![]() Join Date: Jul 2015
Really? Ok.
I didn’t think anyone would want old ones except me.
1963 C20, small window, long bed 292, 4-speed |
Re: Looking for advice - wood bed 63 C20
I have all the lengths cut and all the widths cut. Now I need to figure out how to cut the edge profile. Anyone have any suggestions?
I was thinking of using a straight router bit for the 3/16” groove. Not sure about the edge cut though. Maybe another router bit for that too?
#3 | |
![]() Join Date: Oct 2017
Moderator
![]() Join Date: Dec 2012
Like I said, first set was on radial arm saw (turned sideways) second was table saw. Need a dado blade for the second cut.
That wood looks rough, it looks like it needs a pass through the planer... Last edited by jayoldschool; 07-18-2020 at 09:37 PM. |
#5 | |
These rabbeting router bits use a different size bearing to make a different cut? EDIT: I’m doing everything from the rear bumper of the truck, so not a lot of options. I think I’ll just get a 1/2” router bit and router the last edge, just a little less deep.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 07-18-2020 at 11:00 PM. |
I actually just did some work on my bed. I removed all the old wood took and the bed off. Pressure washed the whole chassis, wire brushed and scraped off 60 years of gunk, and then painted it gloss black with rustoleum thinned for a sprayer. I rattle canned the diff cover with metallic hammertone (not pictured). I just dropped truck off yesterday for paint!
As a woodworker I have the tools to make my own bed wood but by the time I priced out some 4/4 S$S white oak it was close to $500. Hell even the rawer rough 5/4 was too much. To then take the time to do all of the additional work planing and routing didn't seem worth it to me. So I am just going to get the Oak wood kit from car and truck shop here in Charlotte and then varnish it myself.... |
![]() ![]() ![]() Join Date: Jan 2018
My dad and I used this small router table he had. Was definitely a 2 man job since we had to run the boards over the table, but it worked out pretty well. We used two router bits to make it work. First pass cut down to where the strips sit on, second pass cut the deeper groove
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Moderator
Yes, borrow a table saw from someone for this work. You can make multiple passes to get the part outside the slot knocked down if you don't want to buy a dado blade set.
Just to be clear, one of the boards (7-7/16”) will run into the wheel well, correct?
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 07-22-2020 at 01:02 PM. |
Getting there...
Moderator
Good work! Yes, the outermost full board goes under the tub. You put the tub (wheel well) in place, reach in from the bottom, trace the inner edge of the tub on the wood with a marker, remove, cut with jigsaw. See my pics on post #25.
#12 | |
Still got a lot of work.
#13 |
The stain color looks nice. I am going to be staining my bed wood soon. I am planning on staining all surfaces of the wood...top, bottom, sides, ends and the grooves...Would hate for moisture to expand the wood in an exposed area.
#14 |
I was thinking about that, however, I still sealed it with polyurethane. Hoping that will hold up for a while. Not sure how long I will keep this truck. So, I don’t mind redoing it in a couple of years if I still have it.
#15 |
Still have to cut the inside of the wheel wells. Trying to figure out an easy way to mark the boards. Probably just a grease pencil?
