on my '71 long bed. About ready to get the interior color back to Ocre from awful generic yellow.
Pulled the windshield over the weekend and very little rust at the seam/channel. Oh, passenger door need major rust repair, drivers door in good shape. Patching/welding is done for the most part on my refurbishment. I want to use my '71 as a truck so not going the full restoration path. Good luck, keep up the good work. |
#75 |
Thanks, good luck on yours too, sounds like it will be nice.
I painted the doors to try to match the rest of the truck. With a little airbrushing I think it will work. The cracking on the driver door was unintended but I guess it's ok. |
