12-12-2003, 04:05 AM | #51 |
Available for Adoption
Eric, are you sure you REALLY wanna build a 400-450 hp daily driver? Don't get me wrong, I love a hot rod and outside of a few lost years, I've always driven one as a daily driver. But, to get this kinda power out of a small block it's going to require some compression and rpm's. Personally, I don't like driving anything everyday with more than about 9.5:1. Around here, not that far from you, you just can't get much above 90 octane gas, so running more than that will most likely require better gas which comes at a premium price. Turning 6000-7000 rpm is going to require stronger parts. Also, they generally don't make a ton of torque down low where you want the power in a daily driver. I relate it to Harley's, which I know a great deal about, they make a ton of torque down low, which makes them a blast to ride, but they won't go 180mph down the highway...who needs to do that anyway... You gotta think about what this truck is going to be doing for you everyday, carrying your a$$ back and fourth to work and school. If you pay close attention matching up you cam and heads you can easily get 350 hp out this rig without breaking the bank....cheaper than a crate motor....spend the money you saved on getting that hp to the ground....gears-tranny-etc....you'll smoke all these punks riding around in the GT's and Firebirds... 450hp is real overkill when your talking light to light fun.....
Maybe I'm all wrong about what you'll be doing with the truck....Basically, I'm just saying consider what your going to be using it for....Then work from there.... I try to make mine as fast as possible, without loosing it's everyday drivability.... Most of all, have fun......
1983 C10 SWB 2001 Silverado SWB 1995 Corvette |
12-12-2003, 08:16 AM | #52 | |
(45 minutes run time & I am replacing my block now.) http://www.northernautoparts.com/Pro...ctModelId=8961 Hypereutectic Pistons With Coated Skirts Chevy 350 Hypereutectic Flattop pistons. Manufacturer: Federal Mogul/Sealed Power Model Number: H345NP30 Price: $ 12.64 ea If you want Machined: part # H126CP Price: $ 28.99 ea or: the Kit> http://www.northernautoparts.com/Pro...ctModelId=1668 Chevy 350 STREET PERFORMANCE Part #- HP350KH Hasting or Sealed Power Moly Rings Federal Mogul flattop HYPEREUTECTIC Pistons Clevite Rod Brgs Clevite Main Brgs Clevite Cam Brgs Melling or Sealed Power Hi volume Oil Pump Crane Energizer Camshaft and Lifter Kit Cloyes TRUE Roller Timing Components Pioneer Frost Plugs Felpro Gaskets Make: Chevy Model: all Year: to 1985 Price: $352.54 http://www.enginekits.com/ (this is where my parts came from) Powerhouse Exclusive Chevy 350 9.5 "super" Balanced Daily Street Driver - Pistons with moly graphite coating; reduce friction Kit Che 350I: Chev. 350 : Speed Pro Hypereutectic "coated skirt" Pistons 10.8 compression (using 64cc heads) 9.5 compression (using 76cc heads) Hastings premium moly rings; rod bearings; main bearings, cast crank (no more than 20X20) CR3 rods w/ARP Bolts Now Only $599 Last edited by Nvbowtie; 12-12-2003 at 08:34 AM. |
