Old 03-14-2020, 08:01 PM   #51
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: PCM help and monitoring water temp and oil pressure
Originally Posted by LS short box View Post
Make sure your 12 volt switched has 12 volts with the key in the start and run position. The brake light switch needs two set of contacts. One for the normal brake light operation and for the torque converter lock up. I typically use a 2002 Camaro switch for an automatic.
Thanks for your information. I was unaware of this until I started this thread. This was mentioned in post #23, but I appreciate your input. You guys have been great. I thought that brake switch was needed only for cruise.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
